Installation & Licensing
Member
0 Kudos
Post 1 of 7
Error 1406 Could not write value to key
5215 Views, 6 Replies
01-10-2012 06:20 AM
I get the following error when trying to install Civil 3D 2012 XP SP3
Error 1406. Could not write value to key \Software\Classes\CLSID\{00020820-0000-0000-C000-000000000046}\InprocServer32\11.0.0.0. Verify that you have sufficient access to that key, or contact your support personnal.
Faisal
Product Support
10 Kudos
Post 2 of 7
Re: Error 1406 Could not write value to key
01-10-2012 06:22 AM in reply to: mfaisal_i
You will be much better served posting this question in the Installation and Licensing forum.
Jason Hickey
Premium Services Specialist
Product Support
52 Kudos
Post 3 of 7
01-12-2012 02:49 AM in reply to: mfaisal_i
Please try
http://usa.autodesk.com/getdoc/id=TS1069886
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
897 Kudos
Post 4 of 7
01-12-2012 09:23 AM in reply to: mfaisal_i
If this is due to an old Flash player, you can probably hit ignore about a dozen times and come out okay.  Update your Flash player.
2 Kudos
Post 5 of 7
01-17-2013 11:27 AM in reply to: TravisNave
I'll confirm that this works, even though it seems like the wrong thing to do.
897 Kudos
Post 6 of 7
01-17-2013 11:44 AM in reply to: Diequa
Well, being that I supported this issue multiple times a day as well as went onsite and experienced it myself on customer machines, I think you'll probably be alright.  :smileyvery-happy: The issue is due to a problem that Macromedia had with an old version of Flash.  You should consider upgrading your Adobe Flash plugins as well.  Once you ignore those dozen or so 1406 errors, you'll be on your way.  :smileywink:
0 Kudos
Post 7 of 7
08-20-2013 10:58 AM in reply to: TravisNave
Is there a switch that can be applied to the install script (deployment shortcut) that will ignore all ignores like /I /QB?
