Installation & Licensing
error installing AutoCAD 2014
1 REPLY 1
201 Views, 1 Reply
I am trying to install AutoCad 2014 now, but I keep running into the same problem.  I'd tried to install it a couple months ago, but ran into a disk space problem.  Trying to install it now, I did go through the control panel and uninstall the remnants from before, but every time I try and install, it tries to use a non-existant pathway, and it will not let me change it (see attached photo).  How do I fix this?
1 REPLY 1
Yannick.Karawa
Sorry to hear that you're having problems installing AutoCAD, this issue may result on some corrupted registries entries on your PC.
You can remove the remaining installation keys by using the utility from Microsoft "Fix it".
http://support.microsoft.com/mats/Program_Install_and_Uninstall/
That should help to resolve your issue.
Cheers
Yannick Karawa
Administrator Productivity
