Installation & Licensing
Error 1619 during installation
7 REPLIES 7
Message 1 of 8
Alasuya
338 Views, 7 Replies
Microsoft Visual C++ 2012 Redistributable (x86)FailedFailure is ignored, Result=1619
errors like this is what's giving me trouble.
I keep getting errors 1619 im not sure how to fix it.
7 REPLIES 7
Message 2 of 8
Alasuya
in reply to: Alasuya
yeah it's student 2015 3d max
Message 3 of 8
TravisNave
Here is the real failure:
Install	Autodesk® Material Library 2015 - Medium Resolution Library	Failed	Download Failed, Installation aborted, Result=1603
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 4 of 8
Alasuya
in reply to: TravisNave
ok i will give it a shot.
Message 5 of 8
Alasuya
For 3D MAX I got
http://autodesk.creativevirtual15.com/autodesk/SWDLDNET4/2015/3DSMAX/DLM/Autodesk_3ds_Max_2015_EFGJK...
HTTP Status 404 - /autodesk/SWDLDNET4/2015/3DSMAX/DLM/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R1_dlm.sfx.exe
when i clicked on the 64 bit version.
Message 6 of 8
Alasuya
do i have to download autocad before i do 3d max?
Message 7 of 8
TravisNave
Yeah, I think the link is broken.  Try downloading the trial.
Autodesk Forums:
Message 8 of 8
Alasuya
I tried downloading the trial version of 3d max and ran into the same problem twice, error 1619
Administrator Productivity
