Installation & Licensing
ERROR 1603 Instaling 3ds Entertainment Creation Suite 2013
3 REPLIES 3
RalphAX
450 Views, 3 Replies
Hi, every time I tried to install this software I get this message:
2012/11/26:23:32:07 Ralph RALPHAX === Setup started on RALPHAX by Ralph ===
2012/11/26:23:32:07 Ralph RALPHAX Launch
2012/11/26:23:32:14 Ralph RALPHAX === Setup ended ===
2012/11/26:23:32:09 Ralph RALPHAX === Setup started on RALPHAX by Ralph ===
2012/11/26:23:32:09 Ralph RALPHAX Launch
2012/11/26:23:32:14 Ralph RALPHAX PageOpen LaunchDialog
2012/11/26:23:32:49 Ralph RALPHAX PageOpen LicenseDialog
2012/11/26:23:32:51 Ralph RALPHAX PageOpen ProductInfoDialog
2012/11/26:23:34:11 Ralph RALPHAX PageOpen ProductSelectionDialog2
2012/11/26:23:34:48 Ralph RALPHAX PageOpen FullProgressDialog
2012/11/26:23:34:48 Ralph RALPHAX Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ralph\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/11/26:23:34:53 Ralph RALPHAX Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
I installed manually the vredist_x86_2005 and theres no problem, but still got this message when i tried to install the software,
Also, I deleted my temp files, execute the setup as adminsitrator, an yet no results.
Please help me!
3 REPLIES 3
Darin.Green
in reply to: RalphAX
Copy the media onto the hard drive. After the copy, navigate to the setup.ini file and open it with notepad. Browse to the following section:
[VCREDIST2005SP1ATLX86]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)
EXE_PATH=3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe
Modify the EXE_PATH value to the following:
EXE_PATH=ECHO
This workaround should bypass the MS Visual C++ 2005 installation and continue installing the remaining applications.
Let me know if this works.
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution
RalphAX
in reply to: Darin.Green
Hi, thanks, I tried what you told me but unfortunately didnt work; I stil get this log.
2012/11/27:22:48:51 Ralph RALPHAX === Setup started on RALPHAX by Ralph ===
2012/11/27:22:48:51 Ralph RALPHAX Launch
2012/11/27:22:48:57 Ralph RALPHAX === Setup ended ===
2012/11/27:22:48:53 Ralph RALPHAX === Setup started on RALPHAX by Ralph ===
2012/11/27:22:48:53 Ralph RALPHAX Launch
2012/11/27:22:48:57 Ralph RALPHAX PageOpen LaunchDialog
2012/11/27:22:48:58 Ralph RALPHAX PageOpen LicenseDialog
2012/11/27:22:49:01 Ralph RALPHAX PageOpen ProductInfoDialog
2012/11/27:22:50:20 Ralph RALPHAX PageOpen ProductSelectionDialog2
2012/11/27:22:50:29 Ralph RALPHAX PageOpen FullProgressDialog
2012/11/27:22:50:29 Ralph RALPHAX Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Users\Ralph\3DS\ECHO /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ralph\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/11/27:22:50:29 Ralph RALPHAX Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=2
Darin.Green
Ralph,
Attached the error log file and ini file to this thread or via private message.
Administrator Productivity
