I am trying to install student version of revit 2014 and two errors come up during installation.
1308; source file not found
1712; unable to restore
I installed 2013 then when class started we started on 2014 with 2013 book. you can see why I installed 2013.
2013 does not open 2014 files.
I uninstalled 2013 then was having some issues and needed to clean pc.
Any help would be greatly appreciated.
Thank you.
Start here:
Good luck!
Thanks for reponding.
The link di not work.
After downloading, was asked to extract files, selected ok and another error came out saying corrupted file.
So, I tried second suggestion and I am not clear where the settings tab is and what to change?
Thanks again for your response.
Hello. If you are receiving a corrupted file message, you likely failed a download. If you are wireless, plug in.
I would download using the Virtual agent:
If this does not work, I would consider downloading from a different machine, if possible.
Thank you for taking part in our community!
