Installation & Licensing
New Member
Bergstrom
Message 1 of 2 (172 Views)
Error activating AutoCAD after re-install
172 Views, 1 Replies
02-22-2013 01:15 AM
I've just re-installed a computer that was running AutoCAD (without exporting the license first) - when I try to run AutoCAD after it has been re-installed I get the following error when trying to activate:
The serial number you entered is not valid. Try again. (1)
The serial number I am using is definitely correct (the box is in front of me!)
Please could someone help with this issue?
camilo.lemos
Message 2 of 2 (156 Views)
Re: Error activating AutoCAD after re-install
02-22-2013 01:53 AM in reply to: Bergstrom
Hi Bergstrom and welcome to the forums!
Is it possible that your product has been upgraded to a newer version (2013, for example) and you're trying to activate an older one (2012, 2011, etc)?
Can you please send me your serial number and request code via private message (click on my screenname camilo.lemos and then on Send This User Private Message)?
I'll then be able to see why you're getting an error.
Thank you,
Camilo Lemos
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
