Installation & Licensing
Error 1606. Could not access network location Autodesk\AutoCAD 2014\R19.1
5 REPLIES 5
wgmdev
28067 Views, 5 Replies
Problem:-
The following problem is seen when installing AutoCAD 2014.
When we run setup.exe of AutoCAD 2014 the following error message is displayed.
“Error 1606. Could not access network location Autodesk\AutoCAD 2014\R19.1.”
Resolution:-
The problem is due to a registry location pointing to a non-existent location for the user profile location.
Steps to resolve :
  • Go to run.
  • Type ‘regedit’ click ‘ok’. The Registry Editor window opens.
  • Follow the path given below.
  • [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders]
  • Check the location for “Common Documents”, It will be pointing to a non-existent location
  • Eg. "Common Documents"="C:\\Users\\Public\\Documents"
  • Change the value data of common document as:
  • "Common Documents"="d:\\Users\\Public\\Documents"
  • OR create that non-existent folder
  • Run AutoCAD 2014 setup again
5 REPLIES 5
david.lau
in reply to: wgmdev
Thanks for the tip/workaround.
David Lau
RonnySimonsen
in reply to: wgmdev
Hi!
I did try this because userprofiles is stored on partition D:\
This didn't work, so thats why i asked here in forum.
Now i discoverd that the real path is not D:\Users\Public\... but ...\Users\... has been renamed to norwegian ...\Brukere\...
I edit registre to; D:\Brukere\Public\Documents and now it works.
This is an error that shouldnt be there at all. Autodesk should be so proffesional to can avoid such error. No other software have this kind og problem!
Autodesk! Fix this!
gouacht
in reply to: wgmdev
Merci for your answers
jjamison
in reply to: wgmdev
This seemed to work for me:
- delete shortcut on desktop
- open windows explorer
- go to c:\program files\autodesk\autocad 2014
- right click on acad.exe
- select send to desktop (create shortcut)
good luck
Gamitto
in reply to: wgmdev
Thank you, solved my problem
Administrator Productivity
