I am trying to install AutoCAD 2014 or AutoCAD 2013 for that matter. As soon as the installer is initializing I get and error message come up that the autocad installer terminated due to an unexpected error. I have submitted many reports to Autodesk however, I have still not had any reponse.
In addtion to this I have managed to successfully install Revit 2014, which to me suggests there might be problem with th installer of AutoCAD 2014.
I am ruuning a PC with WIndows 7 SP1 64bit. I would appreciate it somebody could help me in resolving this issue.
Solved by nirav_98. Go to Solution.
Solved by asburyj. Go to Solution.
Hi nirav_98,
Welcome to Autodesk Discussion Group.
Are you able to get the installation going under Diagnostic Mode?
Please download AutoCAD 2013 or 2014 from our Virtual Agent (Matt), just to be sure we eliminate installer issues.
** Select [Downloading and Installation] --> [Software Download Links] --> [I need to redownload my product]
Thank you.
I have downloaded the the installation file form the Virtual Agent and I still have the problem. See a screen shot of the error I am geting.
I will try to install it in diagnostic mode.
Hello. Error reports are not submissions for assistance, they are automated submissions that are aggregated for development purposes. In some situations, if the system can identify a fix for a specific issue it will send an automated response, but this type of error submitted from a crash is not a direct submission for assistance.
Your issue specifically, is a crash during the early phase of the installer. It sounds as though you probably have a good download at this stage. So it makes me wonder what is on the system that could be in conflict.
You should first make sure to have Antivirus turned off completely- and open the Task manager to ensure it is off.
I would clean the TEMP directory.
If this doesn’t help, change your TEMP directory
After your test, use the copied paths in the new text file to return the variables to normal.
It is possible there is a conflict in Internet Explorer 10, if you have it installed:
The MSI installer may need to be started or registered:
http://support.microsoft.com/kb/324516
Thank you for taking part in our community!
I have tried the possible solutions from Aaron about trying to install it diagnostic mode which unfortunately has not been successful.
David: I also tried your solution, but unfortunately it was not successful and have had the same results.
The funny thing is that I have managed to the install Revit 2014 and 3d Max design whitout any problems after having been trying to install AUtocad 2014 for some time.
One thing I many have not mentioned is that I had a trial version of AutoCAD 2013 installed. I had uninstalled this so that I could install AutoCAD 2014. However after experiencing the problem in trying ot install AutpCAD 2014, I have the same problem when trying to install AutoCAD 2013 as well.
Hi nirav_98,
Please run Microsoft Fix-It and see if that enable the installation to go through.
Thank you.
Hi Aaron,
Thank you for your reponses so far, but i have not been successful as yet.
I have tried the microsoft fix it and I am still getting the same error.
See attached picture to give a bit more information.
Hi Nirav_98,
Looking into the crash report it seem that the calls to direct 3D (D3D11) from the hardware check is crashing and bringing the setup.exe to a halt. My guess is that this would be related to video card or video drivers. Have you confirmed you are running the latest available video driver from the card manufacturer?
Yes I can confirm I am running the latest drivers from the manufacturer.
The graphics card I am using is an ASUS AMD RADEON EAH6950 DCII/2DI4S/2GD5.
I am still lost as to why this is crashing.
Perhaps there is another video related driver on the system causing an issue. Can you check your programs and features control panel and see if there is a program listed called "displaylink core software"? It has been known to cause a conflict with autodesk installers and products. If you find it try removing it or updating it to the latest version from the displaylink website. http://www.displaylink.com/
Jeffry,
Thanks I tired re-installing the display driver again as for some reason the last time I did it it had not worked. I have re-installed the latest display driver and have managed to install AutoCAD 2014 finally.
Thank you very much for your help on this.
Hi Guys,
It was nice that someone here can fix the error when installing the software. I also have a problem installing the product. Can anyone help me fix this? Here's the error log.
I am now installing AutoCAD 2014 for maya 2014. I installed this version before, but unfortunately my computer was broken down. I would like to reinstall this version in my computer again for my student works use. It still keep on installed error. How I would do with the under installation log?
I am now urgent and looking up for the installation. Please keep a hand.
Thanks a lot.
Welcome to the Autodesk User's Community..
AutoCAD 2014 has been retired so there is no "live" download link. Where did you get the installer from? From your Autodesk Account?
If so change the method to browser download.
Mark Lancaster
& Autodesk Services MarketPlace Provider
temp folder method worked for me
i was facing problem when i open setup of AutoCAD 2014 at "Initialzing" it stops
so with this method of Temp folder i fixed my problem
please solve this error please help me and check this jgp. file
Hi @architect0309,
In short, you're missing the install file - you can download from https://manage.autodesk.com/ - if you already have the installer (.msi) downloaded you can navigate to the file by browse.
It's also worth noting that Windows 10 isn't listed in the System Requirements of AutoCAD 2014 which may lead to further issues down the road - I'm not saying it won't work but just a forewarning.
