So far I've had no luck, each time I attempt to download both 3Ds Max and Mudbox I receive the following error "Error assigning serial number to product: This is an operation implementation generated fault" I read that it's an account error so I registered and tried with 3 other emails yet the problem remains.
When I actually download and install the program, when it come the time where I'm to enter the seriel number I'm met with this "The serial number you entered is not valid. Try again. (1)"
While on my account the "My Software" is also at 0 as you can see.
I've tried every which way to download and run both programs but with no luck, anyone know of a fix or having the same issue I'm experiencing?
Welcome to the community Dylan and our apologies for the inconvenience.
That is actually a direct result of a backend profile issue, where the workaround is to create a new Education Community account with a different email address and proceed with the standard process of obtaining a serial number.
Let me know if that doesn't work, otherwise please accept as a solution so that others can benefit from this information.
Well I've already tried using my three main emails and the problem still remains, thanks for the quick response.
I just downloaded 3Ds Max 2013 and it asked for my serial and product key, it accepted both and installed then when I tried opening the program after installation it asks to activate my product so I enter the serial number I had previously and I'm still met with the error "The serial number you entered is not valid. Try again". UPDATE* I just made yet another account to see if it would resolve the problem and I'm now met with yet another error while confirming the account "Error updating contact: Error in updateContact: contactId value not returned" the link was also not highlighted.
Hi Dylan,
Can you please send me the serial number used to install, product name / version, and corresponding request code via a Private Message (click on my philip.s profile name and then "Send this user a private message").
