Installation & Licensing
Error AdapplicationFrame.dll
7 REPLIES 7
Message 1 of 8
7897 Views, 7 Replies
Installed Autocad 2012 and when starting I get this error message.
Fatal error Unhandled Delayload: AdapplicationFrame.dll
7 REPLIES 7
Message 2 of 8
TravisNave
Welcome to the Autodesk peer support forum!
As for your error, I would suspect it is caused by a problem in your .NET Framework subsystem.  You might try reinstalling the latest version of .NET Framework.  Keep in mind that 2012 is not compatible with Windows 8, so hopefully you are on a supported system.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 8
Thank you but installed the latest .Net software 2 weeks ago.
Message 4 of 8
TravisNave
It is possible that it needs reinstalled.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Autodesk Forums:
Message 5 of 8
in reply to: TravisNave
Ran your removal tool and reinstalled .net same results, Di I have to uninstall and reinstall autocad?
Message 6 of 8
TravisNave
You need to reinstall .NET Framework.  You should download and install the full redistributable from Microsoft's website.  Then you *might* have to do a repair install of AutoCAD.
Autodesk Forums:
Message 7 of 8
Opps should have put this in there: I did reinstall the .net so will try the repair install
Message 8 of 8
ok removed and reinstalled .net and reloaded autocad. System still gives same error.
Administrator Productivity
