I have encountered an error message when I attempt to install the RA2013 UR1.
"Aproblem prevented the Update Release from being installed. Contact your system administrator. Error Code: 1601"
I have searched high and low for solution but nothing has worked as yet....
HELP!!
You might trying to install the wrong update. There are two of them. One for Revit Architecture 2013, and one for Revit Building Design Suite 2013.
This one is for Revit Building Design Suite 2013.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20121968&linkID=16831210
This one is for Revit Architecture 2013.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20121970&linkID=9273944
Be adviced, this updates might take a long time to install, so be pacient.
