Installation & Licensing
Error in setup - Impossible to install
1 REPLY 1
199 Views, 1 Reply
I started the download then had a connectivity issue and the installer aborted.
Since then I cannot install Autocad anymore and as it reports it's already installed while is not.
I've even followed the instructions here: http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
but the issue remains.
Attached a document with all the screenshots and the error. How can I solve it?
1 REPLY 1
TravisNave
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-perform-a-clean-un...
Then...
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
Autodesk Forums:
Administrator Productivity
