I'm trying to download Maya 2011 onto my computer (64bit Windows 7), but each time I get this error message in the log and it doesn't install
Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
I've tried to install the Visual C++ packet from Microsoft, but I get the following error message every time I try that:
Error 1935.An error occurred during the installation of assembly 'Microsoft.VC90.ATL,version= "9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86,type="win32"'. Please refer to Help and Support for more information. HRESULT:0x80070005.
Does anybody have any suggestions? I've tried installing several different C++ bases from Microsoft but they all direct me to variations of the above error message.
This is Microsoft component and usually running the System Update Readiness Tool should find/fix the related cause.
So please try
http://support.microsoft.com/kb/947821
If it doesn't help, please try post the vc*.log from %temp% folder, we can try to find the cause of failure.
Hello, I am having the same problem.
I also tried the Microsoft download link you posted and it's also not working.
This is the message im getting in my installation logfile:
2011/8/6:20:19:58 Hamza HAMZA-HP === Setup started on HAMZA-HP by Hamza ===
2011/8/6:20:19:58 Hamza HAMZA-HP Launch
2011/8/6:20:20:11 Hamza HAMZA-HP === Setup ended ===
2011/8/6:20:19:59 Hamza HAMZA-HP === Setup started on HAMZA-HP by Hamza ===
2011/8/6:20:19:59 Hamza HAMZA-HP Launch
2011/8/6:20:20:11 Hamza HAMZA-HP PageOpen LaunchDialog
2011/8/6:20:21:45 Hamza HAMZA-HP PageOpen LicenseDialog
2011/8/6:20:22:40 Hamza HAMZA-HP PageOpen ProductInfoDialog
2011/8/6:20:22:44 Hamza HAMZA-HP PageOpen ProductSelectionDialog2
2011/8/6:20:22:47 Hamza HAMZA-HP PageOpen FullProgressDialog
2011/8/6:20:22:48 Hamza HAMZA-HP Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): L:\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Hamza\AppData\Local\Temp\vcredist_x86_2005.log"" "
2011/8/6:20:22:53 Hamza HAMZA-HP Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
Could you please find an solution because this is pretty frustrating.
Thanks in advance!
