I have revit and autocad mep 2013 on my computer. Trying to install revit 2014 now. First I had 1603 error on Microsoft Visual C++ remove the prerequisite on Setup.ini made some progress then another 1603 error on faro come up, also removed that on setup.ini. now it's giving me error 997. overlapped i/o operation is in progress. I have close all the program and windows during installing and also cleaned my temp folder.
Autodesk Building Design Premium 2014 Setup
2014/8/21:16:10:56 JLiu PC362 === Setup started on PC362 by JLiu ===
2014/8/21:16:10:56 JLiu PC362 Path_Length: 149
2014/8/21:16:10:56 JLiu PC362 Current Directory C:\2014 setup
2014/8/21:16:10:56 JLiu PC362 Launch
2014/8/21:16:10:56 JLiu PC362 CommandLine
2014/8/21:16:10:56 JLiu PC362 Current Directory C:\Users\JLiu\AppData\Local\Temp\_AIA9F5.tmp
2014/8/21:16:11:08 JLiu PC362 === Setup ended ===
2014/8/21:16:10:58 JLiu PC362 === Setup started on PC362 by JLiu ===
2014/8/21:16:10:58 JLiu PC362 Path_Length: 149
2014/8/21:16:10:58 JLiu PC362 Current Directory C:\Users\JLiu\AppData\Local\Temp\_AIA9F5.tmp
2014/8/21:16:10:58 JLiu PC362 Launch
2014/8/21:16:10:58 JLiu PC362 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\JLiu\AppData\Local\Temp\_AIA9F5.tmp\Setup\RevitSetup.dll
2014/8/21:16:10:58 JLiu PC362 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/21:16:11:08 JLiu PC362 PageOpen LaunchDialog
2014/8/21:16:11:31 JLiu PC362 PageOpen LicenseDialog
2014/8/21:16:11:36 JLiu PC362 PageOpen ProductInfoDialog
2014/8/21:16:12:13 JLiu PC362 PageOpen ProductSelectionDialog2
2014/8/21:16:12:23 JLiu PC362 PageOpen FullProgressDialog
2014/8/21:16:12:23 JLiu PC362 Installing Autodesk® Revit® 2014: TRANSFORMS="C:\2014 setup\x64\en-us\RVT2014\RVT2014.mst;C:\Users\JLiu\AppData\Local\Temp\_AIA9F5.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\2014 setup\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/21:16:12:39 JLiu PC362 Install Autodesk® Revit® 2014 Failed Installation aborted, Result=1603
2014/8/21:16:13:12 JLiu PC362 === Setup started on PC362 by JLiu ===
2014/8/21:16:13:12 JLiu PC362 Path_Length: 149
2014/8/21:16:13:12 JLiu PC362 Current Directory C:\2014 setup
2014/8/21:16:13:12 JLiu PC362 Launch
2014/8/21:16:13:12 JLiu PC362 CommandLine
2014/8/21:16:13:12 JLiu PC362 Current Directory C:\Users\JLiu\AppData\Local\Temp\_AIBC7C.tmp
2014/8/21:16:13:24 JLiu PC362 === Setup ended ===
2014/8/21:16:13:14 JLiu PC362 === Setup started on PC362 by JLiu ===
2014/8/21:16:13:14 JLiu PC362 Path_Length: 149
2014/8/21:16:13:14 JLiu PC362 Current Directory C:\Users\JLiu\AppData\Local\Temp\_AIBC7C.tmp
2014/8/21:16:13:14 JLiu PC362 Launch
2014/8/21:16:13:15 JLiu PC362 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\JLiu\AppData\Local\Temp\_AIBC7C.tmp\Setup\RevitSetup.dll
2014/8/21:16:13:15 JLiu PC362 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/21:16:13:24 JLiu PC362 PageOpen LaunchDialog
2014/8/21:16:13:26 JLiu PC362 PageOpen LicenseDialog
2014/8/21:16:13:29 JLiu PC362 PageOpen ProductInfoDialog
2014/8/21:16:14:30 JLiu PC362 PageOpen ProductSelectionDialog2
2014/8/21:16:14:40 JLiu PC362 PageOpen FullProgressDialog
2014/8/21:16:14:40 JLiu PC362 Installing Autodesk® Revit® 2014: TRANSFORMS="C:\2014 setup\x64\en-us\RVT2014\RVT2014.mst;C:\Users\JLiu\AppData\Local\Temp\_AIBC7C.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\2014 setup\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/21:16:14:46 JLiu PC362 Install Autodesk® Revit® 2014 Failed Installation aborted, Result=1603
2014/8/21:16:20:08 JLiu PC362 === Setup started on PC362 by JLiu ===
2014/8/21:16:20:08 JLiu PC362 Path_Length: 149
2014/8/21:16:20:08 JLiu PC362 Current Directory C:\2014 setup
2014/8/21:16:20:08 JLiu PC362 Launch
2014/8/21:16:20:08 JLiu PC362 CommandLine
2014/8/21:16:20:08 JLiu PC362 Current Directory C:\Users\JLiu\AppData\Local\Temp\_AI146B.tmp
2014/8/21:16:20:20 JLiu PC362 === Setup ended ===
2014/8/21:16:20:40 JLiu PC362 === Setup started on PC362 by JLiu ===
2014/8/21:16:20:40 JLiu PC362 Path_Length: 149
2014/8/21:16:20:40 JLiu PC362 Current Directory C:\2014 setup
2014/8/21:16:20:40 JLiu PC362 Launch
2014/8/21:16:20:40 JLiu PC362 CommandLine
2014/8/21:16:20:40 JLiu PC362 An instance of setup is already running. Only one instance of setup can run at a time.2014/8/21:16:20:43 JLiu PC362 === Setup ended ===
2014/8/21:16:20:58 JLiu PC362 === Setup started on PC362 by JLiu ===
2014/8/21:16:20:58 JLiu PC362 Path_Length: 149
2014/8/21:16:20:58 JLiu PC362 Current Directory C:\2014 setup
2014/8/21:16:20:58 JLiu PC362 Launch
2014/8/21:16:20:58 JLiu PC362 CommandLine
2014/8/21:16:20:58 JLiu PC362 An instance of setup is already running. Only one instance of setup can run at a time.2014/8/21:16:21:04 JLiu PC362 === Setup ended ===
2014/8/21:16:20:10 JLiu PC362 === Setup started on PC362 by JLiu ===
2014/8/21:16:20:10 JLiu PC362 Path_Length: 149
2014/8/21:16:20:10 JLiu PC362 Current Directory C:\Users\JLiu\AppData\Local\Temp\_AI146B.tmp
2014/8/21:16:20:10 JLiu PC362 Launch
2014/8/21:16:20:10 JLiu PC362 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\JLiu\AppData\Local\Temp\_AI146B.tmp\Setup\RevitSetup.dll
2014/8/21:16:20:10 JLiu PC362 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/21:16:20:20 JLiu PC362 PageOpen LaunchDialog
2014/8/21:16:20:32 JLiu PC362 PageOpen LicenseDialog
2014/8/21:16:20:34 JLiu PC362 PageOpen ProductInfoDialog
2014/8/21:16:20:36 JLiu PC362 PageOpen LicenseDialog
2014/8/21:16:20:37 JLiu PC362 PageOpen LaunchDialog
2014/8/21:16:21:30 JLiu PC362 PageOpen LicenseDialog
2014/8/21:16:21:32 JLiu PC362 PageOpen ProductInfoDialog
2014/8/21:16:21:42 JLiu PC362 PageOpen ProductSelectionDialog2
2014/8/21:16:22:32 JLiu PC362 PageOpen FullProgressDialog
2014/8/21:16:22:32 JLiu PC362 Installing Autodesk® Revit® 2014: TRANSFORMS="C:\2014 setup\x64\en-us\RVT2014\RVT2014.mst;C:\Users\JLiu\AppData\Local\Temp\_AI146B.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\2014 setup\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/21:16:22:40 JLiu PC362 Install Autodesk® Revit® 2014 Failed Installation aborted, Result=1603
2014/8/21:16:22:40 JLiu PC362 PageOpen InstallCompleteDialog
2014/8/21:16:24:01 JLiu PC362 === Setup ended ===
2014/8/21:16:27:17 JLiu PC362 === Setup started on PC362 by JLiu ===
2014/8/21:16:27:17 JLiu PC362 Path_Length: 149
2014/8/21:16:27:17 JLiu PC362 Current Directory C:\2014 setup
2014/8/21:16:27:17 JLiu PC362 Launch
2014/8/21:16:27:17 JLiu PC362 CommandLine
2014/8/21:16:27:17 JLiu PC362 Current Directory C:\Users\JLiu\AppData\Local\Temp\_AI317B.tmp
2014/8/21:16:28:14 JLiu PC362 === Setup ended ===
2014/8/21:16:27:25 JLiu PC362 === Setup started on PC362 by JLiu ===
2014/8/21:16:27:25 JLiu PC362 Path_Length: 149
2014/8/21:16:27:25 JLiu PC362 Current Directory C:\Users\JLiu\AppData\Local\Temp\_AI317B.tmp
2014/8/21:16:27:25 JLiu PC362 Launch
2014/8/21:16:27:26 JLiu PC362 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\JLiu\AppData\Local\Temp\_AI317B.tmp\Setup\RevitSetup.dll
2014/8/21:16:27:26 JLiu PC362 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/21:16:28:15 JLiu PC362 PageOpen LaunchDialog
2014/8/21:16:28:18 JLiu PC362 PageOpen LicenseDialog
2014/8/21:16:28:21 JLiu PC362 PageOpen ProductInfoDialog
2014/8/21:16:30:31 JLiu PC362 PageOpen ProductSelectionDialog2
2014/8/21:16:30:46 JLiu PC362 PageOpen FullProgressDialog
2014/8/21:16:30:46 JLiu PC362 Installing Autodesk® Revit® 2014: TRANSFORMS="C:\2014 setup\x64\en-us\RVT2014\RVT2014.mst;C:\Users\JLiu\AppData\Local\Temp\_AI317B.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\2014 setup\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/21:16:30:51 JLiu PC362 Install Autodesk® Revit® 2014 Failed Installation aborted, Result=1603
2014/8/21:16:31:45 JLiu PC362 === Setup started on PC362 by JLiu ===
2014/8/21:16:31:45 JLiu PC362 Path_Length: 149
2014/8/21:16:31:45 JLiu PC362 Current Directory C:\2014 setup
2014/8/21:16:31:45 JLiu PC362 Launch
2014/8/21:16:31:45 JLiu PC362 CommandLine
2014/8/21:16:31:45 JLiu PC362 Current Directory C:\Users\JLiu\AppData\Local\Temp\_AI46CF.tmp
2014/8/21:16:31:59 JLiu PC362 === Setup ended ===
2014/8/21:16:31:47 JLiu PC362 === Setup started on PC362 by JLiu ===
2014/8/21:16:31:47 JLiu PC362 Path_Length: 149
2014/8/21:16:31:47 JLiu PC362 Current Directory C:\Users\JLiu\AppData\Local\Temp\_AI46CF.tmp
2014/8/21:16:31:47 JLiu PC362 Launch
2014/8/21:16:31:48 JLiu PC362 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\JLiu\AppData\Local\Temp\_AI46CF.tmp\Setup\RevitSetup.dll
2014/8/21:16:31:48 JLiu PC362 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/21:16:31:59 JLiu PC362 PageOpen LaunchDialog
2014/8/21:16:32:00 JLiu PC362 PageOpen LicenseDialog
2014/8/21:16:32:02 JLiu PC362 PageOpen ProductInfoDialog
2014/8/21:16:33:05 JLiu PC362 PageOpen ProductSelectionDialog2
2014/8/21:16:33:44 JLiu PC362 PageOpen FullProgressDialog
2014/8/21:16:33:44 JLiu PC362 Installing Autodesk® Revit® 2014: TRANSFORMS="C:\2014 setup\x64\en-us\RVT2014\RVT2014.mst;C:\Users\JLiu\AppData\Local\Temp\_AI46CF.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\2014 setup\" INSTALLDIR="C:\Program Files\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/21:16:33:56 JLiu PC362 Install Autodesk® Revit® 2014 Failed Installation aborted, Result=1603
2014/8/21:16:51:19 JLiu PC362 === Setup started on PC362 by JLiu ===
2014/8/21:16:51:19 JLiu PC362 Path_Length: 149
2014/8/21:16:51:19 JLiu PC362 Current Directory C:\2014 setup
2014/8/21:16:51:19 JLiu PC362 Launch
2014/8/21:16:51:19 JLiu PC362 CommandLine
2014/8/21:16:51:19 JLiu PC362 Current Directory C:\Users\JLiu\AppData\Local\Temp\_AI33DC.tmp
2014/8/21:16:51:33 JLiu PC362 === Setup ended ===
2014/8/21:16:51:48 JLiu PC362 === Setup started on PC362 by JLiu ===
2014/8/21:16:51:48 JLiu PC362 Path_Length: 149
2014/8/21:16:51:48 JLiu PC362 Current Directory C:\2014 setup
2014/8/21:16:51:48 JLiu PC362 Launch
2014/8/21:16:51:48 JLiu PC362 CommandLine
2014/8/21:16:51:48 JLiu PC362 An instance of setup is already running. Only one instance of setup can run at a time.2014/8/21:16:51:49 JLiu PC362 === Setup ended ===
2014/8/21:16:51:22 JLiu PC362 === Setup started on PC362 by JLiu ===
2014/8/21:16:51:22 JLiu PC362 Path_Length: 149
2014/8/21:16:51:22 JLiu PC362 Current Directory C:\Users\JLiu\AppData\Local\Temp\_AI33DC.tmp
2014/8/21:16:51:22 JLiu PC362 Launch
2014/8/21:16:51:23 JLiu PC362 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\JLiu\AppData\Local\Temp\_AI33DC.tmp\Setup\RevitSetup.dll
2014/8/21:16:51:23 JLiu PC362 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/21:16:51:33 JLiu PC362 PageOpen LaunchDialog
2014/8/21:16:51:36 JLiu PC362 PageOpen LicenseDialog
2014/8/21:16:51:38 JLiu PC362 PageOpen LaunchDialog
2014/8/21:16:52:43 JLiu PC362 PageOpen LicenseDialog
2014/8/21:16:52:46 JLiu PC362 PageOpen ProductInfoDialog
2014/8/21:16:52:57 JLiu PC362 PageOpen ProductSelectionDialog2
2014/8/21:16:53:08 JLiu PC362 PageOpen FullProgressDialog
2014/8/21:16:53:08 JLiu PC362 Installing Autodesk® Revit® 2014: TRANSFORMS="C:\2014 setup\x64\en-us\RVT2014\RVT2014.mst;C:\Users\JLiu\AppData\Local\Temp\_AI33DC.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\2014 setup\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/21:16:53:24 JLiu PC362 Install Autodesk® Revit® 2014 Failed Installation aborted, Result=1603
2014/8/21:16:54:42 JLiu PC362 === Setup started on PC362 by JLiu ===
2014/8/21:16:54:42 JLiu PC362 Path_Length: 149
2014/8/21:16:54:42 JLiu PC362 Current Directory C:\2014 setup
2014/8/21:16:54:42 JLiu PC362 Launch
2014/8/21:16:54:42 JLiu PC362 CommandLine
2014/8/21:16:54:42 JLiu PC362 Current Directory C:\Users\JLiu\AppData\Local\Temp\_AI49CC.tmp
2014/8/21:16:54:56 JLiu PC362 === Setup ended ===
2014/8/21:16:54:44 JLiu PC362 === Setup started on PC362 by JLiu ===
2014/8/21:16:54:44 JLiu PC362 Path_Length: 149
2014/8/21:16:54:44 JLiu PC362 Current Directory C:\Users\JLiu\AppData\Local\Temp\_AI49CC.tmp
2014/8/21:16:54:44 JLiu PC362 Launch
2014/8/21:16:54:45 JLiu PC362 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\JLiu\AppData\Local\Temp\_AI49CC.tmp\Setup\RevitSetup.dll
2014/8/21:16:54:45 JLiu PC362 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/21:16:54:56 JLiu PC362 PageOpen LaunchDialog
2014/8/21:16:55:42 JLiu PC362 PageOpen LicenseDialog
2014/8/21:16:55:43 JLiu PC362 PageOpen ProductInfoDialog
2014/8/21:16:56:49 JLiu PC362 PageOpen ProductSelectionDialog2
2014/8/21:16:57:17 JLiu PC362 PageOpen FullProgressDialog
2014/8/21:16:57:17 JLiu PC362 Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\2014 setup\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\JLiu\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/8/21:16:57:18 JLiu PC362 Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2014/8/21:17:01:34 JLiu PC362 === Setup started on PC362 by JLiu ===
2014/8/21:17:01:34 JLiu PC362 Path_Length: 149
2014/8/21:17:01:34 JLiu PC362 Current Directory C:\2014 setup
2014/8/21:17:01:34 JLiu PC362 Launch
2014/8/21:17:01:34 JLiu PC362 CommandLine
2014/8/21:17:01:34 JLiu PC362 Current Directory C:\Users\JLiu\AppData\Local\Temp\_AI92CD.tmp
2014/8/21:17:01:48 JLiu PC362 === Setup ended ===
2014/8/21:17:01:36 JLiu PC362 === Setup started on PC362 by JLiu ===
2014/8/21:17:01:36 JLiu PC362 Path_Length: 149
2014/8/21:17:01:36 JLiu PC362 Current Directory C:\Users\JLiu\AppData\Local\Temp\_AI92CD.tmp
2014/8/21:17:01:36 JLiu PC362 Launch
2014/8/21:17:01:37 JLiu PC362 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\JLiu\AppData\Local\Temp\_AI92CD.tmp\Setup\RevitSetup.dll
2014/8/21:17:01:37 JLiu PC362 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/21:17:01:48 JLiu PC362 PageOpen LaunchDialog
2014/8/21:17:02:03 JLiu PC362 PageOpen LicenseDialog
2014/8/21:17:02:05 JLiu PC362 PageOpen ProductInfoDialog
2014/8/21:17:03:01 JLiu PC362 PageOpen ProductSelectionDialog2
2014/8/21:17:03:59 JLiu PC362 PageOpen FullProgressDialog
2014/8/21:17:03:59 JLiu PC362 Installing Autodesk® Revit® 2014: TRANSFORMS="C:\2014 setup\x64\en-us\RVT2014\RVT2014.mst;C:\Users\JLiu\AppData\Local\Temp\_AI92CD.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\2014 setup\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/21:17:04:07 JLiu PC362 Install Autodesk® Revit® 2014 Failed Installation aborted, Result=1603
2014/8/21:17:06:43 JLiu PC362 === Setup started on PC362 by JLiu ===
2014/8/21:17:06:43 JLiu PC362 Path_Length: 149
2014/8/21:17:06:43 JLiu PC362 Current Directory C:\2014 setup
2014/8/21:17:06:43 JLiu PC362 Launch
2014/8/21:17:06:43 JLiu PC362 CommandLine
2014/8/21:17:06:43 JLiu PC362 Current Directory C:\Users\JLiu\AppData\Local\Temp\_AI4AF4.tmp
2014/8/21:17:06:54 JLiu PC362 === Setup ended ===
2014/8/21:17:06:45 JLiu PC362 === Setup started on PC362 by JLiu ===
2014/8/21:17:06:45 JLiu PC362 Path_Length: 149
2014/8/21:17:06:45 JLiu PC362 Current Directory C:\Users\JLiu\AppData\Local\Temp\_AI4AF4.tmp
2014/8/21:17:06:45 JLiu PC362 Launch
2014/8/21:17:06:45 JLiu PC362 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\JLiu\AppData\Local\Temp\_AI4AF4.tmp\Setup\RevitSetup.dll
2014/8/21:17:06:45 JLiu PC362 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/21:17:06:54 JLiu PC362 PageOpen LaunchDialog
2014/8/21:17:06:58 JLiu PC362 PageOpen LicenseDialog
2014/8/21:17:07:00 JLiu PC362 PageOpen ProductInfoDialog
2014/8/21:17:08:06 JLiu PC362 PageOpen ProductSelectionDialog2
2014/8/21:17:08:20 JLiu PC362 PageOpen FullProgressDialog
2014/8/21:17:08:20 JLiu PC362 Installing Autodesk® Revit® 2014: TRANSFORMS="C:\2014 setup\x64\en-us\RVT2014\RVT2014.mst;C:\Users\JLiu\AppData\Local\Temp\_AI4AF4.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\2014 setup\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/21:17:08:58 JLiu PC362 Install Autodesk® Revit® 2014 Failed Installation aborted, Result=1603
Remove all installed versions of Microsoft Visual C++. Go into your software install folder (C:\Autodesk or similar) and go into the 3rd party folder, and into both the x86>VCRedist and x64>VCRedist folders and install all files in there. (the .exe files). Then run the main install again.
