Installation & Licensing
Error [-15.570.0] while running Inventor 2011
6 REPLIES 6
9955 Views, 6 Replies
Greetings to all,
I am receiving an error while running Inventor 2011 installed on a Laptop running on Windows 7 Professional as follows.
A valid license could not be obtained by the network license manager.
If you are still unable to obtain a licsense,contact your administrator.
Error [-15.570.0]
I have also installed the NLM on the same laptop and when i perfom a status enquiry, all licenses are available and unused.
Through search engines, I was able to find some fixes eg Changing of Environment Variables and Allowing port 2080,2700-27009 and disabling of Antivirus but none of these worked.
The error still occur even when i specify the license file.
Has anyone encountered such a problem and knows how to fix it?
Kindly assist,
Peter,
6 REPLIES 6
hashim.mundol
please get the ipv6 patch for license manager (win7 has ipv6 by default)
http://usa.autodesk.com/getdoc/id=DL10976858
also please make sure you can ping the server name resolving ipv4 address. if not please add an entry for hostname in hosts file.
link shows how to edit hosts file
http://www.ezlan.net/host.html
let me know if you need more help
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
in reply to: hashim.mundol
Hello Hashim,
Thank you very much for the response.
I just want to inform you that the Patch worked for me and now my client is able to run Inventor 2011 installed with the NLM on the same laptop running on Windows 7 Professional.
Thanks alot for the assistance.
Peter K'onunda,
Product Support,
Numerical Machining Complex,
Nairobi-Kenya.
when will there be new serial numbers?
CAD seems to be running out of numbers
clhn
HeIlo,
I managed to install inventor 2011 on a computer running Windows 7 Professional which also acts as the licensing server and was able to solve the ip6 problem encountered  while running the software on the same computer by using ip6 support patch.
My new challenge is to get client computers running on Windows 7 too, to check licenses from the server which indicates that the licenses are available for use.
I still get the error above,...error 15.570.0.
Is it possible to get an urgent solution to the problem.
I have three users waiting for a remedy in the shortest time possible.
Thank you in advance.llo,
TravisNave
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
Autodesk Forums:
in reply to: TravisNave
Thanks! this worked for me.
Did the microsoft fix first
http://support.microsoft.com/kb/929852/en-us
Cam
Administrator Productivity
