Configuration is as follows:
Windows Server 2008 R2 Enterprise 64 bit
Microsoft 2008 SQL Server 64 bit (with an instance AUTODESKVAULT)
Microsoft Exchange 2007
On the IIS I created a 'DefaultAppPool 64' and moved all applications to that pool, to avoid interferrence with 32 bit Autodesk software.
When installing the 2011 Vault Server the install runs until the languagepack is installed then it ends with following error and roll's back.
"29001 Vault management error: Could not load file or assembly 'Connectivity.Content' or one of its dependencies. Access is denied."
See if Doug's solution here fits your issue:
You might also do a search on the Vault forums for this issue. I've run into a few different causes for 29001 in my own experience. You might find yours here:
