Installation & Licensing
Member
mediplanGmbH
Message 11 of 17 (15,433 Views)
Re: Error 1606:Could not access network location Autodesk\Autocad 2014\R19.1
05-13-2013 08:54 AM in reply to: tonyv1978
Hi there,
two good news from me:
1. The installation went fine w/o difficulties on our notebook - just with one HD (Win 7, 64 bit)
2. The installation on our workstation (Win 7, 64 bit, one SSD just for OS and program data - one regular HD for user data) worked fine now.
I got a phone call from the Autodesk Support Line.
We changed the following:
1. generated a local user profile with administrative privileagues and started it.
2. Switched the UAC (user access control) to OFF !!!
3. Opened registry and went to
HKeyLocalMachine/Software/Microsoft/Windows/CurrentVersion/Explorer/Shell folders
and changed the keys
Common Desktop               c:\users\public\desktop    -> d:\users\public\desktop
common documents                                                        d:\users\public\documents
same proceedings for common music, common video, common pictures
(but I think it has nothing to do with this)
4. close regedit
5. reboot PC
6. Log in with administrative privs
7. start setup - and it worked.
So we are done with this subject and hopefully you benefit from this.
Pressing my thumbs that the next update from Autodesk could deal with these problems.
Active Member
tonyv1978
Message 12 of 17 (15,417 Views)
05-13-2013 03:01 PM in reply to: mediplanGmbH
Thank's a lot, i work very well, very easy solution.
Thank's again!!!!
Active Member
wppdev
Message 13 of 17 (14,623 Views)
07-26-2013 12:43 AM in reply to: tonyv1978
I was able to solve the problem with the following solution
Resolution:-
The problem is due to a registry location pointing to a non-existent location for the user profile location.
Steps to resolve :
  • Go to run.
  • Type ‘regedit’ click ‘ok’. The Registry Editor window opens.
  • Follow the path given below.
  • [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders]
  • Check the location for “Common Documents”, It will be pointing to a non-existent location
  • Eg. "Common Documents"="C:\\Users\\Public\\Documents"
  • Change the value data of common document as:
  • "Common Documents"="d:\\Users\\Public\\Documents"  (or any valid location)
  • OR create that non-existent folder
  • Run AutoCAD 2014 setup again
New Member
arsalaan88
Message 14 of 17 (14,125 Views)
09-11-2013 09:39 AM in reply to: tonyv1978
The Solution is easy: I made a new user account in my windows 7 64 bit operating system, and that's all. The setup went smooth with any errors. But the account must have administrator properties.
New Member
ddevillers
Message 15 of 17 (13,841 Views)
10-04-2013 09:55 AM in reply to: mediplanGmbH
This worked like a charm. Wonder if this is a Windows issue or AutoDesk?
Thank you!
New Member
peter
Message 16 of 17 (9,881 Views)
03-26-2014 01:20 PM in reply to: ddevillers
Hey,
For me, creating a symbolic link C:\Users pointing to d:\Users fixed the problem.
New Member
john-p-mccarthy
Message 17 of 17 (3,947 Views)
Re: Error 1606:Could not access network location Autodesk\Autocad 2014\R20
08-19-2014 09:43 AM in reply to: tonyv1978
I now have the same fault but R20. HAve tried the earlier resolution with out success. Richard at Cadline has been most helpful but as yet no resolution. Any ideas?
Auotacd 2014Lt was fine on windows 8 until massive windows updates and I could not sign in. Since then upgraded to windows 8.1. Still cannot install the software
Post to the Community
New Post
Need installation help?
