Installation & Licensing
error launch Autodesk products
4 REPLIES 4
dancol86
837 Views, 4 Replies
hi, when i launch any Autodesk software (Autocad, Inventor, 3d Max) appears the next error:
AutoCAD Application stop working
Problem details:
Firma con problemas:
Nombre del evento de problema: CLR20r3
Firma del problema 01: acad.exe
Firma del problema 02: 25.0.55.0
Firma del problema 03: 4f309abd
Firma del problema 04: mscorlib
Firma del problema 05: 4.0.0.0
Firma del problema 06: 4d92ee1b
Firma del problema 07: 4490
Firma del problema 08: 2
Firma del problema 09: FatalError
Versión del sistema operativo: 6.1.7601.2.1.0.256.48
Id. de configuración regional: 9226
Información adicional 1: e86d
Información adicional 2: e86df45bcd9f24879db30de595fa498a
Información adicional 3: 1cfe
Información adicional 4: 1cfe51125539dd1c69b3ceecc019b9d7
Lea nuestra declaración de privacidad en línea:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0c0a
Si la declaración de privacidad en línea no está disponible, lea la declaración de privacidad sin conexión:
C:\Windows\system32\es-ES\erofflps.txt
4 REPLIES 4
TravisNave
in reply to: dancol86
Errors like this are almost always related to a corrupt .NET Framework.  You might want to reinstall your .NET versions.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
I've also see this error with SQL Server, so it could be a problem if you have that installed for materials libraries.  Just a thought...
Always list your application version and your OS for future help.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
dancol86
Thanks so much, problem solved
aletori
Hi!, I have a similar problem to dancol86, but not the same....
Firma del problema 01: ACAD.exe
Firma del problema 02: 26.1.49.0
Firma del problema 03: 54d44341
Firma del problema 04: WindowsBase
Firma del problema 05: 4.6.81.0
Firma del problema 06: 5584f195
Firma del problema 07: 10a6
Firma del problema 08: 0
Firma del problema 09: System.StackOverflowException
Id. de configuración regional: 11274
Información adicional 1: 0108
Información adicional 2: 010852d059e43570cac8fdd8e4e7fb28
Información adicional 3: dc61
Información adicional 4: dc61a9a34ef80e07c06ae62fdaf055cc
aletori
in reply to: aletori
Sorry, the program is Autodesk Advance Steel 2016
Administrator Productivity
