Installation & Licensing
New Member
dbottomley
Message 1 of 12 (2,080 Views)
Error Code -5.412.0
2080 Views, 11 Replies
12-04-2010 09:01 AM
I have 45 students running Inventor 2011. They have all been able to get their license from the license server when booting Inventor with no problems until yesterday. One student cannot launch Inventor on her computer - the error code and message " Error -5.412.0  A valid license could not be obtained by the network license manager" shows up every time.
Actions to date:
Reboot her computer - same
Reboot the license server - same
Had her log on and run Inventor from several other computers in the lab - She CAN do this. It is only on her assigned computer that she gets the error message.
Logging in as administrator, I CAN launch Inventor on her assigned computer.
Other students CAN launch Inventor for her computer.
Only she gets the error message on her assigned computer.
Any help greatly appreciated.
Windows XP
Autodesk Design Academy 2011
Thank You
David Bottomley
Southwestern HS
Hanover, IN
Product Support
hashim.mundol
Message 2 of 12 (2,052 Views)
Re: Error Code -5.412.0
12-06-2010 02:24 AM in reply to: dbottomley
Please try to delete the file cascadeinfo,cas
http://usa.autodesk.com/getdoc/id=TS13894457
if this doesnt help, please try check antivirus/firewall etc.. locally. also if there is ipv6 enabled locally, please try to disable it.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Distinguished Contributor
bjorn_fallqvist
Message 3 of 12 (1,751 Views)
01-31-2011 03:35 AM in reply to: hashim.mundol
I'm a bit late, but I'm having the same problem, and deleting the .cas file does not help. I've tried turning the firewall on and off, but it doesn't seem to help. The license file shows up correctly in lmgtools, and Autodesk Algor works fine but I can't get Inventor Professional to acquire a license.
Any suggestions?
Product Support
hashim.mundol
Message 4 of 12 (1,743 Views)
01-31-2011 04:15 AM in reply to: bjorn_fallqvist
Did it work before ?
usually this error means this particular feature license is not available on the server
you can get verbose log to figure out the request from client
http://usa.autodesk.com/getdoc/id=TS1065188
Hashim Mundol
bjorn_fallqvist
Message 5 of 12 (1,741 Views)
01-31-2011 04:21 AM in reply to: hashim.mundol
Yes, it did. All I did was to install lmtools on another workstation, generate a new license file and re-install the product here instead.
I'll try this.
bjorn_fallqvist
Message 6 of 12 (1,739 Views)
01-31-2011 04:25 AM in reply to: bjorn_fallqvist
What it says is this:
"Flexnet licensing error: License server system does not support this feature.
Feature [featurename]
Flexnet licensing error: 18,147"
When I close it, another one appears with a new feature name, all associated with Inventor Professional.
Product Support
hashim.mundol
Message 7 of 12 (1,737 Views)
01-31-2011 04:27 AM in reply to: bjorn_fallqvist
Please check your license file here to verify those feature codes, coming up in the error
if you dont have it, please get a new one.
http://licenseparser.com/
you could also see it in License server status (might not look as nice as the link above)
Hashim Mundol
bjorn_fallqvist
Message 8 of 12 (1,734 Views)
01-31-2011 04:37 AM in reply to: hashim.mundol
Ok, this is what it says:
4Subscription Package: Autodesk Algor Simulation Professional85526ASPRO_F 31-Jan-2011permanent
 Autodesk Algor Simulation Professional 201185593ASPRO_2011_0F
85508ASPRO_2010_0F
1Subscription Package: Autodesk Algor Simulation MES85525ASMES_F
 Autodesk Algor Simulation MES 201185592ASMES_2011_0F
85507ASMES_2010_0F
6Subscription Package: Inventor Professional64800INVPRO_F
 AutoCAD Inventor Professional Suite 201185567INVPRO_2011_0F
 AutoCAD Inventor Professional Suite 201070500INVPRO_2010_0F
 Autodesk Inventor Professional 200959600INVPRO_2009_0F
 Inventor Professional 200855300INVPRO_2008_0F
It seems that Inventor decided to startk working, but I still get an error message for "85573INVBUN", "85635FSDPRM_20110_F", "85569INVPRO_2011_0F", "85571INVPROSIM_2011_0F", "85575INVMFG_2011_0F" when starting it.
Product Support
hashim.mundol
Message 9 of 12 (1,732 Views)
01-31-2011 04:40 AM in reply to: bjorn_fallqvist
if you remove the diagnostics variable, errors should go away; its just showing the cascading order.
Did you do anything to fix the issue ?
Hashim Mundol
bjorn_fallqvist
Message 10 of 12 (1,713 Views)
01-31-2011 08:17 AM in reply to: dbottomley
I regenerated the license file. This time, I just pasted the entire text information that I was given into the .lic file instead of only appending the INCREMENT sections (it said to do so on the site). For some reason, this helped.
Thanks.
