Installation & Licensing
paresh6203
Message 1 of 23 (1,243 Views)
error-1722 while installing revit structure 2013
1243 Views, 22 Replies
11-09-2012 03:25 AM
i am trying to install revit structure 2013 on my win7 x64...error comes while installatin ( error -1722 ) ...pls someone help
Employee
DannyHubbard
Message 2 of 23 (1,233 Views)
Re: error-1722 while installing revit structure 2013
11-09-2012 05:18 AM in reply to: paresh6203
Reboot, try the install again. If it still fails post the Revit Setup and Install log from your temp folder, they will have more details on the cause of the failure.
Danny
Danny Hubbard
QA Analyst
paresh6203
Message 3 of 23 (1,227 Views)
11-09-2012 09:12 AM in reply to: DannyHubbard
thanxx for reply danny
there are two log file for revit 1- install.log and 2- satup.log....whitch one is nedded?
Employee
DannyHubbard
Message 4 of 23 (1,219 Views)
11-09-2012 09:31 AM in reply to: paresh6203
Attach both log files.
Danny
Danny Hubbard
QA Analyst
paresh6203
Message 5 of 23 (1,216 Views)
11-09-2012 09:40 AM in reply to: DannyHubbard
here it is...satup.log file
size of install log is about 14 mb..what to do?
Employee
DannyHubbard
Message 6 of 23 (1,204 Views)
11-09-2012 09:50 AM in reply to: paresh6203
Select the install log, right click choose Send to - Compressed Folder.
Uploading the resulting zip file that is created.
Danny
Danny Hubbard
QA Analyst
paresh6203
Message 7 of 23 (1,201 Views)
11-09-2012 09:53 AM in reply to: DannyHubbard
thanks danny ...here it is :smileyhappy:
Employee
DannyHubbard
Message 8 of 23 (1,183 Views)
11-09-2012 10:05 AM in reply to: paresh6203
Your install log is reporting the following error
Note: 1: 1722 2: win64RegisterIDbRoot.742DD471_03BC_4C75_8992_518E2BDABD1C 3: C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\DBAccess\ 4: regsvr32.exe /s "IDbRoot.dll"
Try renaming this DBAccess folder then run Setup again to install Revit.
See a similar post, http://forums.autodesk.com/t5/Installation-Licensing/Cannot-Install-Revit-2013-Something-called-Wind...
Danny
Danny Hubbard
QA Analyst
paresh6203
Message 9 of 23 (1,181 Views)
11-09-2012 10:14 AM in reply to: DannyHubbard
ok i read that post...he is saying
"In Windows Explorer navigate to the folder "C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\DBAccess" select the file "RBCTMdbEditX.dll", right click and choose Rename. After renaming the file run setup for Revit 2013 again."
but not mensioned renamed file... ?????? so can i ename it to any name?
Employee
DannyHubbard
Message 10 of 23 (1,164 Views)
11-09-2012 10:29 AM in reply to: paresh6203
Yes you can rename the file to anything. Make sure you read the rest of that thread there are other things people did to get past this error.
Danny
Danny Hubbard
QA Analyst
