i am trying to install AutoCAD 2011 via the silent Installation and getting following error:
InstallFARO LS 1.1.406.58 Succeeded
InstallAutodesk Material Library 2011 Succeeded
InstallAutodesk Material Library 2011 Base Image librarySucceeded
InstallAutoCAD 2011Failed Installation aborted, Result=1603
The weird thing is, that I ran the unattended installations with admin privileges. I also restarted the Computer several times and turned off virus protection. If I try to install AutoCad manually without any install.ini, it just works fine...
Does anyone have a clue ? 8.)
Not sure what command lines are used for silent install. documentation has all the silent install parameters
if you can post the Autocad 2011 install.log it might give more information on the error.
Hey thanks for your reply.
This morning I found a solution for the problem. Instead of choosing the standart installation in the deployment, I choosed the advantaged Installation. I selected all the components similar to the the standart installation. And now it works 8.)
Don´t know what was the fault but know I am happy
