Installation & Licensing
Error 1603 and 1619 when installing Inventor 2014!!!
3 REPLIES 3
731 Views, 3 Replies
Hey guys,
I tried to install Inventor 2014 (student version) but the installation always leaves a message saying "some products failed to install"
I really need to install this program for school. Does anyone know a solution???
This is the installation log:
2014/4/17:21:23:32 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/17:21:23:32 xjinnyy JINNY Path_Length: 182
2014/4/17:21:23:32 xjinnyy JINNY Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/4/17:21:23:32 xjinnyy JINNY Launch
2014/4/17:21:23:32 xjinnyy JINNY CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_S... /SN 900-46646903 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/17:21:23:32 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AI1D4F.tmp
2014/4/17:21:31:44 xjinnyy JINNY === Setup ended ===
2014/4/17:21:23:33 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/17:21:23:33 xjinnyy JINNY Path_Length: 182
2014/4/17:21:23:33 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AI1D4F.tmp
2014/4/17:21:23:33 xjinnyy JINNY Launch
2014/4/17:21:23:35 xjinnyy JINNY Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/SETU...
2014/4/17:21:31:42 xjinnyy JINNY Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/SETU...
2014/4/17:21:31:42 xjinnyy JINNY Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\xjinnyy\AppData\Local\Temp\_AI1D4F.tmp\Setup\InventorUI.dll
2014/4/17:21:31:42 xjinnyy JINNY Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/17:21:31:44 xjinnyy JINNY PageOpen LaunchDialog
2014/4/17:21:32:54 xjinnyy JINNY Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2014/4/17:21:32:54 xjinnyy JINNY Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2014/4/17:21:32:54 xjinnyy JINNY Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2014/4/17:21:33:40 xjinnyy JINNY PageOpen LicenseDialog
2014/4/17:21:33:40 xjinnyy JINNY PageOpen ProductInfoDialog
2014/4/17:21:33:41 xjinnyy JINNY PageOpen InventorFlavorSelectionDialog
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==DefaultLanguage: en-us
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==InstallName: INVENTOR
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==ProductName: Autodesk Inventor 2014
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==DisplayName: Autodesk® Inventor® 2014
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==DeploymentName:
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==SetupTitle: Autodesk Inventor 2014
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==ConfigTransform:
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==ExeParams:
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==ProductCode: {7F4DD591-1864-0001-0000-7107D70F3DB4}
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==SupportLink:
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==InfotainmentLink:
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==MsiFileName: inventor.msi
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==AdminImageConfigName: Imgx64
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==AdminImageRoot:
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==GetBaseDeploymentName:
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==DeploymentLocation:
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==DocumentLink: http://autodesk.com/wikihelp-inventor-install-2014-enu
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==InstallDeploymentShortcut:
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==ModifyDeploymentShortcut:
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==SetupLockType: 2
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==SetupNetworkType: 1
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==SystemLocale: 1033
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==EvalMsiFilePath: C:\Users\xjinnyy\AppData\Local\Temp\_AI1D4F.tmp\SetupRes\eval.msi
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2014\EULA
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==InstallLogPath: C:\Users\xjinnyy\AppData\Local\Temp\Inventor2014Install.log
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==ConfigFile: C:\Users\xjinnyy\AppData\Local\Temp\_AI1D4F.tmp\Setup.ini
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==SetupPath: C:\Users\xjinnyy\AppData\Local\Temp\_AI1D4F.tmp\
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==NetworkLogPath:
2014/4/17:21:33:41 xjinnyy JINNY Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2014
2014/4/17:21:34:24 xjinnyy JINNY Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2014/4/17:21:34:24 xjinnyy JINNY PageOpen ProductSelectionDialog2
2014/4/17:21:38:19 xjinnyy JINNY PageOpen FullProgressDialog
2014/4/17:21:38:34 xjinnyy JINNY Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/VCRE...
2014/4/17:21:38:59 xjinnyy JINNY Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/VCRE...
2014/4/17:21:38:59 xjinnyy JINNY Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\xjinnyy\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/17:21:39:32 xjinnyy JINNY Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded
2014/4/17:21:39:37 xjinnyy JINNY Download Play VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/VCRE...
2014/4/17:21:40:09 xjinnyy JINNY Download Complete VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/VCRE...
2014/4/17:21:40:09 xjinnyy JINNY Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\xjinnyy\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/17:21:40:23 xjinnyy JINNY Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2014/4/17:21:40:28 xjinnyy JINNY Download Play VCREDIST2008SP1X64_6161 http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/VCRE...
2014/4/17:21:41:31 xjinnyy JINNY Download Complete VCREDIST2008SP1X64_6161 http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/VCRE...
2014/4/17:21:41:31 xjinnyy JINNY Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2014/4/17:21:42:18 xjinnyy JINNY Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2014/4/17:21:44:22 xjinnyy JINNY Download Play CM http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CM.t...
2014/4/17:21:52:32 xjinnyy JINNY Download Complete CM http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CM.t...
2014/4/17:21:52:32 xjinnyy JINNY Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/17:21:53:26 xjinnyy JINNY Install Autodesk Material Library 2014 Succeeded
2014/4/17:21:53:27 xjinnyy JINNY Download Play CMILB http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/17:21:56:07 xjinnyy JINNY Download Complete CMILB http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/17:21:56:07 xjinnyy JINNY Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/17:21:56:42 xjinnyy JINNY Install Autodesk Material Library 2014 - Base Image Library Succeeded
2014/4/17:21:56:42 xjinnyy JINNY Installing VBA Runtime: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/17:21:56:45 xjinnyy JINNY Install VBA Runtime Succeeded
2014/4/17:21:56:45 xjinnyy JINNY Installing VBA Runtime ENG Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/17:21:56:46 xjinnyy JINNY Install VBA Runtime ENG Language Pack Succeeded
2014/4/17:21:56:47 xjinnyy JINNY Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/DIRE...
2014/4/17:21:56:57 xjinnyy JINNY Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/DIRE...
2014/4/17:21:56:57 xjinnyy JINNY Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/17:21:57:02 xjinnyy JINNY Install DirectX® Runtime Succeeded
2014/4/17:21:57:02 xjinnyy JINNY Download Play CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/17:22:13:52 xjinnyy JINNY Download Error CMILL <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/17:22:14:12 xjinnyy JINNY Download Error CMILL <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/17:22:14:52 xjinnyy JINNY Download Error CMILL <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/17:22:22:19 xjinnyy JINNY Download Aborted CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/17:22:22:19 xjinnyy JINNY Install Autodesk Material Library 2014 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2014/4/17:22:22:20 xjinnyy JINNY Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/4/17:22:22:20 xjinnyy JINNY PageOpen InstallCompleteDialog
2014/4/17:22:22:39 xjinnyy JINNY === Setup ended ===
2014/4/17:23:11:40 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/17:23:11:40 xjinnyy JINNY Path_Length: 182
2014/4/17:23:11:40 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AI183C.tmp
2014/4/17:23:11:40 xjinnyy JINNY Launch
2014/4/17:23:11:42 xjinnyy JINNY === Setup ended ===
2014/4/17:23:11:39 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/17:23:11:39 xjinnyy JINNY Path_Length: 182
2014/4/17:23:11:39 xjinnyy JINNY Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/4/17:23:11:39 xjinnyy JINNY Launch
2014/4/17:23:11:39 xjinnyy JINNY CommandLine
2014/4/17:23:11:39 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AI183C.tmp
2014/4/17:23:14:37 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/17:23:14:37 xjinnyy JINNY Path_Length: 182
2014/4/17:23:14:37 xjinnyy JINNY Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/4/17:23:14:37 xjinnyy JINNY Launch
2014/4/17:23:14:37 xjinnyy JINNY CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_S... /SN 900-46646903 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/17:23:14:37 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AID1AF.tmp
2014/4/17:23:17:05 xjinnyy JINNY === Setup ended ===
2014/4/17:23:14:39 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/17:23:14:39 xjinnyy JINNY Path_Length: 182
2014/4/17:23:14:39 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AID1AF.tmp
2014/4/17:23:14:39 xjinnyy JINNY Launch
2014/4/17:23:14:39 xjinnyy JINNY Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/SETU...
2014/4/17:23:17:04 xjinnyy JINNY Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/SETU...
2014/4/17:23:17:04 xjinnyy JINNY Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\xjinnyy\AppData\Local\Temp\_AID1AF.tmp\Setup\InventorUI.dll
2014/4/17:23:17:04 xjinnyy JINNY Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/17:23:17:05 xjinnyy JINNY PageOpen LaunchDialog
2014/4/17:23:17:12 xjinnyy JINNY Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2014/4/17:23:17:12 xjinnyy JINNY Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2014/4/17:23:17:12 xjinnyy JINNY Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2014/4/17:23:17:24 xjinnyy JINNY PageOpen LicenseDialog
2014/4/17:23:17:24 xjinnyy JINNY PageOpen ProductInfoDialog
2014/4/17:23:17:24 xjinnyy JINNY PageOpen InventorFlavorSelectionDialog
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==DefaultLanguage: en-us
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==InstallName: INVENTOR
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==ProductName: Autodesk Inventor 2014
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==DisplayName: Autodesk® Inventor® 2014
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==DeploymentName:
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==SetupTitle: Autodesk Inventor 2014
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==ConfigTransform:
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==ExeParams:
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==ProductCode: {7F4DD591-1864-0001-0000-7107D70F3DB4}
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==SupportLink:
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==InfotainmentLink:
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==MsiFileName: inventor.msi
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==AdminImageConfigName: Imgx64
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==AdminImageRoot:
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==GetBaseDeploymentName:
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==DeploymentLocation:
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==DocumentLink: http://autodesk.com/wikihelp-inventor-install-2014-enu
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==InstallDeploymentShortcut:
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==ModifyDeploymentShortcut:
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==SetupLockType: 2
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==SetupNetworkType: 1
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==SystemLocale: 1033
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==EvalMsiFilePath: C:\Users\xjinnyy\AppData\Local\Temp\_AID1AF.tmp\SetupRes\eval.msi
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2014\EULA
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==InstallLogPath: C:\Users\xjinnyy\AppData\Local\Temp\Inventor2014Install.log
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==ConfigFile: C:\Users\xjinnyy\AppData\Local\Temp\_AID1AF.tmp\Setup.ini
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==SetupPath: C:\Users\xjinnyy\AppData\Local\Temp\_AID1AF.tmp\
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==NetworkLogPath:
2014/4/17:23:17:24 xjinnyy JINNY Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2014
2014/4/17:23:17:30 xjinnyy JINNY Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2014/4/17:23:17:30 xjinnyy JINNY PageOpen ProductSelectionDialog2
2014/4/17:23:17:48 xjinnyy JINNY PageOpen FullProgressDialog
2014/4/17:23:17:48 xjinnyy JINNY Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/DIRE...
2014/4/17:23:17:55 xjinnyy JINNY Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/DIRE...
2014/4/17:23:17:55 xjinnyy JINNY Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/17:23:18:00 xjinnyy JINNY Install DirectX® Runtime Succeeded
2014/4/17:23:18:00 xjinnyy JINNY Download Play CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/17:23:24:15 xjinnyy JINNY Download Aborted CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/17:23:24:15 xjinnyy JINNY Install Autodesk Material Library 2014 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2014/4/17:23:24:16 xjinnyy JINNY Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/4/17:23:24:16 xjinnyy JINNY PageOpen InstallCompleteDialog
2014/4/17:23:45:44 xjinnyy JINNY === Setup ended ===
2014/4/18:00:17:05 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/18:00:17:05 xjinnyy JINNY Path_Length: 182
2014/4/18:00:17:05 xjinnyy JINNY Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/4/18:00:17:05 xjinnyy JINNY Launch
2014/4/18:00:17:05 xjinnyy JINNY CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_S... /SN 900-46646903 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/18:00:17:05 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AI1F1.tmp
2014/4/18:00:19:57 xjinnyy JINNY === Setup ended ===
2014/4/18:00:17:07 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/18:00:17:07 xjinnyy JINNY Path_Length: 182
2014/4/18:00:17:07 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AI1F1.tmp
2014/4/18:00:17:07 xjinnyy JINNY Launch
2014/4/18:00:17:07 xjinnyy JINNY Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/SETU...
2014/4/18:00:19:56 xjinnyy JINNY Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/SETU...
2014/4/18:00:19:56 xjinnyy JINNY Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\xjinnyy\AppData\Local\Temp\_AI1F1.tmp\Setup\InventorUI.dll
2014/4/18:00:19:56 xjinnyy JINNY Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/18:00:19:57 xjinnyy JINNY PageOpen LaunchDialog
2014/4/18:00:51:26 xjinnyy JINNY Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2014/4/18:00:51:26 xjinnyy JINNY Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2014/4/18:00:51:26 xjinnyy JINNY Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2014/4/18:00:51:37 xjinnyy JINNY PageOpen LicenseDialog
2014/4/18:00:51:37 xjinnyy JINNY PageOpen ProductInfoDialog
2014/4/18:00:51:37 xjinnyy JINNY PageOpen InventorFlavorSelectionDialog
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==DefaultLanguage: en-us
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==InstallName: INVENTOR
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==ProductName: Autodesk Inventor 2014
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==DisplayName: Autodesk® Inventor® 2014
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==DeploymentName:
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==SetupTitle: Autodesk Inventor 2014
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==ConfigTransform:
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==ExeParams:
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==ProductCode: {7F4DD591-1864-0001-0000-7107D70F3DB4}
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==SupportLink:
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==InfotainmentLink:
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==MsiFileName: inventor.msi
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==AdminImageConfigName: Imgx64
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==AdminImageRoot:
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==GetBaseDeploymentName:
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==DeploymentLocation:
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==DocumentLink: http://autodesk.com/wikihelp-inventor-install-2014-enu
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==InstallDeploymentShortcut:
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==ModifyDeploymentShortcut:
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==SetupLockType: 2
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==SetupNetworkType: 1
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==SystemLocale: 1033
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==EvalMsiFilePath: C:\Users\xjinnyy\AppData\Local\Temp\_AI1F1.tmp\SetupRes\eval.msi
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2014\EULA
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==InstallLogPath: C:\Users\xjinnyy\AppData\Local\Temp\Inventor2014Install.log
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==ConfigFile: C:\Users\xjinnyy\AppData\Local\Temp\_AI1F1.tmp\Setup.ini
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==SetupPath: C:\Users\xjinnyy\AppData\Local\Temp\_AI1F1.tmp\
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==NetworkLogPath:
2014/4/18:00:51:37 xjinnyy JINNY Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2014
2014/4/18:00:54:13 xjinnyy JINNY Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2014/4/18:00:54:13 xjinnyy JINNY PageOpen ProductSelectionDialog2
2014/4/18:00:54:21 xjinnyy JINNY PageOpen FullProgressDialog
2014/4/18:00:54:22 xjinnyy JINNY Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/DIRE...
2014/4/18:00:54:32 xjinnyy JINNY Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/DIRE...
2014/4/18:00:54:32 xjinnyy JINNY Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/18:00:54:35 xjinnyy JINNY Install DirectX® Runtime Succeeded
2014/4/18:00:54:35 xjinnyy JINNY Download Play CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/18:00:55:10 xjinnyy JINNY Download User Pause CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/18:00:55:10 xjinnyy JINNY Download Paused CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/18:00:55:19 xjinnyy JINNY Download User Resume CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/18:00:55:25 xjinnyy JINNY Download User Pause CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/18:00:55:25 xjinnyy JINNY Download Paused CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/18:00:55:30 xjinnyy JINNY Download User Cancel CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/18:00:55:30 xjinnyy JINNY Download Aborted CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/18:00:55:30 xjinnyy JINNY PageOpen InstallCompleteDialog
2014/4/18:00:55:36 xjinnyy JINNY === Setup ended ===
2014/4/18:11:11:49 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/18:11:11:49 xjinnyy JINNY Path_Length: 182
2014/4/18:11:11:49 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AIDDDC.tmp
2014/4/18:11:11:49 xjinnyy JINNY Launch
2014/4/18:11:11:54 xjinnyy JINNY === Setup ended ===
2014/4/18:11:11:48 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/18:11:11:48 xjinnyy JINNY Path_Length: 182
2014/4/18:11:11:48 xjinnyy JINNY Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/4/18:11:11:48 xjinnyy JINNY Launch
2014/4/18:11:11:48 xjinnyy JINNY CommandLine
2014/4/18:11:11:48 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AIDDDC.tmp
2014/4/18:11:25:15 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/18:11:25:15 xjinnyy JINNY Path_Length: 182
2014/4/18:11:25:15 xjinnyy JINNY Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/4/18:11:25:15 xjinnyy JINNY Launch
2014/4/18:11:25:15 xjinnyy JINNY CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_S... /SN 900-46646903 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/18:11:25:15 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AI2F7C.tmp
2014/4/18:11:32:02 xjinnyy JINNY === Setup ended ===
2014/4/18:11:25:17 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/18:11:25:17 xjinnyy JINNY Path_Length: 182
2014/4/18:11:25:17 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AI2F7C.tmp
2014/4/18:11:25:17 xjinnyy JINNY Launch
2014/4/18:11:25:33 xjinnyy JINNY Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/SETU...
2014/4/18:11:32:01 xjinnyy JINNY Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/SETU...
2014/4/18:11:32:01 xjinnyy JINNY Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\xjinnyy\AppData\Local\Temp\_AI2F7C.tmp\Setup\InventorUI.dll
2014/4/18:11:32:01 xjinnyy JINNY Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/18:11:32:02 xjinnyy JINNY PageOpen LaunchDialog
2014/4/18:11:34:10 xjinnyy JINNY Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2014/4/18:11:34:10 xjinnyy JINNY Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2014/4/18:11:34:10 xjinnyy JINNY Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2014/4/18:11:34:21 xjinnyy JINNY PageOpen LicenseDialog
2014/4/18:11:34:21 xjinnyy JINNY PageOpen ProductInfoDialog
2014/4/18:11:34:21 xjinnyy JINNY PageOpen InventorFlavorSelectionDialog
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==DefaultLanguage: en-us
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==InstallName: INVENTOR
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==ProductName: Autodesk Inventor 2014
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==DisplayName: Autodesk® Inventor® 2014
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==DeploymentName:
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==SetupTitle: Autodesk Inventor 2014
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==ConfigTransform:
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==ExeParams:
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==ProductCode: {7F4DD591-1864-0001-0000-7107D70F3DB4}
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==SupportLink:
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==InfotainmentLink:
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==MsiFileName: inventor.msi
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==AdminImageConfigName: Imgx64
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==AdminImageRoot:
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==GetBaseDeploymentName:
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==DeploymentLocation:
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==DocumentLink: http://autodesk.com/wikihelp-inventor-install-2014-enu
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==InstallDeploymentShortcut:
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==ModifyDeploymentShortcut:
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==SetupLockType: 2
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==SetupNetworkType: 1
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==SystemLocale: 1033
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==EvalMsiFilePath: C:\Users\xjinnyy\AppData\Local\Temp\_AI2F7C.tmp\SetupRes\eval.msi
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2014\EULA
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==InstallLogPath: C:\Users\xjinnyy\AppData\Local\Temp\Inventor2014Install.log
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==ConfigFile: C:\Users\xjinnyy\AppData\Local\Temp\_AI2F7C.tmp\Setup.ini
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==SetupPath: C:\Users\xjinnyy\AppData\Local\Temp\_AI2F7C.tmp\
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==NetworkLogPath:
2014/4/18:11:34:22 xjinnyy JINNY Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2014
2014/4/18:11:36:19 xjinnyy JINNY Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2014/4/18:11:36:19 xjinnyy JINNY PageOpen ProductSelectionDialog2
2014/4/18:11:36:46 xjinnyy JINNY PageOpen FullProgressDialog
2014/4/18:11:36:46 xjinnyy JINNY Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/DIRE...
2014/4/18:11:37:27 xjinnyy JINNY Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/DIRE...
2014/4/18:11:37:27 xjinnyy JINNY Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/18:11:37:43 xjinnyy JINNY Install DirectX® Runtime Succeeded
2014/4/18:11:37:49 xjinnyy JINNY Download Play CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/18:11:44:41 xjinnyy JINNY Download Aborted CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/18:11:44:41 xjinnyy JINNY Install Autodesk Material Library 2014 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2014/4/18:11:44:42 xjinnyy JINNY Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/4/18:11:44:42 xjinnyy JINNY PageOpen InstallCompleteDialog
2014/4/18:11:55:02 xjinnyy JINNY === Setup ended ===
2014/4/18:14:25:44 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/18:14:25:44 xjinnyy JINNY Path_Length: 182
2014/4/18:14:25:44 xjinnyy JINNY Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/4/18:14:25:44 xjinnyy JINNY Launch
2014/4/18:14:25:44 xjinnyy JINNY CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_S... /SN 900-46646903 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/18:14:25:44 xjinnyy JINNY Setup Windows update reboot is pending
2014/4/18:14:26:03 xjinnyy JINNY Setup Autodesk Inventor 2014 Will restart automatically.
2014/4/18:14:26:03 xjinnyy JINNY === Setup ended ===
2014/4/18:14:30:20 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/18:14:30:20 xjinnyy JINNY Path_Length: 182
2014/4/18:14:30:20 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AIAB1B.tmp
2014/4/18:14:30:20 xjinnyy JINNY Launch
2014/4/18:14:30:22 xjinnyy JINNY === Setup ended ===
2014/4/18:14:30:20 xjinnyy JINNY Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/4/18:14:30:20 xjinnyy JINNY CommandLine
2014/4/18:14:34:36 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/18:14:34:36 xjinnyy JINNY Path_Length: 182
2014/4/18:14:34:36 xjinnyy JINNY Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/4/18:14:34:36 xjinnyy JINNY Launch
2014/4/18:14:34:36 xjinnyy JINNY CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_S... /SN 900-46646903 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/18:14:34:36 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AI951E.tmp
2014/4/18:14:40:50 xjinnyy JINNY === Setup ended ===
2014/4/18:14:34:38 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/18:14:34:38 xjinnyy JINNY Path_Length: 182
2014/4/18:14:34:38 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AI951E.tmp
2014/4/18:14:34:38 xjinnyy JINNY Launch
2014/4/18:14:34:39 xjinnyy JINNY Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/SETU...
2014/4/18:14:40:48 xjinnyy JINNY Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/SETU...
2014/4/18:14:40:49 xjinnyy JINNY Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\xjinnyy\AppData\Local\Temp\_AI951E.tmp\Setup\InventorUI.dll
2014/4/18:14:40:49 xjinnyy JINNY Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/18:14:40:50 xjinnyy JINNY PageOpen LaunchDialog
2014/4/18:14:49:41 xjinnyy JINNY Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2014/4/18:14:49:41 xjinnyy JINNY Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2014/4/18:14:49:41 xjinnyy JINNY Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2014/4/18:14:50:05 xjinnyy JINNY PageOpen LicenseDialog
2014/4/18:14:50:05 xjinnyy JINNY PageOpen ProductInfoDialog
2014/4/18:14:50:05 xjinnyy JINNY PageOpen InventorFlavorSelectionDialog
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==DefaultLanguage: en-us
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==InstallName: INVENTOR
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==ProductName: Autodesk Inventor 2014
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==DisplayName: Autodesk® Inventor® 2014
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==DeploymentName:
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==SetupTitle: Autodesk Inventor 2014
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==ConfigTransform:
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==ExeParams:
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==ProductCode: {7F4DD591-1864-0001-0000-7107D70F3DB4}
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==SupportLink:
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==InfotainmentLink:
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==MsiFileName: inventor.msi
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==AdminImageConfigName: Imgx64
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==AdminImageRoot:
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==GetBaseDeploymentName:
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==DeploymentLocation:
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==DocumentLink: http://autodesk.com/wikihelp-inventor-install-2014-enu
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==InstallDeploymentShortcut:
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==ModifyDeploymentShortcut:
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==SetupLockType: 2
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==SetupNetworkType: 1
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==SystemLocale: 1033
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==EvalMsiFilePath: C:\Users\xjinnyy\AppData\Local\Temp\_AI951E.tmp\SetupRes\eval.msi
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2014\EULA
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==InstallLogPath: C:\Users\xjinnyy\AppData\Local\Temp\Inventor2014Install.log
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==ConfigFile: C:\Users\xjinnyy\AppData\Local\Temp\_AI951E.tmp\Setup.ini
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==SetupPath: C:\Users\xjinnyy\AppData\Local\Temp\_AI951E.tmp\
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==NetworkLogPath:
2014/4/18:14:50:05 xjinnyy JINNY Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2014
2014/4/18:15:27:41 xjinnyy JINNY Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2014/4/18:15:27:41 xjinnyy JINNY PageOpen ProductSelectionDialog2
2014/4/18:15:27:55 xjinnyy JINNY PageOpen FullProgressDialog
2014/4/18:15:27:55 xjinnyy JINNY Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/DIRE...
2014/4/18:15:27:57 xjinnyy JINNY Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/DIRE...
2014/4/18:15:27:57 xjinnyy JINNY Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/18:15:28:02 xjinnyy JINNY Install DirectX® Runtime Succeeded
2014/4/18:15:28:03 xjinnyy JINNY Download Play CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/18:15:31:40 xjinnyy JINNY Download Aborted CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/18:15:31:40 xjinnyy JINNY Install Autodesk Material Library 2014 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2014/4/18:15:31:40 xjinnyy JINNY Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/4/18:15:31:41 xjinnyy JINNY PageOpen InstallCompleteDialog
2014/4/18:15:43:49 xjinnyy JINNY === Setup ended ===
2014/4/18:20:05:52 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/18:20:05:52 xjinnyy JINNY Path_Length: 182
2014/4/18:20:05:52 xjinnyy JINNY Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/4/18:20:05:52 xjinnyy JINNY Launch
2014/4/18:20:05:52 xjinnyy JINNY CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_S... /SN 900-46646903 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/18:20:05:52 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AIDE1C.tmp
2014/4/18:20:05:55 xjinnyy JINNY === Setup ended ===
2014/4/18:20:05:54 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/18:20:05:54 xjinnyy JINNY Path_Length: 182
2014/4/18:20:05:54 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AIDE1C.tmp
2014/4/18:20:05:54 xjinnyy JINNY Launch
2014/4/18:20:05:54 xjinnyy JINNY Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/SETU...
2014/4/18:20:05:54 xjinnyy JINNY Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\xjinnyy\AppData\Local\Temp\_AIDE1C.tmp\Setup\InventorUI.dll
2014/4/18:20:05:54 xjinnyy JINNY Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/18:20:05:55 xjinnyy JINNY PageOpen LaunchDialog
2014/4/18:20:06:23 xjinnyy JINNY Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2014/4/18:20:06:23 xjinnyy JINNY Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2014/4/18:20:06:23 xjinnyy JINNY Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2014/4/18:20:06:37 xjinnyy JINNY PageOpen LicenseDialog
2014/4/18:20:06:37 xjinnyy JINNY PageOpen ProductInfoDialog
2014/4/18:20:06:37 xjinnyy JINNY PageOpen InventorFlavorSelectionDialog
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==DefaultLanguage: en-us
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==InstallName: INVENTOR
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==ProductName: Autodesk Inventor 2014
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==DisplayName: Autodesk® Inventor® 2014
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==DeploymentName:
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==SetupTitle: Autodesk Inventor 2014
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==ConfigTransform:
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==ExeParams:
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==ProductCode: {7F4DD591-1864-0001-0000-7107D70F3DB4}
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==SupportLink:
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==InfotainmentLink:
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==MsiFileName: inventor.msi
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==AdminImageConfigName: Imgx64
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==AdminImageRoot:
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==GetBaseDeploymentName:
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==DeploymentLocation:
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==DocumentLink: http://autodesk.com/wikihelp-inventor-install-2014-enu
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==InstallDeploymentShortcut:
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==ModifyDeploymentShortcut:
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==SetupLockType: 2
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==SetupNetworkType: 1
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==SystemLocale: 1033
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==EvalMsiFilePath: C:\Users\xjinnyy\AppData\Local\Temp\_AIDE1C.tmp\SetupRes\eval.msi
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2014\EULA
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==InstallLogPath: C:\Users\xjinnyy\AppData\Local\Temp\Inventor2014Install.log
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==ConfigFile: C:\Users\xjinnyy\AppData\Local\Temp\_AIDE1C.tmp\Setup.ini
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==SetupPath: C:\Users\xjinnyy\AppData\Local\Temp\_AIDE1C.tmp\
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==NetworkLogPath:
2014/4/18:20:06:37 xjinnyy JINNY Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2014
2014/4/18:20:07:12 xjinnyy JINNY Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2014/4/18:20:07:12 xjinnyy JINNY PageOpen ProductSelectionDialog2
2014/4/18:20:07:21 xjinnyy JINNY PageOpen FullProgressDialog
2014/4/18:20:07:21 xjinnyy JINNY Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/DIRE...
2014/4/18:20:07:21 xjinnyy JINNY Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/18:20:07:25 xjinnyy JINNY Install DirectX® Runtime Succeeded
2014/4/18:20:07:25 xjinnyy JINNY Download Play CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/18:20:12:06 xjinnyy JINNY Download Aborted CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/18:20:12:06 xjinnyy JINNY Install Autodesk Material Library 2014 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2014/4/18:20:12:06 xjinnyy JINNY Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/4/18:20:12:07 xjinnyy JINNY PageOpen InstallCompleteDialog
2014/4/18:20:24:28 xjinnyy JINNY === Setup ended ===
2014/4/18:22:35:22 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/18:22:35:22 xjinnyy JINNY Path_Length: 182
2014/4/18:22:35:22 xjinnyy JINNY Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/4/18:22:35:22 xjinnyy JINNY Launch
2014/4/18:22:35:22 xjinnyy JINNY CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_S... /SN 900-46646903 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/18:22:35:22 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AIBAF9.tmp
2014/4/18:22:35:25 xjinnyy JINNY === Setup ended ===
2014/4/18:22:35:24 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/18:22:35:24 xjinnyy JINNY Path_Length: 182
2014/4/18:22:35:24 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AIBAF9.tmp
2014/4/18:22:35:24 xjinnyy JINNY Launch
2014/4/18:22:35:24 xjinnyy JINNY Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/SETU...
2014/4/18:22:35:24 xjinnyy JINNY Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\xjinnyy\AppData\Local\Temp\_AIBAF9.tmp\Setup\InventorUI.dll
2014/4/18:22:35:24 xjinnyy JINNY Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/18:22:35:25 xjinnyy JINNY PageOpen LaunchDialog
2014/4/18:22:35:31 xjinnyy JINNY Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2014/4/18:22:35:31 xjinnyy JINNY Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2014/4/18:22:35:31 xjinnyy JINNY Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2014/4/18:22:35:51 xjinnyy JINNY PageOpen LicenseDialog
2014/4/18:22:35:51 xjinnyy JINNY PageOpen ProductInfoDialog
2014/4/18:22:35:51 xjinnyy JINNY PageOpen InventorFlavorSelectionDialog
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==DefaultLanguage: en-us
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==InstallName: INVENTOR
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==ProductName: Autodesk Inventor 2014
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==DisplayName: Autodesk® Inventor® 2014
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==DeploymentName:
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==SetupTitle: Autodesk Inventor 2014
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==ConfigTransform:
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==ExeParams:
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==ProductCode: {7F4DD591-1864-0001-0000-7107D70F3DB4}
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==SupportLink:
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==InfotainmentLink:
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==MsiFileName: inventor.msi
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==AdminImageConfigName: Imgx64
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==AdminImageRoot:
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==GetBaseDeploymentName:
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==DeploymentLocation:
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==DocumentLink: http://autodesk.com/wikihelp-inventor-install-2014-enu
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==InstallDeploymentShortcut:
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==ModifyDeploymentShortcut:
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==SetupLockType: 2
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==SetupNetworkType: 1
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==SystemLocale: 1033
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==EvalMsiFilePath: C:\Users\xjinnyy\AppData\Local\Temp\_AIBAF9.tmp\SetupRes\eval.msi
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2014\EULA
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==InstallLogPath: C:\Users\xjinnyy\AppData\Local\Temp\Inventor2014Install.log
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==ConfigFile: C:\Users\xjinnyy\AppData\Local\Temp\_AIBAF9.tmp\Setup.ini
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==SetupPath: C:\Users\xjinnyy\AppData\Local\Temp\_AIBAF9.tmp\
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==NetworkLogPath:
2014/4/18:22:35:51 xjinnyy JINNY Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2014
2014/4/18:22:40:59 xjinnyy JINNY Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2014/4/18:22:40:59 xjinnyy JINNY PageOpen ProductSelectionDialog2
2014/4/18:22:41:08 xjinnyy JINNY PageOpen FullProgressDialog
2014/4/18:22:41:08 xjinnyy JINNY Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/DIRE...
2014/4/18:22:41:08 xjinnyy JINNY Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/18:22:41:13 xjinnyy JINNY Install DirectX® Runtime Succeeded
2014/4/18:22:41:14 xjinnyy JINNY Download Play CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/18:22:46:44 xjinnyy JINNY Download Aborted CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/18:22:46:44 xjinnyy JINNY Install Autodesk Material Library 2014 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2014/4/18:22:46:45 xjinnyy JINNY Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/4/18:22:46:45 xjinnyy JINNY PageOpen InstallCompleteDialog
2014/4/18:23:29:05 xjinnyy JINNY === Setup ended ===
2014/4/18:23:36:10 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/18:23:36:10 xjinnyy JINNY Path_Length: 182
2014/4/18:23:36:10 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AI5EFE.tmp
2014/4/18:23:36:10 xjinnyy JINNY Launch
2014/4/18:23:36:18 xjinnyy JINNY === Setup ended ===
2014/4/18:23:36:08 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/18:23:36:08 xjinnyy JINNY Path_Length: 182
2014/4/18:23:36:08 xjinnyy JINNY Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/4/18:23:36:08 xjinnyy JINNY Launch
2014/4/18:23:36:08 xjinnyy JINNY CommandLine
2014/4/18:23:36:08 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AI5EFE.tmp
2014/4/19:00:27:53 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/19:00:27:53 xjinnyy JINNY Path_Length: 182
2014/4/19:00:27:53 xjinnyy JINNY Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/4/19:00:27:53 xjinnyy JINNY Launch
2014/4/19:00:27:53 xjinnyy JINNY CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_S... /SN 900-46646903 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/19:00:27:53 xjinnyy JINNY Setup Windows update reboot is pending
2014/4/19:00:27:57 xjinnyy JINNY === Setup ended ===
2014/4/19:00:30:26 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/19:00:30:26 xjinnyy JINNY Path_Length: 182
2014/4/19:00:30:26 xjinnyy JINNY Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/4/19:00:30:26 xjinnyy JINNY Launch
2014/4/19:00:30:26 xjinnyy JINNY CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_S... /SN 900-46646903 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/19:00:30:26 xjinnyy JINNY Setup Windows update reboot is pending
2014/4/19:00:30:33 xjinnyy JINNY === Setup ended ===
2014/4/19:00:40:59 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/19:00:40:59 xjinnyy JINNY Path_Length: 182
2014/4/19:00:40:59 xjinnyy JINNY Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/4/19:00:40:59 xjinnyy JINNY Launch
2014/4/19:00:40:59 xjinnyy JINNY CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_S... /SN 900-46646903 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/19:00:40:59 xjinnyy JINNY Setup Windows update reboot is pending
2014/4/19:00:41:17 xjinnyy JINNY Setup Autodesk Inventor 2014 Will restart automatically.
2014/4/19:00:41:17 xjinnyy JINNY === Setup ended ===
2014/4/19:00:49:30 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/19:00:49:30 xjinnyy JINNY Path_Length: 182
2014/4/19:00:49:30 xjinnyy JINNY Current Directory C:\Autodesk\Autodesk_Inventor_2014_Eng_64bit_wi_en-US
2014/4/19:00:49:30 xjinnyy JINNY Launch
2014/4/19:00:49:30 xjinnyy JINNY CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/Autodesk_Inventor_2014_Eng_64bit_wi_en-US_S... /SN 900-46646903 /PK 797F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/19:00:49:30 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AIAE63.tmp
2014/4/19:00:51:57 xjinnyy JINNY === Setup ended ===
2014/4/19:00:49:31 xjinnyy JINNY === Setup started on JINNY by xjinnyy ===
2014/4/19:00:49:31 xjinnyy JINNY Path_Length: 182
2014/4/19:00:49:31 xjinnyy JINNY Current Directory C:\Users\xjinnyy\AppData\Local\Temp\_AIAE63.tmp
2014/4/19:00:49:31 xjinnyy JINNY Launch
2014/4/19:00:49:32 xjinnyy JINNY Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/SETU...
2014/4/19:00:51:55 xjinnyy JINNY Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/SETU...
2014/4/19:00:51:56 xjinnyy JINNY Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\xjinnyy\AppData\Local\Temp\_AIAE63.tmp\Setup\InventorUI.dll
2014/4/19:00:51:56 xjinnyy JINNY Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/19:00:51:56 xjinnyy JINNY PageOpen LaunchDialog
2014/4/19:00:53:11 xjinnyy JINNY Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2014/4/19:00:53:11 xjinnyy JINNY Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2014/4/19:00:53:11 xjinnyy JINNY Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2014/4/19:00:53:29 xjinnyy JINNY PageOpen LicenseDialog
2014/4/19:00:53:29 xjinnyy JINNY PageOpen ProductInfoDialog
2014/4/19:00:53:29 xjinnyy JINNY PageOpen InventorFlavorSelectionDialog
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==DefaultLanguage: en-us
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==InstallName: INVENTOR
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==ProductName: Autodesk Inventor 2014
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==DisplayName: Autodesk® Inventor® 2014
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==DeploymentName:
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==SetupTitle: Autodesk Inventor 2014
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==ConfigTransform:
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==ExeParams:
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==ProductCode: {7F4DD591-1864-0001-0000-7107D70F3DB4}
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==SupportLink:
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==InfotainmentLink:
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==MsiFileName: inventor.msi
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==AdminImageConfigName: Imgx64
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==AdminImageRoot:
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==GetBaseDeploymentName:
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==DeploymentLocation:
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==DocumentLink: http://autodesk.com/wikihelp-inventor-install-2014-enu
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==InstallDeploymentShortcut:
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==ModifyDeploymentShortcut:
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==SetupLockType: 2
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==SetupNetworkType: 1
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==SystemLocale: 1033
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==EvalMsiFilePath: C:\Users\xjinnyy\AppData\Local\Temp\_AIAE63.tmp\SetupRes\eval.msi
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2014\EULA
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==InstallLogPath: C:\Users\xjinnyy\AppData\Local\Temp\Inventor2014Install.log
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==ConfigFile: C:\Users\xjinnyy\AppData\Local\Temp\_AIAE63.tmp\Setup.ini
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==SetupPath: C:\Users\xjinnyy\AppData\Local\Temp\_AIAE63.tmp\
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==NetworkLogPath:
2014/4/19:00:53:29 xjinnyy JINNY Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2014
2014/4/19:00:54:38 xjinnyy JINNY Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2014/4/19:00:54:38 xjinnyy JINNY PageOpen ProductSelectionDialog2
2014/4/19:00:54:47 xjinnyy JINNY PageOpen FullProgressDialog
2014/4/19:00:54:48 xjinnyy JINNY Download Play CM http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CM.t...
2014/4/19:00:55:56 xjinnyy JINNY Download Complete CM http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CM.t...
2014/4/19:00:55:56 xjinnyy JINNY Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/19:00:56:42 xjinnyy JINNY Install Autodesk Material Library 2014 Succeeded
2014/4/19:00:56:42 xjinnyy JINNY Download Play CMILB http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/19:00:57:59 xjinnyy JINNY Download Complete CMILB http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/19:00:57:59 xjinnyy JINNY Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2014" SETUP_PACKAGECODE={8CB42675-1800-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/19:00:58:28 xjinnyy JINNY Install Autodesk Material Library 2014 - Base Image Library Succeeded
2014/4/19:00:58:29 xjinnyy JINNY Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/DIRE...
2014/4/19:00:58:41 xjinnyy JINNY Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/DIRE...
2014/4/19:00:58:41 xjinnyy JINNY Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Inventor 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/19:00:58:47 xjinnyy JINNY Install DirectX® Runtime Succeeded
2014/4/19:00:58:47 xjinnyy JINNY Download Play CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/19:01:03:43 xjinnyy JINNY Download Aborted CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/EDU/{1F529783-B4DA-4922-AAA5-D4B48AC2C880}/CMIL...
2014/4/19:01:03:43 xjinnyy JINNY Install Autodesk Material Library 2014 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2014/4/19:01:03:44 xjinnyy JINNY Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
Tags (1)
3 REPLIES 3
pendean
Both of those errors are documented and solved in this forum: try the search if you don't want to wait any longer.
in reply to: pendean
What does this mean?
emily.xu
Try to download the installer to local, and install from there.
  • Visit the Virtual Agent.
  • Click Download Links on the list of topics in the right-hand panel.
  • Follow the on-screen prompts to find the installer file you need
Emily Xu
Product Support
Administrator Productivity
