Hi, I have been having trouble with installing AUTOcad Architecture and recieve the same error. I really don't know that is wrong. Any help is greatly appreciated. Thank you.
2015/1/22:20:01:02 USER USERINFINITY === Setup started on USERINFINITY by USER ===
2015/1/22:20:01:02 USER USERINFINITY Launch
2015/1/22:20:01:03 USER USERINFINITY PageOpen LaunchDialog
2015/1/22:20:14:56 USER USERINFINITY PageOpen LicenseDialog
2015/1/22:20:14:59 USER USERINFINITY PageOpen ProductInfoDialog
2015/1/22:20:15:14 USER USERINFINITY PageOpen ProductSelectionDialog2
2015/1/22:20:15:22 USER USERINFINITY PageOpen FullProgressDialog
2015/1/22:20:15:22 USER USERINFINITY Installing DirectX Runtime: C:\Autodesk\AutoCAD_Architecture_2013_English_Win_64Bit\3rdParty\DirectX\DXSETUP.exe /silent
2015/1/22:20:15:32 USER USERINFINITY Install DirectX Runtime Succeeded
2015/1/22:20:15:32 USER USERINFINITY Installing AutoCADĀ® Architecture 2013: TRANSFORMS="C:\Autodesk\AutoCAD_Architecture_2013_English_Win_64Bit\x64\en-us\ACA\ACA.mst;C:\Users\USER\AppData\Local\Temp\_AIB970.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2013_English_Win_64Bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/1/22:20:16:49 USER USERINFINITY Install AutoCADĀ® Architecture 2013 Failed Installation aborted, Result=1603
2015/1/22:20:16:49 USER USERINFINITY Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Solved by TravisNave. Go to Solution.
Hi @Anonymous,
Welcome to the Community.
Check out the suggested solutions from these Autodesk Solution below and let us know if it resolves your installation problem:
Error 1603 during installation of Autodesk software
Autodesk program installation fails
I tried everything listed in both articles, and the same error occurrs. The instalation log is also the same. Is there anything else I can do? Thank you.
Hi
I had a similar problem and found that the problem was solved if I saved the file first and then installed from the hard drive rather than install from a download
Hope this works for you
Rob
Your Autodesk installer is failing because you may already have another vertical flavor of AutoCAD installed and/or updated. For more information on how to resolve this issue, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/AutoCAD-2013-Suite-failed-installation-aborted-...
Good Luck!
