Installation & Licensing
Error 1606. Could not access network location Setup.
25 REPLIES 25
Message 1 of 26
msmallmn
16541 Views, 25 Replies
It appears there is an extra “\” …\AutoCAD 2013 – English\R19.0\enu\\Support\.
I don’t know if this is causing the error or not.
I tried these articles but everything checked out.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9579121&linkID=9240617 and http://support.microsoft.com/kb/886549
Not sure what to do next.
25 REPLIES 25
Message 2 of 26
cbenner
in reply to: msmallmn
Message 3 of 26
msmallmn
in reply to: cbenner
Sure thing.
Dell Precision T1650 w/Intel i7-3770
Windows 7 Pro 64-Bit
16GB Ram
AMD FirePro V4900
Message 4 of 26
David_Knight
Have you tried installing from a CD DVD, Thumbrdrive, or by copying the installation folders to your Hard Drive?
Message 5 of 26
msmallmn
in reply to: David_Knight
From the thumbdrive.
Message 6 of 26
David_Knight
I presume you get the same error then?
I'm not sure.
Those are the things I would have tried.
If there is in fact an error in your user profile (as the links you listed suggest) I would try either
  1. creating a new user profile (or)
  2. logging in as the admin profile
and trying the installation again.
I also presumed you had admin privileges when you attempted to install.  If you do not, that is likely an issue of some sort as well.
Message 7 of 26
msmallmn
I'm not sure.
There is no problem with the user profile. That checked out.  I do have admin rights on this PC.
The only thing I have't tried is copying the files from the thumbdrive to the hard drive.  Why would that cause an issue?
Message 8 of 26
David_Knight
Handful of network issues, or perhaps the length of the share name... The thumb drive would eliminate things, as would trying another profile. If it fails with the thumb drive its not a network issue. And changing profiles would eliminate the profile completely if it failed. I'm not sure beyond that what the problem is or could be. As a worst case scenario it could be hardware issues or corrupted operating system. Speaking or corruption, can you reinstall from an original disc or from the original download? Maybe the server corrupted the installation path. Lastly the double "\" in the path isn't always a problem I've had it display it before but work. Good luck.
Message 9 of 26
Alfred.NESWADBA
Because part of the installation procedure installs Framework (plus hotfix). Framework is quite sensitive to non-trusted drives, so if your security settings are default (or stronger) a network-drive (or external drive) might be blocked for some update process. So it really makes sense to copy the installation files to a local folder (on C:) and start then the installation.
And remember, the message tells you that you have a network-problem during installation.
Why are you that sure, at least you have a problem with installation and we don't know where. So it's a tip to run that with another profile just as an option.
Great, and you have started the SETUP.EXE with right-click and option "start as administrator" or you have disable UAC?
Just to have admin-permissions does not mean you start the programs with admin-permissions, that changed since Vista.
You also can start with first installing the DirectX-components from the installation media, then the Framework (+hotfix) and when this is finished, then try to start the AutoCAD-installation again.
If it again fails, please upload the log-file that was created during the AutoCAD-installation.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 10 of 26
Great reply Alfred. He said it better than I.
Message 11 of 26
msmallmn
in reply to: Alfred.NESWADBA
- alfred -
It failed again.  Where do I find this log file?
Message 12 of 26
msmallmn
Found it.
2013/4/2:12:05:02	msmall	ESI069	=== Setup started on ESI069 by msmall ===
2013/4/2:12:05:02	msmall	ESI069	Launch
2013/4/2:12:05:08	msmall	ESI069	=== Setup ended ===
2013/4/2:12:05:16	msmall	ESI069	=== Setup started on ESI069 by msmall ===
2013/4/2:12:05:16	msmall	ESI069	Launch
2013/4/2:12:05:19	msmall	ESI069	=== Setup ended ===
2013/4/2:12:05:17	msmall	ESI069	=== Setup started on ESI069 by msmall ===
2013/4/2:12:05:17	msmall	ESI069	Launch
2013/4/2:12:05:19	msmall	ESI069	PageOpen	LaunchDialog
2013/4/2:12:05:20	msmall	ESI069	PageOpen	LicenseDialog
2013/4/2:12:05:23	msmall	ESI069	PageOpen	ProductInfoDialog
2013/4/2:12:06:14	msmall	ESI069	PageOpen	ProductSelectionDialog2
2013/4/2:12:06:29	msmall	ESI069	PageOpen	FullProgressDialog
2013/4/2:12:06:29	msmall	ESI069	Installing Autodesk® Design Review 2013:  TRANSFORMS="C:\Users\msmall\AppData\Local\Temp\_AI3084.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\AutoCAD Design Suite\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/2:12:06:42	msmall	ESI069	Install	Autodesk® Design Review 2013	Succeeded
2013/4/2:12:06:42	msmall	ESI069	Installing DirectX Runtime: C:\AutoCAD Design Suite\3rdParty\DirectX\DXSETUP.exe /silent
2013/4/2:12:08:05	msmall	ESI069	Install	DirectX Runtime	Succeeded
2013/4/2:12:08:06	msmall	ESI069	Installing Autodesk® Material Library 2013 - Medium Resolution Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\AutoCAD Design Suite\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/2:12:08:29	msmall	ESI069	Install	Autodesk® Material Library 2013 - Medium Resolution Image Library	Succeeded
2013/4/2:12:08:29	msmall	ESI069	Installing Autodesk DirectConnect 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\AutoCAD Design Suite\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/2:12:09:23	msmall	ESI069	Install	Autodesk DirectConnect 2013	Succeeded
2013/4/2:12:09:24	msmall	ESI069	Installing Autodesk® Showcase® 2013:  TRANSFORMS="C:\Users\msmall\AppData\Local\Temp\_AI3084.tmp\x64\Showcase\AutodeskShowcase7.0-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\AutoCAD Design Suite\" INSTALLDIR="C:\Program Files\Autodesk\Showcase 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/2:12:14:49	msmall	ESI069	Install	Autodesk® Showcase® 2013	Succeeded
2013/4/2:12:14:49	msmall	ESI069	Installing Autodesk® SketchBook® Designer 2013:  TRANSFORMS="C:\Users\msmall\AppData\Local\Temp\_AI3084.tmp\x64\SBD\SBD-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\AutoCAD Design Suite\" INSTALLDIR="C:\Program Files\Autodesk\SketchBookDesigner2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/2:12:15:55	msmall	ESI069	Install	Autodesk® SketchBook® Designer 2013	Succeeded
2013/4/2:12:15:55	msmall	ESI069	Installing Autodesk® SketchBook® Designer for AutoCAD® 2013:  TRANSFORMS="C:\Users\msmall\AppData\Local\Temp\_AI3084.tmp\x64\SBDACAD\SBDACAD-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\AutoCAD Design Suite\" INSTALLDIR="C:\Program Files\Autodesk\ApplicationPlugins\SBD.bundle\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/2:12:16:19	msmall	ESI069	Install	Autodesk® SketchBook® Designer for AutoCAD® 2013	Succeeded
2013/4/2:12:16:20	msmall	ESI069	Installing Autodesk® Mudbox® 2013:  TRANSFORMS="C:\Users\msmall\AppData\Local\Temp\_AI3084.tmp\x64\Mudbox\Mudbox2013.0-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\AutoCAD Design Suite\" INSTALLDIR="C:\Program Files\Autodesk\Mudbox 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/2:12:17:31	msmall	ESI069	Install	Autodesk® Mudbox® 2013	Succeeded
2013/4/2:12:17:31	msmall	ESI069	Installing Autodesk® Raster Design 2013:  TRANSFORMS="C:\Users\msmall\AppData\Local\Temp\_AI3084.tmp\x64\Raster\Raster-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\AutoCAD Design Suite\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Raster Design 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/2:12:18:46	msmall	ESI069	Install	Autodesk® Raster Design 2013	Failed	Installation aborted, Result=1603
2013/4/2:12:19:10	msmall	ESI069	Rollback	Autodesk® Mudbox® 2013	Succeeded
2013/4/2:12:19:25	msmall	ESI069	Rollback	Autodesk® SketchBook® Designer for AutoCAD® 2013	Succeeded
2013/4/2:12:20:16	msmall	ESI069	Rollback	Autodesk® SketchBook® Designer 2013	Succeeded
2013/4/2:12:21:53	msmall	ESI069	Rollback	Autodesk® Showcase® 2013	Succeeded
2013/4/2:12:22:13	msmall	ESI069	Rollback	Autodesk DirectConnect 2013	Succeeded
2013/4/2:12:22:18	msmall	ESI069	Rollback	Autodesk® Material Library 2013 - Medium Resolution Image Library	Succeeded
2013/4/2:12:22:18	msmall	ESI069	Rollback	DirectX Runtime	Failed	Failure is ignored, Result=1619
2013/4/2:12:22:24	msmall	ESI069	Rollback	Autodesk® Design Review 2013	Succeeded
2013/4/2:12:22:24	msmall	ESI069	PageOpen	InstallCompleteDialog
2013/4/2:12:49:20	msmall	ESI069	=== Setup ended ===
2013/4/2:12:51:15	msmall	ESI069	=== Setup started on ESI069 by msmall ===
2013/4/2:12:51:15	msmall	ESI069	Launch
2013/4/2:12:51:18	msmall	ESI069	=== Setup ended ===
Message 13 of 26
Alfred.NESWADBA
first failure I see is Raster-Design. Try to disable "Raster Design" from the list of products to be installed and try it again.
- alfred -
Alfred NESWADBA
Message 14 of 26
msmallmn
Would this headache go away if I were to install it with a local profile on this machine?
Message 15 of 26
DannyHubbard
With a local profile everything should install fine.
Check out the following section from http://usa.autodesk.com/getdoc/id=TS1055299
Folder redirection
There are several ways to redirect certain folders from within the user profile, including (but not limited to) the Start Menu, My Documents or Temp folders. This customization can be done directly on the computer or with network management software, such as Microsoft Active Directory and Group Policies. These types of customizations can cause failures in the AutoCAD secondary installer which might result in error messages, such as Error 1606: Unable to access network location. To correct this issue, you should remove folder redirection from the user, reboot the machine, and then try to run AutoCAD again.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 16 of 26
msmallmn
in reply to: DannyHubbard
Folder redirection
Danny
Thanks a lot Danny! I'll see if I can't have that folder redirection disabled temporarily, or just use a local profile to install with.
Message 17 of 26
MarioVanceti
Same problem – I have tried everything I found on internet,  but no change. Then I’ve decide to create a new user account, and Acad 2014 installation had no problems. After that I simply switch to the original user account and Acad 2014 installation was OK on this user account as well.  That’s how it works for me (Win 7x64 – Autocad 2014x64):
  1. Go to user accounts and create a new account as Administrator
  2. Log on with new account
  3. After logon go to Switch user and Go back to the original account
  4. That’s it – now you can install Acad 2014  with original account
It works for me – I hope it works for you either
Message 18 of 26
latimersd
I appreciate your helpful replies. That said, I would like to take a moment to rant regarding AutoDesk's need to make this sort of thing so difficult and internally complex. Why do we need a 12-step process to load a viewer?! Perhaps there could be a "light" version for those of us relatively normal users who do not care to use all the accessory applicatiions AutoDesks thinks we need or would like us to use. My goodness! Give me a one-file download that does not rely on three other products that also have to be installed. Just let me load and look at a DWG.
-Cheers-
Message 19 of 26
msmallmn
in reply to: MarioVanceti
This is what I'm trying next.  Our IT guys wanted to try something else, but I still got the same error.
Message 20 of 26
msmallmn
Well, ended up disabling roaming profiles and folder redirection. So now I have a local profile.  This appears to have solved the issue. Everything seems to have installed properly and is working correctly. It even corrected the problem I was having with properties not displaying for the selected object.
IMO it's poor programming on AutoDesk's part to not be able to account for that. It seems like it's a pretty common IT practice.
Thank you to those who helped out!
Administrator Productivity
