Hi, Guys
While Installing Autodesk Inventor 2013 with windows 8.1 am getting the error as described in the image. Kindly suggest the solution for this.
Thank you in advance.
The problem is with installing the Visual C++ Resdistributable component. This product is probably not compatible with 8.1, so you might have to install the prerequisite manually or edit the setup.ini to ignore it. I would also try installing in Win7 compatibility mode too.
