I am the administrator to my laptop and when i initiate the install process on Autcat Lt 14, I get the following error message:
"The system cannot open the device or file specified. C:\users\arosales\AppData\Local\Temp\_AICS558.tmp\x64\acadlt\acadlt.msi"
When i click 'Close', the install stops and closes itself.
I can open the temp file listed above, I also checked to make sure I have rull rights to that folder.
I just downloaded this software and need to use it ASAP...please help!!!!
It's also failing here:
Install AutoCAD LT® 2014 Language Pack Failed Installation aborted, Result=1603
MSI failure issues are generally caused by your anti-virus running.
When installing, you should always ensure that you have local admin rights, UAC is off, and anti-virus is disabled. Do that and try again.
