Installation & Licensing
904 Kudos
Post 11 of 27
Re: Error -5.412.0 @ Error -4.132.0
05-18-2010 07:23 AM in reply to: alextong
This is one of those hot-button issues that should be tried in nearly every situation, as it seems to solve the majority of the problems with Autodesk software since 2010.
For Vista and Windows 7 users, the location of this file is:
C:\ProgramData\Autodesk\AdLM
The corrupt CascadeInfo.cas file will be recreated when you relaunch the software.
New Member
0 Kudos
Post 12 of 27
11-02-2010 06:58 AM in reply to: Darin.Green
Thank you very very much for the solution! :smileyvery-happy:
Deleting CASCADEINFO.CAS solved my problem completely.
I was having trouble starting Inventor 2010 (not starting, just started as a process for a couple of seconds) and AutoCAD Mechanical 2010 (server license error).
You saved me for re-installing Windows (which was the only solution I came up with when having this problem last time).
Br
Rami
Active Member
3 Kudos
Post 13 of 27
11-04-2010 11:44 AM in reply to: Darin.Green
Just wondering...  Do you know why this works?
Just an FYI...  If anyone is using Window 7 the file location of the .cas file is c:smileytongue:rogramData\Autodesk\Adlm
Member
0 Kudos
Post 14 of 27
10-20-2011 08:19 AM in reply to: TravisNave
This worked great for an -4.132 error with Revit MEP 2012!
Thanks everyone!
Frank
904 Kudos
Post 15 of 27
10-20-2011 08:47 AM in reply to: frankaholic
Just to elaborate, the -4 error means that you were out of licenses on your NLM server.  Freeing up a license by having someone else close their application or return their borrowed license will resolve this temporary issue.  Deleting the CascadeInfo.cas file will work, however, if for some reason the cascading of licenses are not working when you are out of one feature and it cannot cascade to another available license.
Help Improve the Autodesk Discussion Groups
If I was able to resolve your issue, please select the "Accept as Solution" option so that you can help fellow members quickly find solutions to their problems. Please add Kudos to a post if you were helped by a post that you did not author.
Member
0 Kudos
Post 16 of 27
10-20-2011 11:06 AM in reply to: TravisNave
The problem I was having did not have to do with available licenses. There were two licenses available, and the workstation next to mine was able to open and close revit with no error.
Further, I was able to use revit last week with no problems.
When I deleted the .cas file, the error went away.
-Frank
904 Kudos
Post 17 of 27
10-20-2011 12:04 PM in reply to: frankaholic
Yes, which is why I clarified the difference between the standard -4 licenses exceeded error vs. the cascade issue.  Thanks.  :smileywink:
Member
0 Kudos
Post 18 of 27
10-20-2011 12:18 PM in reply to: TravisNave
i see. Big thanks to you and everyone who contributed. i don't know how long i would of struggled with this!:smileyhappy:
-Frank
904 Kudos
Post 19 of 27
10-20-2011 12:22 PM in reply to: frankaholic
I am glad you are up and running.  Every little bit of helpful information is a good resource for someone else.  You never know what tidbit is going to fix someone else.  Feel free to pick our brains anytime and contribute any solutions you have.  That's what it's all about, my man!  :smileyvery-happy:
New Member
0 Kudos
Post 20 of 27
Error -4.132.0
01-18-2012 06:52 AM in reply to: alextong
I have this error -4.132.0 comes up when I launch REVIT 2012 and ACAD 2012. I looked for the .cas file in the directory but did not find it. Can anyone please provide information on how to resolve this error.
Respectfully,
Jfields
