2012/4/20:12:16:38 Zakee Kazmee KAZMEE === Setup started on KAZMEE by Zakee Kazmee ===
2012/4/20:12:16:38 Zakee Kazmee KAZMEE Launch
2012/4/20:12:17:29 Zakee Kazmee KAZMEE === Setup ended ===
2012/4/20:12:16:39 Zakee Kazmee KAZMEE === Setup started on KAZMEE by Zakee Kazmee ===
2012/4/20:12:16:39 Zakee Kazmee KAZMEE Launch
2012/4/20:12:17:30 Zakee Kazmee KAZMEE PageOpen LaunchDialog
2012/4/20:12:17:42 Zakee Kazmee KAZMEE PageOpen LicenseDialog
2012/4/20:12:18:11 Zakee Kazmee KAZMEE PageOpen ProductInfoDialog
2012/4/20:12:18:17 Zakee Kazmee KAZMEE PageOpen ProductSelectionDialog2
2012/4/20:12:18:19 Zakee Kazmee KAZMEE PageOpen FullProgressDialog
2012/4/20:12:18:20 Zakee Kazmee KAZMEE Installing .NET Framework Runtime 2.0: E:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\x64\NET\2\NetFx20.exe /q:a /c:"install.exe /q"
2012/4/20:12:18:23 Zakee Kazmee KAZMEE Install .NET Framework Runtime 2.0 Failed Failure is ignored, Result=1603
2012/4/20:12:18:23 Zakee Kazmee KAZMEE Installing .NET Framework Runtime 4.0: E:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2012/4/20:12:18:47 Zakee Kazmee KAZMEE Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
Solved by Yong.Jing. Go to Solution.
Windows 8 is not a supported operating system for your products. You are welcome to try the product for testing, but you should not use it or activate it as a production machine.
Although not supported, I was able to install AutoCAD 2012 on Windows 8 Consumer Preview. My steps are listed here:
http://forums.autodesk.com/t5/CAD-Managers/Anyone-try-Windows-8-Developer-preview/m-p/3352895#M84974
You should not have any expectation for additional support getting this to work. I wish you luck.
At this time, Windows® 8 and the Windows® 8 Consumer Preview are not supported operating systems for any AutoCAD versions officially. The AutoCAD team is investigating compatibility with these new platforms, but we do not have any further information at this time.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19048377&linkID=9240617
