Installation & Licensing
duchoabn
426 Views, 3 Replies
error asd 2013
hello all
when I setup asd 2013 then display error as in this pic
please help me
3 REPLIES 3
zcsillag
in reply to: duchoabn
change PC date July 2012
Regards
Csillag Zoltán
TravisNave
The above response is ridiculous.
What you should do is just reactivate your software.  This is normal if you have a student license or a home-use license with a 13-month expiration.  As long as you are legal, you shouldn't have any problems.
Autodesk Forums:
ASD 2013 hotfix, which fixes the issue of the trial version expiration date is now available at:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=20784586&siteID=123112&linkID=12952913
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Jakub Brożonowicz
Global Product Support
Administrator Productivity
