Hi, I've been trying to install the student software of inventor professional on my win 7 64 bit pc, which I accidentally unistalled. However, it says
"Error
Some installation files are corrupt
Please download a fresh copy and retry the installation"
I've tried like 4 times, downloading it at school twice and at home twice. Same thing every time. I got less CRC errors though when i deleted the autodesk folder in the APPDATA folder, on the C drive, and in the Program Files folder.
It looked like most of the errors were in the x64 folder in the autodesk folder on the C drive
Is there something that wasn't uninstalled correctly that I should delete?
Please Help!!
Notice the bar and how far it got.... so close!!!
...yet so far....
Thanks in advance!!
Solved by jessica.t. Go to Solution.
By the way, I have the whole log of the installation, one that has everything and one with only errors.
Ask me if you want them.
Problems downloading the Autodesk software and/or CRC errors may be avoided by using another web browser, or using the alternate browser download method.
For more detailed information on this process, please see the following blog post tip here:
http://upandready.typepad.com/up_and_ready/2011/08/downloading-software-browser-download-vs-download...
WOW!! that ALMOST worked!! but I still got 6 errors. 😞
CRC failed in x64\Inventor\Program Files\Autodesk\Inventor 2013\Bin\DynamicSimulation.dll
CRC failed in x64\Inventor\Program Files\Autodesk\Inventor 2013\Bin\HSCBLUTL10.dll
CRC failed in x64\Inventor\Program Files\Autodesk\Inventor 2013\Bin\LIBEAY32.DLL
CRC failed in x64\Components\DWGViewer\Program Files\DWG TrueView 2013\libfbxsdk-3_0.dll
CRC failed in Content\DCLibrary\DesktopContents\AI2013_Inventor ISO.idz
Now what? Is there a way to peice together a non corrupted version if I download it again and get different errors?
Well, I did do this with my antivirus off, every time. And what do you mean use winrar...use it in what way? Is there a way to peice together a full good download from multiple bad ones?
Possibly. The files are packed in such a way that WinRAR may be able to open the archive. It's just a thought.
Have you tried downloading from another computer?
YAAAAY!! I GOT IT!! I downloaded it for about the 7th time and it worked!! I also found that using 7zip, you can open it up and possibly peice together a non corrupted one, though I did not try.
I got a corrupteed file on the x64 folder. can you send me all the good ones from that one folder, thanks
AUTODESK is the WORST IN THE WORLD FOR ME
i tried a million times to download 3ds max in everyway and it just says NO
Hi @aspauladelin and welcome to the Autodesk Community!
Sorry for the issues but we'll get you up and running! Please take the following steps to get the best download performance:
If the problem persists please reply to this post with details on the download failure. Or please "Accept as a Solution" if this post resolves your issue so that others with this same question can more easily find an answer. Thanks!
