I´m not able to install Autocad LT 2010 in my new computer (runs on Windows 7 Proffesional).
When set up is starting from original DVD, an error message states "System could not open......\\SetupDesignReview2010.msi" and cancels installation process.
When trying to install directly from x64 folder ....\acadlt.exe, the process runs for a while but it stops suddenly and crash installation.... I send you a snapshot with this error.
I need assitance as maybe DVD is damaged (in that case, could you provide a copy?) or seems to be any incompatibility.
The license has been exported from my previous computer and is waiting to be imported as soos as I get the software installed in my new computer.
Thanks in advance
Santiago
Solved by pendean. Go to Solution.
