Installation & Licensing
1242 Views, 2 Replies
Error 1603?
I'm trying to download Maya 2011 onto my computer (64bit Windows 7), but each time I get this error message in the log and it doesn't install
Install    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1603
I've tried to install the Visual C++ packet from Microsoft, but I get the following error message every time I try that:
Error 1935.An error occurred during the installation of assembly 'Microsoft.VC90.ATL,version= "9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86,type="win32"'. Please refer to Help and Support for more information. HRESULT:0x80070005.
Does anybody have any suggestions? I've tried installing several different C++ bases from Microsoft but they all direct me to variations of the above error message.
2 REPLIES 2
hashim.mundol
This is Microsoft component and usually running the System Update Readiness Tool should find/fix the related cause.
So please try
http://support.microsoft.com/kb/947821
If it doesn't help, please try post the vc*.log from %temp% folder, we can try to find the cause of failure.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
in reply to: hashim.mundol
Hello, I am having the same problem.
I also tried the Microsoft download link you posted and it's also not working.
This is the message im getting in my installation logfile:
2011/8/6:20:19:58 Hamza HAMZA-HP === Setup started on HAMZA-HP by Hamza ===
2011/8/6:20:19:58 Hamza HAMZA-HP Launch
2011/8/6:20:20:11 Hamza HAMZA-HP === Setup ended ===
2011/8/6:20:19:59 Hamza HAMZA-HP === Setup started on HAMZA-HP by Hamza ===
2011/8/6:20:19:59 Hamza HAMZA-HP Launch
2011/8/6:20:20:11 Hamza HAMZA-HP PageOpen LaunchDialog
2011/8/6:20:21:45 Hamza HAMZA-HP PageOpen LicenseDialog
2011/8/6:20:22:40 Hamza HAMZA-HP PageOpen ProductInfoDialog
2011/8/6:20:22:44 Hamza HAMZA-HP PageOpen ProductSelectionDialog2
2011/8/6:20:22:47 Hamza HAMZA-HP PageOpen FullProgressDialog
2011/8/6:20:22:48 Hamza HAMZA-HP Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): L:\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Hamza\AppData\Local\Temp\vcredist_x86_2005.log"" "
2011/8/6:20:22:53 Hamza HAMZA-HP Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
Could you please find an solution because this is pretty frustrating.
Thanks in advance!
Tags (4)
Administrator Productivity
