I have been trying to install AutoCAD 2014. i keep getting these errors in this attachment. After having read a few others issues with install, I expect the support email I sent to be ignored as well. Can anyone here help?
CORRECTION: the title should have read "Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603"
Good afternoon Robert and welcome to the Autodesk Community!
I am sorry to see that you're having installation troubles, however the good news is that this is a pretty common error so there is quite a bit of troubleshooting material available.
Please see the following solutions to help resolve the issue:
I know it looks like a lot but let me know how it goes. If you have any questions please respond to this post.
Thank you!
Uninstall .NET Framework 4.0 Extended and Client Profile, then run the installation again. The installer will install the preferred version .NET Framework 4.0.
Hope this helps.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
