Installation & Licensing
Active Contributor
wgmdev
Message 1 of 4 (2,479 Views)
Error 1606. Could not access network location Autodesk\AutoCAD 2014\R19.1
2479 Views, 3 Replies
01-10-2014 04:26 AM
Problem:-
The following problem is seen when installing AutoCAD 2014.
When we run setup.exe of AutoCAD 2014 the following error message is displayed.
“Error 1606. Could not access network location Autodesk\AutoCAD 2014\R19.1.”
Resolution:-
The problem is due to a registry location pointing to a non-existent location for the user profile location.
Steps to resolve :
  • Go to run.
  • Type ‘regedit’ click ‘ok’. The Registry Editor window opens.
  • Follow the path given below.
  • [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders]
  • Check the location for “Common Documents”, It will be pointing to a non-existent location
  • Eg. "Common Documents"="C:\\Users\\Public\\Documents"
  • Change the value data of common document as:
  • "Common Documents"="d:\\Users\\Public\\Documents"
  • OR create that non-existent folder
  • Run AutoCAD 2014 setup again
Product Support
david.lau
Message 2 of 4 (2,402 Views)
Re: Error 1606. Could not access network location Autodesk\AutoCAD 2014\R19.1
01-16-2014 12:24 PM in reply to: wgmdev
Thanks for the tip/workaround.
David Lau
New Member
RonnySimonsen
Message 3 of 4 (1,117 Views)
SOLVED (Re: Error 1606. Could not access network location....
05-28-2014 12:35 AM in reply to: wgmdev
Hi!
I did try this because userprofiles is stored on partition D:\
This didn't work, so thats why i asked here in forum.
Now i discoverd that the real path is not D:\Users\Public\... but ...\Users\... has been renamed to norwegian ...\Brukere\...
I edit registre to; D:\Brukere\Public\Documents and now it works.
This is an error that shouldnt be there at all. Autodesk should be so proffesional to can avoid such error. No other software have this kind og problem!
Autodesk! Fix this!
New Member
gouacht
Message 4 of 4 (876 Views)
06-16-2014 06:13 AM in reply to: wgmdev
Merci for your answers
