I tried to install Revit 2014 (student version), but at the end of the installation I got a message saying that 'some products failed to install', which seems to mean ALL failed to install.
I really need this program to work, so I hope someone knows a solution?
This is the setup log file I got:
2013/11/1:11:04:27 Maurane MAURANE === Setup started on MAURANE by Maurane ===
2013/11/1:11:04:27 Maurane MAURANE Path_Length: 149
2013/11/1:11:04:27 Maurane MAURANE Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2013/11/1:11:04:27 Maurane MAURANE Launch
2013/11/1:11:04:27 Maurane MAURANE CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64... /SN 900-42547059 /PK 829F1 /student /skipEULA /akamai /auth /sid
2013/11/1:11:04:27 Maurane MAURANE Current Directory C:\Users\Maurane\AppData\Local\Temp\_AI3B0.tmp
2013/11/1:11:11:35 Maurane MAURANE === Setup ended ===
2013/11/1:11:04:34 Maurane MAURANE === Setup started on MAURANE by Maurane ===
2013/11/1:11:04:34 Maurane MAURANE Path_Length: 149
2013/11/1:11:04:34 Maurane MAURANE Current Directory C:\Users\Maurane\AppData\Local\Temp\_AI3B0.tmp
2013/11/1:11:04:34 Maurane MAURANE Launch
2013/11/1:11:04:39 Maurane MAURANE Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:11:35 Maurane MAURANE Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:11:35 Maurane MAURANE Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Maurane\AppData\Local\Temp\_AI3B0.tmp\Setup\RevitSetup.dll
2013/11/1:11:11:35 Maurane MAURANE Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/11/1:11:11:35 Maurane MAURANE PageOpen LaunchDialog
2013/11/1:11:17:15 Maurane MAURANE PageOpen LicenseDialog
2013/11/1:11:17:15 Maurane MAURANE PageOpen ProductInfoDialog
2013/11/1:11:17:15 Maurane MAURANE PageOpen ProductSelectionDialog2
2013/11/1:11:19:46 Maurane MAURANE PageOpen FullProgressDialog
2013/11/1:11:19:47 Maurane MAURANE Download Play VCREDIST2005X64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:20:14 Maurane MAURANE Download Complete VCREDIST2005X64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:20:14 Maurane MAURANE Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Maurane\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/11/1:11:20:56 Maurane MAURANE Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2013/11/1:11:20:57 Maurane MAURANE Download Play KB958314ATLX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:20:58 Maurane MAURANE Download Complete KB958314ATLX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:20:58 Maurane MAURANE Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:11:21:08 Maurane MAURANE Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2013/11/1:11:21:09 Maurane MAURANE Download Play KB958314MFCX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:22:08 Maurane MAURANE Download Complete KB958314MFCX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:22:08 Maurane MAURANE Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:11:22:31 Maurane MAURANE Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2013/11/1:11:22:32 Maurane MAURANE Download Play KB958314CRTX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:22:40 Maurane MAURANE Download Complete KB958314CRTX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:22:40 Maurane MAURANE Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:11:22:58 Maurane MAURANE Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2013/11/1:11:22:59 Maurane MAURANE Download Play KB958314OPENMPX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:22:59 Maurane MAURANE Download Complete KB958314OPENMPX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:22:59 Maurane MAURANE Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:11:23:15 Maurane MAURANE Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2013/11/1:11:23:16 Maurane MAURANE Download Play KB958314ATLX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:23:17 Maurane MAURANE Download Complete KB958314ATLX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:23:17 Maurane MAURANE Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:11:23:26 Maurane MAURANE Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2013/11/1:11:23:27 Maurane MAURANE Download Play KB958314MFCX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:24:34 Maurane MAURANE Download Complete KB958314MFCX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:24:34 Maurane MAURANE Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:11:24:56 Maurane MAURANE Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2013/11/1:11:24:58 Maurane MAURANE Download Play KB958314CRTX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:25:06 Maurane MAURANE Download Complete KB958314CRTX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:25:06 Maurane MAURANE Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:11:25:26 Maurane MAURANE Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2013/11/1:11:25:27 Maurane MAURANE Download Play KB958314OPENMPX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:25:28 Maurane MAURANE Download Complete KB958314OPENMPX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:25:28 Maurane MAURANE Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:11:25:44 Maurane MAURANE Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2013/11/1:11:25:45 Maurane MAURANE Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:26:43 Maurane MAURANE Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:26:43 Maurane MAURANE Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/11/1:11:27:23 Maurane MAURANE Install DirectX® Runtime Succeeded
2013/11/1:11:27:23 Maurane MAURANE Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:11:28:19 Maurane MAURANE Install FaroSDK Succeeded
2013/11/1:11:28:20 Maurane MAURANE Download Play RVT2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:14:04:56 Maurane MAURANE Download Complete RVT2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:14:04:56 Maurane MAURANE Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\Maurane\AppData\Local\Temp\_AI3B0.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:16:10:48 Maurane MAURANE Install Autodesk® Revit® 2014 Succeeded
2013/11/1:16:10:51 Maurane MAURANE Download Play RVT2014_en-us http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:16:13:49 Maurane MAURANE Download Complete RVT2014_en-us http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:16:13:50 Maurane MAURANE Installing Autodesk® Revit® 2014 Language Pack: TRANSFORMS="C:\Users\Maurane\AppData\Local\Temp\_AI3B0.tmp\_la4B1C.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:16:14:11 Maurane MAURANE Install Autodesk® Revit® 2014 Language Pack Succeeded
2013/11/1:16:14:12 Maurane MAURANE Installing Autodesk Workflows 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:16:14:18 Maurane MAURANE Install Autodesk Workflows 2014 Succeeded
2013/11/1:16:14:20 Maurane MAURANE Download Play CM2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:16:22:41 Maurane MAURANE Download Complete CM2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:16:22:42 Maurane MAURANE Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:16:23:27 Maurane MAURANE Install Autodesk Material Library 2014 Succeeded
2013/11/1:16:23:28 Maurane MAURANE Download Play CMILB2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:16:38:46 Maurane MAURANE Download Complete CMILB2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:16:38:46 Maurane MAURANE Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:16:39:16 Maurane MAURANE Install Autodesk Material Library 2014 - Base Image Library Succeeded
2013/11/1:16:39:19 Maurane MAURANE Download Play CMILL2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:17:14:48 Maurane MAURANE Download Complete CMILL2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:17:14:48 Maurane MAURANE Installing Autodesk Material Library 2014 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:17:15:18 Maurane MAURANE Install Autodesk Material Library 2014 - Low Image Library Succeeded
2013/11/1:17:15:21 Maurane MAURANE Download Play CMILM2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:18:21:31 Maurane MAURANE Download Error CMILM2014 <B>Connection has expired.</B>Please Install Now again from the Autodesk website. http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:18:21:32 Maurane MAURANE Download Aborted CMILM2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:18:21:32 Maurane MAURANE Install Autodesk Material Library 2014 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603
2013/11/1:18:21:54 Maurane MAURANE Rollback Autodesk Material Library 2014 - Low Image Library Succeeded
2013/11/1:18:22:12 Maurane MAURANE Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2013/11/1:18:22:46 Maurane MAURANE Rollback Autodesk Material Library 2014 Succeeded
2013/11/1:18:22:50 Maurane MAURANE Rollback Autodesk Workflows 2014 Succeeded
2013/11/1:18:22:56 Maurane MAURANE Rollback Autodesk® Revit® 2014 Language Pack Succeeded
2013/11/1:18:30:46 Maurane MAURANE Rollback Autodesk® Revit® 2014 Succeeded
2013/11/1:18:30:54 Maurane MAURANE Rollback FaroSDK Succeeded
2013/11/1:18:30:54 Maurane MAURANE Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/11/1:18:31:02 Maurane MAURANE Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2013/11/1:18:31:15 Maurane MAURANE Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2013/11/1:18:31:24 Maurane MAURANE Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2013/11/1:18:31:28 Maurane MAURANE Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2013/11/1:18:31:36 Maurane MAURANE Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2013/11/1:18:31:43 Maurane MAURANE Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2013/11/1:18:31:52 Maurane MAURANE Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2013/11/1:18:31:57 Maurane MAURANE Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2013/11/1:18:31:57 Maurane MAURANE Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
Hello and welcome to the forums Maurane,
Based on the logs, downloading Autodesk Material Library 2014 – Medium Image Library fails during your Revit 2014 installation.
I would suggest to download Revit 2014 via Autodesk virtual agent interface:
Then follow general installation steps we posted on our Up and Ready blog, click here.
i had that same problem but through inventor. lt downloaded fine but when it wanted to extract necessary files, it gave me "File Corrupt Error." what should I do? i'm using the Inventor Pro 2014 version also. please help
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
