Hi.
During my installation of AutoCad 2014 my computer experienced a power failure. When I started the installation again hoping it will just start installing again. Then the installation suite told me that AutoCad 2014 is installed already and it seems you can't reinstall. I have tried to remove AutoCad 2014 through the control panel and try installing AutoCad again, but to no use! (by the way I have windows 7-64bit as operating system)
If you could please assist me with this problem, I would appreciate it!
Solved by TravisNave. Go to Solution.
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-perform-a-clean-un...
That should get you headed in the right direction.
Good Luck!
