I tried to download the Autodesk Revit Architecture and it came up with error 1935 and said there was a problem with the Microsoft.VC90.ATL any recomendations?
please try the fix from Microsoft
http://support.microsoft.com/kb/970652
if it doesn't help try this
http://usa.autodesk.com/getdoc/id=TS1065229
I tried to install Revit 2013 without any luck. I got an
Error 1935 HRESULT 0x8007054F, on Windows 7, when attempting to install Microsoft Visual C++ 2008 Redistributable Setup.
Also on the log I got:
Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Failed Installation
I have tried everything I found on Microsoft, Autodesk, etc without luck.
Anybody can help please.
Uninstall all the instances of Microsoft Visual C++ 2008, then run the installer. It will reinstall the runtime as necessary.
I unistalled all the instances of Microsoft Visual C++ 2008 and still getting the same error.
I do not know what else I have to do to install Revit 2013.
For new users who have the same problem:
I had the same problem but afther I tried almost everything I found what was wrong for me.
It's very simpel.
First restart your computer.
Delete every file from autodesk you have on your pc from an earlier download try.
Then try to download it again, it worked for me.
Let me know if it worked for you to!
Good luck!
@esmeeheebing wrote:For new users who have the same problem:
It's very simpel.
Good luck!
Hello!
I had the same error when I tried to install revit 2017 and I only got fix it disabling the antivirus during installation.
I really didn't know if this solution will be useful for other users but I prefer to share.
Good luck
