Installation & Licensing
Error 1603 installing Softimage 2014
2 REPLIES 2
1328 Views, 2 Replies
Hi, I'm trying to install Entertainment Creation Suite 2014 but the installation program always terminate with error. Here is the log I get from Softimage. DirectX Runtime failet too but it seems that the programm just ignor this.
I (s) (44:60) [18:51:37:105]: Das Produkt wurde durch Windows Installer installiert. Produktname: Autodesk Softimage 2014. Produktversion: 12.0.0000. Produktsprache: 1033. Hersteller: Autodesk. Erfolg- bzw. Fehlerstatus der Installation: 1603.
MSI (s) (44:60) [18:51:37:106]: Attempting to delete file C:\Windows\Installer\1afc1f.mst
MSI (s) (44:60) [18:51:37:106]: Unable to delete the file. LastError = 32
MSI (s) (44:60) [18:51:37:110]: Deferring clean up of packages/files, if any exist
MSI (s) (44:60) [18:51:37:110]: Attempting to delete file C:\Windows\Installer\1afc1f.mst
MSI (s) (44:60) [18:51:37:110]: MainEngineThread is returning 1603
MSI (s) (44:28) [18:51:37:110]: No System Restore sequence number for this installation.
=== Logging stopped: 18.01.2014 18:51:37 ===
MSI (s) (44:28) [18:51:37:111]: User policy value 'DisableRollback' is 0
MSI (s) (44:28) [18:51:37:111]: Machine policy value 'DisableRollback' is 0
MSI (s) (44:28) [18:51:37:111]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (44:28) [18:51:37:111]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (44:28) [18:51:37:112]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (44:28) [18:51:37:113]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (44:28) [18:51:37:113]: Restoring environment variables
MSI (s) (44:28) [18:51:37:113]: Destroying RemoteAPI object.
MSI (s) (44:88) [18:51:37:113]: Custom Action Manager thread ending.
MSI (c) (84:64) [18:51:37:114]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (84:64) [18:51:37:114]: MainEngineThread is returning 1603
=== Verbose logging stopped: 18.01.2014 18:51:37 ===
Tags (2)
2 REPLIES 2
pendean
Search around here for that error: plenty if solutions to try.
Administrator Productivity
