Installation & Licensing
Active Member
JustinCase1
Message 1 of 8 (1,772 Views)
Error AdapplicationFrame.dll
1772 Views, 7 Replies
06-05-2013 10:10 AM
Installed Autocad 2012 and when starting I get this error message.
Fatal error Unhandled Delayload: AdapplicationFrame.dll
TravisNave
Message 2 of 8 (1,767 Views)
Re: Error AdapplicationFrame.dll
06-05-2013 10:22 AM in reply to: JustinCase1
Welcome to the Autodesk peer support forum!
As for your error, I would suspect it is caused by a problem in your .NET Framework subsystem.  You might try reinstalling the latest version of .NET Framework.  Keep in mind that 2012 is not compatible with Windows 8, so hopefully you are on a supported system.
Active Member
JustinCase1
Message 3 of 8 (1,764 Views)
06-05-2013 10:25 AM in reply to: JustinCase1
Thank you but installed the latest .Net software 2 weeks ago.
TravisNave
Message 4 of 8 (1,760 Views)
06-05-2013 10:31 AM in reply to: JustinCase1
It is possible that it needs reinstalled.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Active Member
JustinCase1
Message 5 of 8 (1,754 Views)
06-05-2013 10:53 AM in reply to: TravisNave
Ran your removal tool and reinstalled .net same results, Di I have to uninstall and reinstall autocad?
TravisNave
Message 6 of 8 (1,751 Views)
06-05-2013 10:55 AM in reply to: JustinCase1
You need to reinstall .NET Framework.  You should download and install the full redistributable from Microsoft's website.  Then you *might* have to do a repair install of AutoCAD.
Active Member
JustinCase1
Message 7 of 8 (1,749 Views)
06-05-2013 10:58 AM in reply to: TravisNave
Opps should have put this in there: I did reinstall the .net so will try the repair install
Active Member
JustinCase1
Message 8 of 8 (1,720 Views)
06-10-2013 06:19 AM in reply to: JustinCase1
ok removed and reinstalled .net and reloaded autocad. System still gives same error.
