Installation & Licensing
error-1722 while installing revit structure 2013
22 REPLIES 22
Message 1 of 23
2059 Views, 22 Replies
i am trying to install revit structure 2013 on my win7 x64...error comes while installatin ( error -1722 ) ...pls someone help
22 REPLIES 22
Message 21 of 23
DannyHubbard
The only other thing I would think to try is to again remove Revit using the Microsoft Fix It utility then reinstall following the steps from the following document.
http://usa.autodesk.com/getdoc/id=TS75218
Danny
Danny Hubbard
QA Analyst
Message 22 of 23
I had exactelly the same problem with autodesk robot structural analysis 2013. The only solution that I have found after two weeks of test is to reinstall windows. After every thing has working well. Perhaps a windows repair with CD is possible, or with the sauvergard initial CD of your computer.
Unfortunetly it's a lot of work to reinstall all yours softwares.
If somebody has a better solution it will be great
Pierre Finiels
Message 23 of 23
in reply to: DannyHubbard
no danny that didn't work for me...thanks for giving me yr valuable time...now  i have give up.....
and thanks pierreFINELS6147 for that solution....but i dont want to reinstall windows..as u said its lot of work to istall other program.....but thanks  🙂
Administrator Productivity
