Installation & Licensing
1543 Views, 5 Replies
ERROR 15.10.10061
I recently downloaded the Autodesk Simulation CFD 2013 for Windows 64-bit student version. I succesfully installed it, but when I try to run the software for the first time, an error message appears this picture:
And then when I press "Close", appears:
How could I fix it? I am hopeless...
HELP!!
5 REPLIES 5
TravisNave
Where is your Autodesk Network License Manager installed?  If it is installed on the same machine, then it is likely an IPv6 issue.  If it is on a server, check PING connectivity and make sure the firewall is not blocking ports 27000 and 2080.  Also, make sure the license manager service is running and licenses are available.  If you have a stand-alone licensed product, then you need to reinstall as stand-alone.
Autodesk Forums:
in reply to: TravisNave
I think that my trouble is solved...
As your reply is concerned, I checked every item and it was not the issue. I saw this post and I realized that I didn't pick the "Stand-alone" option:
http://forums.autodesk.com/t5/Autodesk-Simulation-CFD/How-to-get-license-file-from-registration-it-i...
But I have another question...
I am a student in which university we can obtain licence for every Autodesk program, but when I installed the Simulation CFD 2013 (Stand-alone) I recieved a new message-picture:
How could I activate my Autodesk Simulation CFD license? Before my 30 days free trial?
TravisNave
Click the Activate button.
Autodesk Forums:
But if I "Activate", which license will I obtain??
I don't want the free trial license. I want the student license which gives me more than 30 days...
Sorry Man Sad
TravisNave
Activate it with your student serial number.
Autodesk Forums:
Administrator Productivity
