Installation & Licensing
Error during installation Civil 3D 2013
5 REPLIES 5
724 Views, 5 Replies
There is an error occuring during installation which it is :
.NET Framework Runtime 4.0 KB2468871 Failed Failure is ignored, Result=1619
 Rollback .NET Framework Runtime 4.0 Failed Failure is ignored, Result=1619
and i remove net.framework 4.0 from control panel but the problem still.
I hope that any one help me to go beyond the problem.
2013/3/19:20:55:40 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:20:55:40 Motasem MOTASEM-HP Launch
2013/3/19:20:55:56 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:20:55:48 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:20:55:48 Motasem MOTASEM-HP Launch
2013/3/19:20:55:56 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/19:20:56:02 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/19:20:56:07 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/19:20:56:26 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/19:20:56:33 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/19:20:56:33 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/3/19:21:00:02 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Succeeded
2013/3/19:21:00:02 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/19:21:00:02 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/19:21:00:02 Motasem MOTASEM-HP Rollback .NET Framework Runtime 4.0 Failed Failure is ignored, Result=1619
2013/3/19:21:00:17 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/19:21:06:36 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:21:16:06 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:21:16:06 Motasem MOTASEM-HP Launch
2013/3/19:21:17:33 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:21:16:57 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:21:16:57 Motasem MOTASEM-HP Launch
2013/3/19:21:17:33 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/19:21:19:39 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/19:21:19:42 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/19:21:20:02 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/19:21:20:22 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/19:21:20:22 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 KB2468871: H:\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2013/3/19:21:25:44 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 KB2468871 Succeeded
2013/3/19:21:25:44 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AIA6B9.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/19:21:26:13 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Failed Failure is ignored, Result=1603
2013/3/19:21:26:13 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/19:21:26:13 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/19:21:26:13 Motasem MOTASEM-HP Rollback .NET Framework Runtime 4.0 KB2468871 Failed Failure is ignored, Result=1619
2013/3/19:21:26:31 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/19:21:29:16 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:21:54:08 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:21:54:08 Motasem MOTASEM-HP Launch
2013/3/19:21:54:19 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:21:54:14 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:21:54:14 Motasem MOTASEM-HP Launch
2013/3/19:21:54:19 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/19:21:54:35 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/19:21:54:35 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/19:21:54:54 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/19:21:54:55 Motasem MOTASEM-HP Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AIBB82.tmp\Media.mst"
2013/3/19:21:54:58 Motasem MOTASEM-HP Install Network License Manager Succeeded
2013/3/19:21:54:58 Motasem MOTASEM-HP Installing Autodesk CAD Manager Tools: INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AIBB82.tmp\Media.mst"
2013/3/19:21:55:17 Motasem MOTASEM-HP Install Autodesk CAD Manager Tools Succeeded
2013/3/19:21:55:17 Motasem MOTASEM-HP Installing Autodesk Content Service: TRANSFORMS="H:\x64\en-us\Tools\snap\ContentService.mst;C:\Users\Motasem\AppData\Local\Temp\_AIBB82.tmp\x64\Tools\snap\ContentService-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/19:21:55:44 Motasem MOTASEM-HP Install Autodesk Content Service Succeeded
2013/3/19:21:55:44 Motasem MOTASEM-HP Installing Autodesk Content Service Language Pack: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AIBB82.tmp\_la3046.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/19:21:55:52 Motasem MOTASEM-HP Install Autodesk Content Service Language Pack Succeeded
2013/3/19:21:55:52 Motasem MOTASEM-HP Installing Civil 3D 2013 32 bit Object Enabler: H:\x86\support\ObjectEnabler\Civil3D_2013_OE_32Bit.exe
2013/3/19:21:59:41 Motasem MOTASEM-HP Install Civil 3D 2013 32 bit Object Enabler Succeeded
2013/3/19:21:59:42 Motasem MOTASEM-HP Installing Civil 3D 2013 64 bit Object Enabler: H:\x64\support\ObjectEnabler\Civil3D_2013_OE_64Bit.exe
2013/3/19:22:00:29 Motasem MOTASEM-HP Install Civil 3D 2013 64 bit Object Enabler Succeeded
2013/3/19:22:00:31 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/19:22:00:39 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:22:01:53 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:22:01:53 Motasem MOTASEM-HP Launch
2013/3/19:22:02:04 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:22:02:25 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:22:02:25 Motasem MOTASEM-HP Launch
2013/3/19:22:02:25 Motasem MOTASEM-HP An instance of setup is already running. Only one instance of setup can run at a time.2013/3/19:22:02:26 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:22:01:59 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:22:01:59 Motasem MOTASEM-HP Launch
2013/3/19:22:02:03 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/19:22:02:10 Motasem MOTASEM-HP PageOpen BeginDeploymentDialog
2013/3/19:22:02:18 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/19:22:02:34 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/19:22:02:46 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/19:22:02:50 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/19:22:02:59 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/19:22:03:00 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AID3E2.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/19:22:04:19 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Succeeded
2013/3/19:22:04:19 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/19:22:04:19 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/19:22:04:33 Motasem MOTASEM-HP Rollback Autodesk® Design Review 2013 Succeeded
2013/3/19:22:04:34 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/19:22:06:35 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:22:10:27 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:22:10:27 Motasem MOTASEM-HP Launch
2013/3/19:22:10:37 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:22:10:31 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:22:10:31 Motasem MOTASEM-HP Launch
2013/3/19:22:10:37 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/19:22:10:41 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/19:22:10:43 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/19:22:11:03 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/19:22:11:16 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/19:22:11:17 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AIA89E.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/19:22:11:56 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Succeeded
2013/3/19:22:11:56 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/19:22:11:56 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/19:22:12:09 Motasem MOTASEM-HP Rollback Autodesk® Design Review 2013 Succeeded
2013/3/19:22:12:10 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/19:22:12:20 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:22:12:25 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:22:12:25 Motasem MOTASEM-HP Launch
2013/3/19:22:12:30 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:22:12:28 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:22:12:28 Motasem MOTASEM-HP Launch
2013/3/19:22:12:30 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/19:22:12:31 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/19:22:12:34 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/19:22:12:44 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/19:22:13:02 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/19:22:13:03 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AI7677.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/19:22:13:34 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Succeeded
2013/3/19:22:13:34 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/19:22:13:34 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/19:22:13:45 Motasem MOTASEM-HP Rollback Autodesk® Design Review 2013 Succeeded
2013/3/19:22:13:45 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/19:22:17:17 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:22:17:26 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:22:17:26 Motasem MOTASEM-HP Launch
2013/3/19:22:17:36 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:22:17:31 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:22:17:31 Motasem MOTASEM-HP Launch
2013/3/19:22:17:36 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/19:22:17:39 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/19:22:17:41 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/19:22:17:57 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/19:22:18:05 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/19:22:18:05 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/19:22:18:05 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/19:22:18:08 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/19:22:23:27 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:22:29:37 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:22:29:37 Motasem MOTASEM-HP Launch
2013/3/19:22:30:45 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:22:30:02 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:22:30:02 Motasem MOTASEM-HP Launch
2013/3/19:22:30:45 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/19:22:30:48 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/19:22:30:51 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/19:22:31:18 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/19:22:31:24 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/19:22:31:25 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AI24CE.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/19:22:32:00 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Succeeded
2013/3/19:22:32:00 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/19:22:32:00 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/19:22:32:08 Motasem MOTASEM-HP Rollback Autodesk® Design Review 2013 Succeeded
2013/3/19:22:32:16 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/19:22:40:50 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:23:14:50 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:23:14:50 Motasem MOTASEM-HP Launch
2013/3/19:23:14:50 Motasem MOTASEM-HP An instance of setup is already running. Only one instance of setup can run at a time.2013/3/19:23:14:52 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:23:14:43 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:23:14:43 Motasem MOTASEM-HP Launch
2013/3/19:23:15:39 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:23:15:04 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:23:15:04 Motasem MOTASEM-HP Launch
2013/3/19:23:15:04 Motasem MOTASEM-HP [Error: 1052] The requested control is not valid for this service.
2013/3/19:23:15:39 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/19:23:15:48 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/19:23:15:51 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/19:23:16:10 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/19:23:16:17 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/19:23:16:17 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AIDFA4.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/19:23:17:31 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Succeeded
2013/3/19:23:17:31 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/19:23:17:31 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/19:23:17:48 Motasem MOTASEM-HP Rollback Autodesk® Design Review 2013 Succeeded
2013/3/19:23:18:02 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/19:23:20:11 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:23:54:53 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:23:54:53 Motasem MOTASEM-HP Launch
2013/3/19:23:56:21 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:23:55:53 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:23:55:53 Motasem MOTASEM-HP Launch
2013/3/19:23:56:21 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/19:23:56:28 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/19:23:56:30 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/19:23:57:02 Motasem MOTASEM-HP PageOpen BeginDeploymentDialog
2013/3/19:23:58:17 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/19:23:58:30 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/19:23:58:30 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/19:23:58:52 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/19:23:58:52 Motasem MOTASEM-HP Installing Civil 3D 2013 32 bit Object Enabler: H:\x86\support\ObjectEnabler\Civil3D_2013_OE_32Bit.exe
2013/3/20:00:05:51 Motasem MOTASEM-HP Install Civil 3D 2013 32 bit Object Enabler Succeeded
2013/3/20:00:05:56 Motasem MOTASEM-HP Installing Civil 3D 2013 64 bit Object Enabler: H:\x64\support\ObjectEnabler\Civil3D_2013_OE_64Bit.exe
2013/3/20:00:07:34 Motasem MOTASEM-HP Install Civil 3D 2013 64 bit Object Enabler Succeeded
2013/3/20:00:07:35 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/20:00:07:40 Motasem MOTASEM-HP === Setup ended ===
2013/3/19:23:56:53 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/19:23:56:53 Motasem MOTASEM-HP Launch
2013/3/19:23:56:53 Motasem MOTASEM-HP An instance of setup is already running. Only one instance of setup can run at a time.2013/3/20:00:07:44 Motasem MOTASEM-HP === Setup ended ===
2013/3/20:00:11:03 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/20:00:11:03 Motasem MOTASEM-HP Launch
2013/3/20:00:11:18 Motasem MOTASEM-HP === Setup ended ===
2013/3/20:00:11:12 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/20:00:11:12 Motasem MOTASEM-HP Launch
2013/3/20:00:11:18 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/20:00:11:25 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/20:00:11:33 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/20:00:12:47 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/20:00:15:41 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/20:00:15:42 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AI7FE9.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/20:00:16:39 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Succeeded
2013/3/20:00:16:39 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/20:00:16:39 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/20:00:16:54 Motasem MOTASEM-HP Rollback Autodesk® Design Review 2013 Succeeded
2013/3/20:00:17:00 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/20:00:18:04 Motasem MOTASEM-HP === Setup ended ===
2013/3/20:22:05:45 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/20:22:05:45 Motasem MOTASEM-HP Launch
2013/3/20:22:06:19 Motasem MOTASEM-HP === Setup ended ===
2013/3/20:22:06:39 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/20:22:06:39 Motasem MOTASEM-HP Launch
2013/3/20:22:06:39 Motasem MOTASEM-HP An instance of setup is already running. Only one instance of setup can run at a time.2013/3/20:22:06:41 Motasem MOTASEM-HP === Setup ended ===
2013/3/20:22:05:58 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/20:22:05:58 Motasem MOTASEM-HP Launch
2013/3/20:22:06:19 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/20:22:06:22 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/20:22:06:30 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/20:22:06:49 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/20:22:06:52 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/20:22:06:59 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/20:22:07:10 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/20:22:07:11 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AI88CE.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/20:22:08:13 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Succeeded
2013/3/20:22:08:13 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/20:22:08:13 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/20:22:08:22 Motasem MOTASEM-HP Rollback Autodesk® Design Review 2013 Succeeded
2013/3/20:22:08:30 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/20:22:27:24 Motasem MOTASEM-HP === Setup ended ===
2013/3/20:22:33:10 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/20:22:33:10 Motasem MOTASEM-HP Launch
2013/3/20:22:34:12 Motasem MOTASEM-HP === Setup ended ===
2013/3/20:22:33:53 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/20:22:33:53 Motasem MOTASEM-HP Launch
2013/3/20:22:33:53 Motasem MOTASEM-HP [Error: 1052] The requested control is not valid for this service.
2013/3/20:22:34:12 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/20:22:34:25 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/20:22:34:25 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/20:22:34:35 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/20:22:34:35 Motasem MOTASEM-HP Installing Civil 3D 2013 32 bit Object Enabler: H:\x86\support\ObjectEnabler\Civil3D_2013_OE_32Bit.exe
2013/3/20:22:35:03 Motasem MOTASEM-HP Install Civil 3D 2013 32 bit Object Enabler Succeeded
2013/3/20:22:35:03 Motasem MOTASEM-HP Installing Civil 3D 2013 64 bit Object Enabler: H:\x64\support\ObjectEnabler\Civil3D_2013_OE_64Bit.exe
2013/3/20:22:35:18 Motasem MOTASEM-HP Install Civil 3D 2013 64 bit Object Enabler Succeeded
2013/3/20:22:35:18 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/20:22:35:23 Motasem MOTASEM-HP === Setup ended ===
2013/3/20:22:35:55 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/20:22:35:55 Motasem MOTASEM-HP Launch
2013/3/20:22:36:03 Motasem MOTASEM-HP === Setup ended ===
2013/3/20:22:35:59 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/20:22:35:59 Motasem MOTASEM-HP Launch
2013/3/20:22:36:03 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/20:22:36:05 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/20:22:36:09 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/20:22:36:39 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/20:22:36:47 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/20:22:36:47 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/3/20:22:39:10 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Succeeded
2013/3/20:22:39:10 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 KB2468871: H:\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2013/3/20:22:43:42 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 KB2468871 Succeeded
2013/3/20:22:43:42 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AIBBCF.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/20:22:44:29 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Succeeded
2013/3/20:22:44:29 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/20:22:44:29 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/20:22:44:40 Motasem MOTASEM-HP Rollback Autodesk® Design Review 2013 Succeeded
2013/3/20:22:44:41 Motasem MOTASEM-HP Rollback .NET Framework Runtime 4.0 KB2468871 Failed Failure is ignored, Result=1619
2013/3/20:22:44:41 Motasem MOTASEM-HP Rollback .NET Framework Runtime 4.0 Failed Failure is ignored, Result=1619
2013/3/20:22:44:49 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/20:22:46:40 Motasem MOTASEM-HP === Setup ended ===
2013/3/20:22:57:43 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/20:22:57:43 Motasem MOTASEM-HP Launch
2013/3/20:22:58:39 Motasem MOTASEM-HP === Setup ended ===
2013/3/20:22:58:05 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/20:22:58:05 Motasem MOTASEM-HP Launch
2013/3/20:22:58:39 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/20:22:58:42 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/20:22:58:45 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/20:22:59:07 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/20:22:59:19 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/20:22:59:19 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/3/20:23:05:26 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Succeeded
2013/3/20:23:05:26 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 KB2468871: H:\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2013/3/20:23:10:50 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 KB2468871 Succeeded
2013/3/20:23:10:50 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AI1FDE.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/20:23:12:13 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Succeeded
2013/3/20:23:12:13 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/20:23:12:13 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/20:23:12:27 Motasem MOTASEM-HP Rollback Autodesk® Design Review 2013 Succeeded
2013/3/20:23:12:27 Motasem MOTASEM-HP Rollback .NET Framework Runtime 4.0 KB2468871 Failed Failure is ignored, Result=1619
2013/3/20:23:12:27 Motasem MOTASEM-HP Rollback .NET Framework Runtime 4.0 Failed Failure is ignored, Result=1619
2013/3/20:23:12:41 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/20:23:44:18 Motasem MOTASEM-HP === Setup ended ===
2013/3/20:23:44:46 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/20:23:44:46 Motasem MOTASEM-HP Launch
2013/3/20:23:45:42 Motasem MOTASEM-HP === Setup ended ===
2013/3/20:23:45:26 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/20:23:45:26 Motasem MOTASEM-HP Launch
2013/3/20:23:45:42 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/20:23:48:16 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/20:23:48:19 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/20:23:48:44 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/20:23:49:14 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/20:23:49:14 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AI28D5.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/20:23:49:44 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Succeeded
2013/3/20:23:49:44 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/20:23:49:44 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/20:23:49:52 Motasem MOTASEM-HP Rollback Autodesk® Design Review 2013 Succeeded
2013/3/20:23:50:04 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/20:23:50:41 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:06:06:16 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:06:06:16 Motasem MOTASEM-HP Launch
2013/3/21:06:06:16 Motasem MOTASEM-HP An instance of setup is already running. Only one instance of setup can run at a time.2013/3/21:06:06:18 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:06:05:58 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:06:05:58 Motasem MOTASEM-HP Launch
2013/3/21:06:06:41 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:06:06:41 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/21:06:06:44 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/21:06:06:46 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/21:06:07:00 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/21:06:07:05 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/21:06:07:06 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AIFDBE.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/21:06:08:05 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Succeeded
2013/3/21:06:08:05 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/21:06:08:05 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/21:06:08:16 Motasem MOTASEM-HP Rollback Autodesk® Design Review 2013 Succeeded
2013/3/21:06:08:26 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/21:06:08:38 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:06:26:22 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:06:26:22 Motasem MOTASEM-HP Launch
2013/3/21:06:27:19 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:06:27:02 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:06:27:02 Motasem MOTASEM-HP Launch
2013/3/21:06:27:02 Motasem MOTASEM-HP [Error: 1052] The requested control is not valid for this service.
2013/3/21:06:27:20 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/21:06:27:30 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/21:06:27:33 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/21:06:27:53 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/21:06:27:59 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/21:06:27:59 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/3/21:06:33:34 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Succeeded
2013/3/21:06:33:34 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 KB2468871: H:\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2013/3/21:06:38:45 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 KB2468871 Succeeded
2013/3/21:06:38:45 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AIFF44.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/21:06:39:42 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Succeeded
2013/3/21:06:39:42 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/21:06:39:42 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/21:06:39:49 Motasem MOTASEM-HP Rollback Autodesk® Design Review 2013 Succeeded
2013/3/21:06:39:49 Motasem MOTASEM-HP Rollback .NET Framework Runtime 4.0 KB2468871 Failed Failure is ignored, Result=1619
2013/3/21:06:39:49 Motasem MOTASEM-HP Rollback .NET Framework Runtime 4.0 Failed Failure is ignored, Result=1619
2013/3/21:06:40:09 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/21:06:41:15 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:08:30:03 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:08:30:03 Motasem MOTASEM-HP Launch
2013/3/21:08:30:26 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:08:30:11 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:08:30:11 Motasem MOTASEM-HP Launch
2013/3/21:08:30:26 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/21:08:30:32 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/21:08:30:39 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/21:08:30:56 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/21:08:31:05 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/21:08:31:05 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AI5FBB.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/21:08:32:18 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Succeeded
2013/3/21:08:32:19 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/21:08:32:19 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/21:08:32:33 Motasem MOTASEM-HP Rollback Autodesk® Design Review 2013 Succeeded
2013/3/21:08:32:43 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/21:08:32:48 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:08:33:21 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:08:33:21 Motasem MOTASEM-HP Launch
2013/3/21:08:33:37 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:08:33:30 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:08:33:30 Motasem MOTASEM-HP Launch
2013/3/21:08:33:37 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/21:08:33:42 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/21:08:33:46 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/21:08:33:56 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/21:08:34:04 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/21:08:34:05 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AI6AB3.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/21:08:34:52 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Succeeded
2013/3/21:08:34:52 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/21:08:34:52 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/21:08:35:09 Motasem MOTASEM-HP Rollback Autodesk® Design Review 2013 Succeeded
2013/3/21:08:35:11 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/21:08:35:40 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:08:49:15 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:08:49:15 Motasem MOTASEM-HP Launch
2013/3/21:08:50:03 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:08:49:31 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:08:49:31 Motasem MOTASEM-HP Launch
2013/3/21:08:49:31 Motasem MOTASEM-HP [Error: 1052] The requested control is not valid for this service.
2013/3/21:08:50:04 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/21:08:50:10 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/21:08:50:19 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/21:08:50:36 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/21:08:50:43 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/21:08:50:43 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/3/21:08:55:50 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Succeeded
2013/3/21:08:55:50 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 KB2468871: H:\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2013/3/21:09:02:57 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 KB2468871 Succeeded
2013/3/21:09:02:57 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AI425C.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/21:09:03:58 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Succeeded
2013/3/21:09:03:58 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/21:09:03:58 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/21:09:04:15 Motasem MOTASEM-HP Rollback Autodesk® Design Review 2013 Succeeded
2013/3/21:09:04:15 Motasem MOTASEM-HP Rollback .NET Framework Runtime 4.0 KB2468871 Failed Failure is ignored, Result=1619
2013/3/21:09:04:16 Motasem MOTASEM-HP Rollback .NET Framework Runtime 4.0 Failed Failure is ignored, Result=1619
2013/3/21:09:04:31 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/21:12:11:25 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:12:15:16 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:12:15:16 Motasem MOTASEM-HP Launch
2013/3/21:12:15:39 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:12:15:23 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:12:15:23 Motasem MOTASEM-HP Launch
2013/3/21:12:15:39 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/21:12:15:41 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/21:12:15:43 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/21:12:15:57 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/21:12:16:04 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/21:12:16:04 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AIE90A.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/21:12:16:42 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Succeeded
2013/3/21:12:16:42 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/21:12:16:42 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/21:12:16:55 Motasem MOTASEM-HP Rollback Autodesk® Design Review 2013 Succeeded
2013/3/21:12:17:04 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/21:12:17:22 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:12:29:07 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:12:29:07 Motasem MOTASEM-HP Launch
2013/3/21:12:30:05 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:12:29:44 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:12:29:44 Motasem MOTASEM-HP Launch
2013/3/21:12:30:06 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/21:12:30:08 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/21:12:30:10 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/21:12:30:32 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/21:12:30:39 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/21:12:30:39 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/3/21:13:01:23 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Succeeded
2013/3/21:13:01:23 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 KB2468871: H:\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2013/3/21:13:08:11 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 KB2468871 Succeeded
2013/3/21:13:08:11 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AIA7B.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/21:13:09:09 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Succeeded
2013/3/21:13:09:09 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/21:13:09:09 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/21:13:09:20 Motasem MOTASEM-HP Rollback Autodesk® Design Review 2013 Succeeded
2013/3/21:13:09:20 Motasem MOTASEM-HP Rollback .NET Framework Runtime 4.0 KB2468871 Failed Failure is ignored, Result=1619
2013/3/21:13:09:20 Motasem MOTASEM-HP Rollback .NET Framework Runtime 4.0 Failed Failure is ignored, Result=1619
2013/3/21:13:09:37 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/21:13:10:01 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:13:32:49 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:13:32:49 Motasem MOTASEM-HP Launch
2013/3/21:13:33:13 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:13:32:56 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:13:32:56 Motasem MOTASEM-HP Launch
2013/3/21:13:33:13 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/21:13:33:15 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/21:13:33:18 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/21:13:33:33 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/21:13:33:38 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/21:13:33:38 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AI6191.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/21:13:34:16 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Succeeded
2013/3/21:13:34:16 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/21:13:34:16 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/21:13:34:28 Motasem MOTASEM-HP Rollback Autodesk® Design Review 2013 Succeeded
2013/3/21:13:34:30 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/21:13:37:23 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:13:40:27 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:13:40:27 Motasem MOTASEM-HP Launch
2013/3/21:13:40:40 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:13:40:35 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:13:40:35 Motasem MOTASEM-HP Launch
2013/3/21:13:40:40 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/21:13:40:58 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/21:13:40:58 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/21:13:41:05 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/21:13:41:05 Motasem MOTASEM-HP Installing Civil 3D 2013 32 bit Object Enabler: H:\x86\support\ObjectEnabler\Civil3D_2013_OE_32Bit.exe
2013/3/21:13:41:32 Motasem MOTASEM-HP Install Civil 3D 2013 32 bit Object Enabler Succeeded
2013/3/21:13:41:32 Motasem MOTASEM-HP Installing Civil 3D 2013 64 bit Object Enabler: H:\x64\support\ObjectEnabler\Civil3D_2013_OE_64Bit.exe
2013/3/21:13:41:59 Motasem MOTASEM-HP Install Civil 3D 2013 64 bit Object Enabler Succeeded
2013/3/21:13:41:59 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/21:13:42:01 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:13:42:08 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:13:42:08 Motasem MOTASEM-HP Launch
2013/3/21:13:42:15 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:13:42:12 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:13:42:12 Motasem MOTASEM-HP Launch
2013/3/21:13:42:15 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/21:13:42:16 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/21:13:42:19 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/21:13:42:30 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/21:13:42:34 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/21:13:42:34 Motasem MOTASEM-HP Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): H:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\Motasem\AppData\Local\Temp\vcredist_x86_2010.log
2013/3/21:13:42:55 Motasem MOTASEM-HP Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/3/21:13:42:55 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AIEE55.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/21:13:43:44 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Succeeded
2013/3/21:13:43:44 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/21:13:43:44 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/21:13:44:00 Motasem MOTASEM-HP Rollback Autodesk® Design Review 2013 Succeeded
2013/3/21:13:44:01 Motasem MOTASEM-HP Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Failure is ignored, Result=1619
2013/3/21:13:44:02 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/21:13:44:35 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:13:45:28 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:13:45:28 Motasem MOTASEM-HP Launch
2013/3/21:13:45:40 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:13:45:33 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:13:45:33 Motasem MOTASEM-HP Launch
2013/3/21:13:45:40 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/21:13:45:42 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/21:13:45:44 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/21:13:45:59 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/21:13:46:06 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/21:13:46:06 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/21:13:46:06 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/21:13:46:07 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/21:13:46:52 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:19:47:09 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:19:47:09 Motasem MOTASEM-HP Launch
2013/3/21:19:48:01 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:19:47:46 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:19:47:46 Motasem MOTASEM-HP Launch
2013/3/21:19:47:46 Motasem MOTASEM-HP [Error: 1052] The requested control is not valid for this service.
2013/3/21:19:48:02 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/21:19:48:04 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/21:19:48:07 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/21:19:48:26 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/21:19:48:33 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/21:19:48:33 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AI65A5.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/21:19:50:37 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Succeeded
2013/3/21:19:50:37 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/21:19:50:37 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/21:19:50:56 Motasem MOTASEM-HP Rollback Autodesk® Design Review 2013 Succeeded
2013/3/21:19:51:18 Motasem MOTASEM-HP PageOpen InstallCompleteDialog
2013/3/21:19:51:52 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:20:05:26 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:20:05:26 Motasem MOTASEM-HP Launch
2013/3/21:20:06:11 Motasem MOTASEM-HP === Setup ended ===
2013/3/21:20:05:39 Motasem MOTASEM-HP === Setup started on MOTASEM-HP by Motasem ===
2013/3/21:20:05:39 Motasem MOTASEM-HP Launch
2013/3/21:20:05:39 Motasem MOTASEM-HP [Error: 1052] The requested control is not valid for this service.
2013/3/21:20:06:11 Motasem MOTASEM-HP PageOpen LaunchDialog
2013/3/21:20:06:17 Motasem MOTASEM-HP PageOpen LicenseDialog
2013/3/21:20:06:20 Motasem MOTASEM-HP PageOpen ProductInfoDialog
2013/3/21:20:06:53 Motasem MOTASEM-HP PageOpen ProductSelectionDialog2
2013/3/21:20:07:05 Motasem MOTASEM-HP PageOpen FullProgressDialog
2013/3/21:20:07:05 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/3/21:20:14:39 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Succeeded
2013/3/21:20:14:39 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 KB2468871: H:\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2013/3/21:20:21:32 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 KB2468871 Succeeded
2013/3/21:20:21:32 Motasem MOTASEM-HP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\Motasem\AppData\Local\Temp\_AIB55.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/21:20:22:42 Motasem MOTASEM-HP Install Autodesk® Design Review 2013 Succeeded
2013/3/21:20:22:42 Motasem MOTASEM-HP Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1025.exe /q
2013/3/21:20:22:42 Motasem MOTASEM-HP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/21:20:22:56 Motasem MOTASEM-HP Rollback Autodesk® Design Review 2013 Succeeded
2013/3/21:20:22:56 Motasem MOTASEM-HP Rollback .NET Framework Runtime 4.0 KB2468871 Failed Failure is ignored, Result=1619
2013/3/21:20:22:56 Motasem MOTASEM-HP Rollback .NET Framework Runtime 4.0 Failed Failure is ignored, Result=1619
5 REPLIES 5
tcorey
Some possibilities:
1. Be sure you are logged in as Administrator.
2. Turn off User Account Control
3. Turn off Virus Scanners
4. Before the install, delete contents of %temp%. (In the Windows Explorer address bar, just type %temp% and hit enter. It will take you to the folder.)
If none of those ideas help, and no one else on this forum pipes in, you might consider posting to the Installation and Setup group.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
michael.robertson
What version of Windows are you trying to install on? This is a common message on Win8 which is not supported.
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
TravisNave
Your failure actually exists here:
You might try installing it manually, then if it still fails, you might have to edit the setup.ini file to remove the prerequisite check.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Autodesk Forums:
in reply to: TravisNave
I use Net.framework cleanup and Net.framework4.0 removed from my system,then i install Civil 3d again,and it is automaticly download Net.framework4.0 , during intstallation i see same previouse message and the installation stop.
TravisNave
See my link above for instructions on how to edit the setup.ini to skip the prerequisite check for .NET.
Autodesk Forums:
Administrator Productivity
