Please provide us the "install.log" file generated after the installation attempt under %tmp%.
2013/9/13:17:45:38 USER USER-PC === Setup started on USER-PC by USER ===
2013/9/13:17:45:38 USER USER-PC Launch
2013/9/13:17:45:44 USER USER-PC === Setup ended ===
2013/9/13:17:45:40 USER USER-PC === Setup started on USER-PC by USER ===
2013/9/13:17:45:40 USER USER-PC Launch
2013/9/13:17:45:44 USER USER-PC PageOpen LaunchDialog
2013/9/13:17:45:48 USER USER-PC PageOpen LicenseDialog
2013/9/13:17:45:57 USER USER-PC PageOpen ProductInfoDialog
2013/9/13:17:47:22 USER USER-PC PageOpen ProductSelectionDialog2
2013/9/13:17:47:29 USER USER-PC PageOpen FullProgressDialog
2013/9/13:17:47:29 USER USER-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\Maya_2013_CEJ_Win_64-bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/9/13:17:47:33 USER USER-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/9/13:17:47:35 USER USER-PC PageOpen InstallCompleteDialog
2013/9/13:17:47:48 USER USER-PC === Setup ended ===
2013/9/13:17:51:13 USER USER-PC === Setup started on USER-PC by USER ===
2013/9/13:17:51:13 USER USER-PC Launch
2013/9/13:17:51:17 USER USER-PC === Setup ended ===
2013/9/13:17:51:17 USER USER-PC PageOpen LaunchDialog
2013/9/13:17:51:45 USER USER-PC PageOpen LicenseDialog
2013/9/13:17:51:53 USER USER-PC PageOpen ProductInfoDialog
2013/9/13:17:53:23 USER USER-PC PageOpen ProductSelectionDialog2
2013/9/13:17:53:57 USER USER-PC PageOpen FullProgressDialog
2013/9/13:17:53:57 USER USER-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\Maya_2013_CEJ_Win_64-bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/9/13:17:54:02 USER USER-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
Hi Danyon,
Try to manually remove the VC++ components from your computer from "uninstall or change a program" and reattempt the installation.
If it still fails, append the "setup.ini" file you use for the installation which is located in the same directory as the "Setup.ini".
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
The prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Good Luck!
Hi....
I uninstall Visual VC++ Redistributable, But I got the Same error.Then I tried to Install VC++ 2008
Located in C:\Autodesk\Maya_2013_CEJ_Win_64-bit\3rdParty\x64\VCRedist\2008SP1. But I can't Install it too
It says "Error 1935.An error occurred during the installation of assembly Microsoft.VC90.ATL,version=
9.0.30729.4148",publicKeyToken="1fc8b3b9a1e18e 3b",processorArchitecture="amd64",type="win32"'."
What Should I Do...
See my post about editing the setup.ini to remove the check for this prereq. That should get you installed at least. But you will have to figure out how to get the C++ installed, regardless.
