Installation & Licensing
error installing inventor 2013
1 REPLY 1
svigelj.gregor
378 Views, 1 Reply
2012/12/3:16:59:35 Gregor Švigelj GREGA Install Autodesk Material Library 2013 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2012/12/3:16:59:35 Gregor Švigelj GREGA Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2012/12/3:16:59:48 Gregor Švigelj GREGA Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2012/12/3:17:00:11 Gregor Švigelj GREGA Rollback Autodesk Material Library 2013 Succeeded
2012/12/3:17:00:11 Gregor Švigelj GREGA Rollback .NET Framework Runtime 4.0 KB2468871 Failed Failure is ignored, Result=1619
2012/12/3:17:00:11 Gregor Švigelj GREGA Rollback .NET Framework Runtime 4.0 Failed Failure is ignored, Result=1619
I cannot install inventor, i dont know whats the matter?
please help me, thank you.!
1 REPLY 1
TravisNave
in reply to: svigelj.gregor
It's not able to complete the download of the libraries.  Make sure you have a solid internet connection and that you are not using any blocking software to impede you, like Norton Internet Security, etc.
Autodesk Forums:
Administrator Productivity
