Installation & Licensing
Error 20. THe software license check out failed
2 REPLIES 2
6988 Views, 2 Replies
Is the only solution to reinstall 3ds Max? Im using Win7, 64 bit.
2 REPLIES 2
david.lau
TravisNave
David,
Can you re-check your link?
In the mean-time also look here:
http://area.autodesk.com/forum/autodesk-3ds-max/installation---hardware---os/the-software-license-ch...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
