I'm trying to install AutoCAD 2014 and Autodesk ReCap onto my computer but during installation, it says everything has failed to install. Here is the installation log:
2014/2/5:16:01:12 Alex HALLNET-CVAV2 === Setup started on HALLNET-CVAV2 by Alex ===
2014/2/5:16:01:12 Alex HALLNET-CVAV2 Path_Length: 155
2014/2/5:16:01:12 Alex HALLNET-CVAV2 Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/2/5:16:01:12 Alex HALLNET-CVAV2 Launch
2014/2/5:16:01:12 Alex HALLNET-CVAV2 CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setu... /SN 900-44865955 /PK 001F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/5:16:01:12 Alex HALLNET-CVAV2 Current Directory C:\Users\Alex\AppData\Local\Temp\_AI2291.tmp
2014/2/5:16:02:17 Alex HALLNET-CVAV2 === Setup ended ===
2014/2/5:16:01:14 Alex HALLNET-CVAV2 === Setup started on HALLNET-CVAV2 by Alex ===
2014/2/5:16:01:14 Alex HALLNET-CVAV2 Path_Length: 155
2014/2/5:16:01:14 Alex HALLNET-CVAV2 Current Directory C:\Users\Alex\AppData\Local\Temp\_AI2291.tmp
2014/2/5:16:01:14 Alex HALLNET-CVAV2 Launch
2014/2/5:16:01:49 Alex HALLNET-CVAV2 Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6...
2014/2/5:16:02:16 Alex HALLNET-CVAV2 Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6...
2014/2/5:16:02:16 Alex HALLNET-CVAV2 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Alex\AppData\Local\Temp\_AI2291.tmp\Setup\AcSetup.dll
2014/2/5:16:02:16 Alex HALLNET-CVAV2 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/5:16:02:16 Alex HALLNET-CVAV2 PageOpen LaunchDialog
2014/2/5:16:02:24 Alex HALLNET-CVAV2 PageOpen LicenseDialog
2014/2/5:16:02:28 Alex HALLNET-CVAV2 PageOpen ProductInfoDialog
2014/2/5:16:02:28 Alex HALLNET-CVAV2 PageOpen ProductSelectionDialog2
2014/2/5:16:02:39 Alex HALLNET-CVAV2 PageOpen FullProgressDialog
2014/2/5:16:02:39 Alex HALLNET-CVAV2 Download Play DOTNET4 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DOTNET4K...
2014/2/5:16:03:17 Alex HALLNET-CVAV2 Download Aborted DOTNET4 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DOTNET4K...
2014/2/5:16:03:17 Alex HALLNET-CVAV2 Install .NET Framework Runtime 4.0 Failed Download Failed, Installation aborted, Result=1603
2014/2/5:16:03:17 Alex HALLNET-CVAV2 PageOpen InstallCompleteDialog
2014/2/5:16:04:56 Alex HALLNET-CVAV2 === Setup ended ===
2014/2/5:16:13:04 Alex HALLNET-CVAV2 === Setup started on HALLNET-CVAV2 by Alex ===
2014/2/5:16:13:04 Alex HALLNET-CVAV2 Path_Length: 155
2014/2/5:16:13:04 Alex HALLNET-CVAV2 Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/2/5:16:13:04 Alex HALLNET-CVAV2 Launch
2014/2/5:16:13:04 Alex HALLNET-CVAV2 CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setu... /SN 900-44865955 /PK 001F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/5:16:13:04 Alex HALLNET-CVAV2 Current Directory C:\Users\Alex\AppData\Local\Temp\_AI14C.tmp
2014/2/5:16:13:10 Alex HALLNET-CVAV2 === Setup ended ===
2014/2/5:16:13:05 Alex HALLNET-CVAV2 === Setup started on HALLNET-CVAV2 by Alex ===
2014/2/5:16:13:05 Alex HALLNET-CVAV2 Path_Length: 155
2014/2/5:16:13:05 Alex HALLNET-CVAV2 Current Directory C:\Users\Alex\AppData\Local\Temp\_AI14C.tmp
2014/2/5:16:13:05 Alex HALLNET-CVAV2 Launch
2014/2/5:16:13:05 Alex HALLNET-CVAV2 Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6...
2014/2/5:16:13:06 Alex HALLNET-CVAV2 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Alex\AppData\Local\Temp\_AI14C.tmp\Setup\AcSetup.dll
2014/2/5:16:13:06 Alex HALLNET-CVAV2 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/5:16:13:06 Alex HALLNET-CVAV2 PageOpen LaunchDialog
2014/3/10:21:38:47 Alex HALLNET-CVAV2 === Setup started on HALLNET-CVAV2 by Alex ===
2014/3/10:21:38:47 Alex HALLNET-CVAV2 Path_Length: 155
2014/3/10:21:38:47 Alex HALLNET-CVAV2 Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/3/10:21:38:47 Alex HALLNET-CVAV2 Launch
2014/3/10:21:38:47 Alex HALLNET-CVAV2 CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setu... /SN 900-44865955 /PK 001F1 /student /akamai /auth authparam /sid SESSION_ID
2014/3/10:21:38:47 Alex HALLNET-CVAV2 Current Directory C:\Users\Alex\AppData\Local\Temp\_AIF49D.tmp
2014/3/10:21:38:53 Alex HALLNET-CVAV2 === Setup ended ===
2014/3/10:21:38:50 Alex HALLNET-CVAV2 === Setup started on HALLNET-CVAV2 by Alex ===
2014/3/10:21:38:50 Alex HALLNET-CVAV2 Path_Length: 155
2014/3/10:21:38:50 Alex HALLNET-CVAV2 Current Directory C:\Users\Alex\AppData\Local\Temp\_AIF49D.tmp
2014/3/10:21:38:50 Alex HALLNET-CVAV2 Launch
2014/3/10:21:38:51 Alex HALLNET-CVAV2 Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6...
2014/3/10:21:38:52 Alex HALLNET-CVAV2 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Alex\AppData\Local\Temp\_AIF49D.tmp\Setup\AcSetup.dll
2014/3/10:21:38:52 Alex HALLNET-CVAV2 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/3/10:21:38:52 Alex HALLNET-CVAV2 PageOpen LaunchDialog
2014/3/10:21:39:07 Alex HALLNET-CVAV2 PageOpen LicenseDialog
2014/3/10:21:39:11 Alex HALLNET-CVAV2 PageOpen ProductInfoDialog
2014/3/10:21:39:11 Alex HALLNET-CVAV2 PageOpen ProductSelectionDialog2
2014/3/10:21:39:19 Alex HALLNET-CVAV2 PageOpen FullProgressDialog
2014/3/10:21:39:19 Alex HALLNET-CVAV2 Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DIRECTX....
2014/3/10:21:39:22 Alex HALLNET-CVAV2 Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DIRECTX....
2014/3/10:21:39:22 Alex HALLNET-CVAV2 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/3/10:21:40:27 Alex HALLNET-CVAV2 Install DirectX Runtime Succeeded
2014/3/10:21:40:27 Alex HALLNET-CVAV2 Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/10:21:40:39 Alex HALLNET-CVAV2 Install FARO LS 5.1.0.30630 (64bit) Succeeded
2014/3/10:21:40:40 Alex HALLNET-CVAV2 Download Play CM http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/CM.tar.l...
2014/3/10:21:40:49 Alex HALLNET-CVAV2 Download Complete CM http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/CM.tar.l...
2014/3/10:21:40:50 Alex HALLNET-CVAV2 Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/10:21:41:06 Alex HALLNET-CVAV2 Install Autodesk Material Library 2014 Succeeded
2014/3/10:21:41:07 Alex HALLNET-CVAV2 Download Play CMILB http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/CMILB.ta...
2014/3/10:21:41:19 Alex HALLNET-CVAV2 Download Complete CMILB http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/CMILB.ta...
2014/3/10:21:41:20 Alex HALLNET-CVAV2 Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/10:21:41:36 Alex HALLNET-CVAV2 Install Autodesk Material Library 2014 - Base Image Library Succeeded
2014/3/10:21:41:37 Alex HALLNET-CVAV2 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/10:21:41:47 Alex HALLNET-CVAV2 Install Autodesk Content Service Succeeded
2014/3/10:21:41:47 Alex HALLNET-CVAV2 Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/10:21:41:53 Alex HALLNET-CVAV2 Install Autodesk Content Service Language Pack Succeeded
2014/3/10:21:41:54 Alex HALLNET-CVAV2 Download Play ACAD http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/ACAD_x64...
2014/3/10:21:45:51 Alex HALLNET-CVAV2 Download Aborted ACAD http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/ACAD_x64...
2014/3/10:21:45:51 Alex HALLNET-CVAV2 Install Autodesk® AutoCAD® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/3/10:21:45:57 Alex HALLNET-CVAV2 Rollback Autodesk Content Service Language Pack Succeeded
2014/3/10:21:46:19 Alex HALLNET-CVAV2 Rollback Autodesk Content Service Succeeded
2014/3/10:21:46:30 Alex HALLNET-CVAV2 Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2014/3/10:21:46:52 Alex HALLNET-CVAV2 Rollback Autodesk Material Library 2014 Succeeded
2014/3/10:21:46:53 Alex HALLNET-CVAV2 Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2014/3/10:21:46:53 Alex HALLNET-CVAV2 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/3/10:21:46:55 Alex HALLNET-CVAV2 PageOpen InstallCompleteDialog
2014/3/10:21:51:46 Alex HALLNET-CVAV2 === Setup ended ===
2014/3/11:09:43:01 Alex HALLNET-CVAV2 === Setup started on HALLNET-CVAV2 by Alex ===
2014/3/11:09:43:01 Alex HALLNET-CVAV2 Path_Length: 155
2014/3/11:09:43:01 Alex HALLNET-CVAV2 Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/3/11:09:43:01 Alex HALLNET-CVAV2 Launch
2014/3/11:09:43:01 Alex HALLNET-CVAV2 CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setu... /SN 900-44865955 /PK 001F1 /student /akamai /auth authparam /sid SESSION_ID
2014/3/11:09:43:01 Alex HALLNET-CVAV2 Current Directory C:\Users\Alex\AppData\Local\Temp\_AI7FBA.tmp
2014/3/11:09:43:10 Alex HALLNET-CVAV2 === Setup ended ===
2014/3/11:09:43:04 Alex HALLNET-CVAV2 === Setup started on HALLNET-CVAV2 by Alex ===
2014/3/11:09:43:04 Alex HALLNET-CVAV2 Path_Length: 155
2014/3/11:09:43:04 Alex HALLNET-CVAV2 Current Directory C:\Users\Alex\AppData\Local\Temp\_AI7FBA.tmp
2014/3/11:09:43:04 Alex HALLNET-CVAV2 Launch
2014/3/11:09:43:05 Alex HALLNET-CVAV2 Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6...
2014/3/11:09:43:07 Alex HALLNET-CVAV2 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Alex\AppData\Local\Temp\_AI7FBA.tmp\Setup\AcSetup.dll
2014/3/11:09:43:07 Alex HALLNET-CVAV2 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/3/11:09:43:08 Alex HALLNET-CVAV2 PageOpen LaunchDialog
2014/3/11:09:43:29 Alex HALLNET-CVAV2 PageOpen LicenseDialog
2014/3/11:09:43:31 Alex HALLNET-CVAV2 PageOpen ProductInfoDialog
2014/3/11:09:43:31 Alex HALLNET-CVAV2 PageOpen ProductSelectionDialog2
2014/3/11:09:43:34 Alex HALLNET-CVAV2 PageOpen FullProgressDialog
2014/3/11:09:43:34 Alex HALLNET-CVAV2 Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DIRECTX....
2014/3/11:09:43:34 Alex HALLNET-CVAV2 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/3/11:09:44:17 Alex HALLNET-CVAV2 Install DirectX Runtime Succeeded
2014/3/11:09:44:17 Alex HALLNET-CVAV2 Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/11:09:44:39 Alex HALLNET-CVAV2 Install FARO LS 5.1.0.30630 (64bit) Succeeded
2014/3/11:09:44:39 Alex HALLNET-CVAV2 Download Skipped CM http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/CM.tar.l...
2014/3/11:09:44:39 Alex HALLNET-CVAV2 Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/11:09:45:04 Alex HALLNET-CVAV2 Install Autodesk Material Library 2014 Succeeded
2014/3/11:09:45:04 Alex HALLNET-CVAV2 Download Skipped CMILB http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/CMILB.ta...
2014/3/11:09:45:05 Alex HALLNET-CVAV2 Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/11:09:45:27 Alex HALLNET-CVAV2 Install Autodesk Material Library 2014 - Base Image Library Succeeded
2014/3/11:09:45:28 Alex HALLNET-CVAV2 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/11:09:45:36 Alex HALLNET-CVAV2 Install Autodesk Content Service Succeeded
2014/3/11:09:45:37 Alex HALLNET-CVAV2 Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/11:09:45:41 Alex HALLNET-CVAV2 Install Autodesk Content Service Language Pack Succeeded
2014/3/11:09:45:41 Alex HALLNET-CVAV2 Download Play ACAD http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/ACAD_x64...
2014/3/11:09:51:21 Alex HALLNET-CVAV2 Download Complete ACAD http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/ACAD_x64...
2014/3/11:09:51:44 Alex HALLNET-CVAV2 Installing Autodesk® AutoCAD® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\acad\acad.mst;C:\Users\Alex\AppData\Local\Temp\_AI7FBA.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/11:09:55:03 Alex HALLNET-CVAV2 Install Autodesk® AutoCAD® 2014 Succeeded
2014/3/11:09:55:04 Alex HALLNET-CVAV2 Download Play ACAD_en-us http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/ACAD_x64...
2014/3/11:09:56:39 Alex HALLNET-CVAV2 Download Aborted ACAD_en-us http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/ACAD_x64...
2014/3/11:09:56:39 Alex HALLNET-CVAV2 Install AutoCAD® 2014 Language Pack Failed Download Failed, Installation aborted, Result=1603
2014/3/11:09:56:43 Alex HALLNET-CVAV2 Rollback Autodesk® AutoCAD® 2014 Failed Installation aborted, Result=1618
2014/3/11:09:56:48 Alex HALLNET-CVAV2 Rollback Autodesk Content Service Language Pack Failed Failure is ignored, Result=1618
2014/3/11:09:56:52 Alex HALLNET-CVAV2 Rollback Autodesk Content Service Failed Failure is ignored, Result=1618
2014/3/11:09:57:20 Alex HALLNET-CVAV2 Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2014/3/11:09:57:44 Alex HALLNET-CVAV2 Rollback Autodesk Material Library 2014 Succeeded
2014/3/11:09:57:46 Alex HALLNET-CVAV2 Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2014/3/11:09:57:46 Alex HALLNET-CVAV2 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
From what I gathered, my DirectX might be out of date so I've updated it to the latest edition and this still didn't work. Is there anything I can do to fix this? I really need AutoCAD 14 for my University coursework
Alex Vickers
Hi Alex,
Welcome to the community.
Please ensure the following has been done:
1. Computer meets the minimum requirements
2. UAC off
3. Firewall off
4. Anti-Virus off
5. Administrator rights
6. Clear the temp folder
7. Make sure you have enough disc space 60 Gigs at least
8. Make sure the OS is up to date
9. Reinstall C++ redistributable
10. Reinstall .Net Framework
11. Copy the content of the installation media to the C drive. Preferably on the root of the C drive to negate the problem of filenames becoming too long
12. Make sure short file name creation has been enabled HKEY_LOCAL_MACHINE\SYSTEM\
CurrentControlSet\Control\FileSystem Set NtfsDisable8dot3NameCreation to a value of 0
13. Create a new Windows user with full admin rights
14. If the computer is on a domain remove it from the network completely for the duration of installation
If there is any step you dont understand. Please dont hesitate to ask
It also looks like you are trying to download the software while installing. Is this correct?
Hi Jo,
Sorry about the delay in response, I've had a lot of work 😕
I download the installer from the Autodesk website for AutoCAD 14 and then run the installer. I'm guessing that the installer is just a window that allows me to download the software and install it at the same time, like you said so I wouldn't be able to disconnect from the netowrk for the installation. Is there another way for me to install it without downloading it at the same time?
Alex
Hi Alex,
There are several ways to download and install Autodesk Software, please check the link below to the post regarding it on our Up and Ready blog.
http://upandready.typepad.com/up_and_ready/2013/01/quick-start-downloads.html
Then please check the link below for general installation workflow and proceed with your ACAD 2014 installation.
http://upandready.typepad.com/up_and_ready/2013/04/quick-start-general-installation-workflow.html
Regarding installation logs you posted, the installation failed at the stage of downloading ACAD 2014 Language Pack and this caused the installation rollback.
-snip-
-snip-
