Installation & Licensing
Active Contributor
haisin.rusli
Message 1 of 10 (1,790 Views)
Error 1603 and 1619 during AutoCAD MEP Suite 2013 installation
1790 Views, 9 Replies
12-18-2012 08:08 PM
I am trying to install AutoCAD MEP Suite 2013 on windows 7 - 64 Bit and I through the serial number part, but as it installing, it just aborts.  When I look at the installation log, I see errors 1603 and 1619.
error message :" DirectX Runtime Failed Failure is ignored, Result=1619 "
I have tried to turn off Antivirus. Deleting Service Pack 1 for AutoCAD etc but still didn't work.
I have Product Design Suite 2013 installed before this installation.
I attached the log file and error message.
Could someone help?
Best Regards,
Haisin Rusli
Product Support
emily.xu
Message 2 of 10 (1,759 Views)
Re: Error 1603 and 1619 during AutoCAD MEP Suite 2013 installation
12-19-2012 06:46 PM in reply to: haisin.rusli
I would say you have done most efforts for the installation failure, for the error code is 1603 which is a general error, many things can cause this, except what you have done, I want to give you the following suggestions to try:
1  Try to use another admin user to login your system and install
2  Try to copy the installation media contents into your local harddisk and install from there.
3  Turn off UAC if your OS is Windows 7.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
*Expert Elite*
TravisNave
Message 3 of 10 (1,738 Views)
12-20-2012 12:47 PM in reply to: haisin.rusli
In addition to copying the media to your local HDD and installing from there, double-check that you do not also have any other version of AutoCAD 2013 flavors installed.  I have noticed that products like MEP and Mechanical, etc. all install to C:\Program Files\Autodesk\AutoCAD 2013\ regardless of flavor.  If another AutoCAD is pre-existing, it will not install.
Active Contributor
haisin.rusli
Message 4 of 10 (1,642 Views)
01-09-2013 12:07 AM in reply to: emily.xu
Hi Emily Xu,
I have tried Turn off UAC in my Windows 7 Prof. ,copy the installation media contents into my local harddisk and install from there and use another admin user to login mysystem and install, but the error still exist.
Best Regards,
Haisin Rusli
Active Contributor
haisin.rusli
Message 5 of 10 (1,641 Views)
01-09-2013 12:09 AM in reply to: TravisNave
Hi Travis Nave,
Yes I have AutoCAD Mechanical installed on the system. should I uninstall it before installing AutoCAD MEP?
How if I need AutoCAD mechanical then?
Best Regards,
Haisin Rusli
*Expert Elite*
TravisNave
Message 6 of 10 (1,616 Views)
01-10-2013 08:57 AM in reply to: haisin.rusli
That is actually a good question.  Autodesk needs to address the fact that their suites are using the AutoCAD 2013 directory to install their base AutoCAD from their suites but it is preventing further verticals from being installed.  You might see if doing a custom install will allow you to change the installation home directory.
blewis
Message 7 of 10 (1,433 Views)
02-22-2013 03:49 PM in reply to: TravisNave
Travis, I totally agree.   I’m getting these error codes as well trying to install AutoCAD Architecture 2013.  It’s getting so frustrating dealing with the Autodesk software.  Seems we have to do these install dances with every darn release.  It’s getting so old.  Why in the world do their applications have to share files or directories.  No one has limited or slow hard drives anymore, why can’t the darn applications install into their own structures.  Out of all our office software, the Autodesk products cause the biggest headaches and problems.  We can’t run around to our many machine in various offices manually installing the applications, nor uninstalling other components (used by other applications) to get their product installed.
If their application needs a certain version of C++, then it should clearly identify this, and provide the needed sub component themselves, or at least a link to install it from the other manufacturer.  *shakes head*
Sorry for the rant, but these things keep showing up with their products.  Getting VERY old.
Autodesk,
Please develop a much more stable installation process.
"When you do things right, people won't be sure you've done anything at all." (Futurama)
Brian Lewis
CAD Manager, Civil Designer
www.uskh.com
AutoCAD, AutoCAD Architecture, Civil 3D, AutoCAD MEP
Revit Architecture, Revit Structural, Revit MEP
(versions 2008-2011)
*Expert Elite*
TravisNave
Message 8 of 10 (1,429 Views)
02-22-2013 03:54 PM in reply to: haisin.rusli
I wrote a new work around for this. 1603 in my hot signature.
blewis
Message 9 of 10 (1,425 Views)
02-22-2013 03:57 PM in reply to: TravisNave
Thanks Travis.
I'll look it over and see what I can do.
Much appreciated.
Brian Lewis
www.uskh.com
*Expert Elite*
TravisNave
Message 10 of 10 (1,424 Views)
02-22-2013 03:59 PM in reply to: blewis
It was the best I could do with what I had. Good luck!
Post to the Community
New Post
Need installation help?
