Installation & Licensing
Error 1402 during uninstallation (Could not open key)
16 REPLIES 16
Message 1 of 17
david.lau
35620 Views, 16 Replies
We have been getting this error occasionally come into support and when it finally happened on my computer, I decided to go though the solution and confirm that it does work.
When you try to uninstall an AutoCAD based product, you will get the following error:
Error 1402.  Could not open key:
UNKNOWN\Components\Hex#\Hex#.  Verify that you have sufficient access to that key, or contact your support personnel.
The solution is to change the permissions of the following folder in the Registry:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components
  1. Right Click on Components select permissions.
  2. Click Advanced button.
  3. Select the Owner Tab
  4. Under Change owner to:  Select Administrators (Group) and Click Apply.
  5. Then Select Check box Replace owner on subcontainers and objects and Click Apply.
  6. Go to the Permissions tab, select the Check box:  Replace all child objects Permissions with inheritable permissions from this object and Click apply.  NOTE:  The wording maybe a bit different depending on your operating system.
I have included a video on changing the permissions in Windows Vista & Windows 7.
David Lau
Tags (1)
16 REPLIES 16
Message 2 of 17
gf
Observer
in reply to: david.lau
Hi!
Why does this happen in the first place?
We had this happen by deleting the installationfiles from the install folder IMMEDIATLY AFTER the setup.exe returned, but there where still some parts of the install running which were launched by setup.exe.
So the setup itself returned but not all started install tasks were finished. REALLY BAD design!
Trying to just rerun the setup always failed with strange 'unable to install anchor service' errors which were caused by the '1402' errors during the installation because of messed up permissions by the prior (failed) installation.
I would suggest you create a better and more resilient installation routine to prevent stuff like this from happening in the first place. Only tackling the symptoms does not help in the long run.
Overall Autodesk software installation is still a PITA, but has improved over the years - Which does not mean that it is good right now, only shows how utterly horrible it has been in the past. Still a long way to go...
Message 3 of 17
david.lau
I value your opinion.  This post was only meant to help solve a problem.
David Lau
Message 4 of 17
lusiautocad
I started having issues with this aftern uninstalling all Autodesk products from a Windows 7 64 bit computer to reinstall clean.   I was trying to reinstall a package created on the server.  What I did was drilled down to the actual base .msi install package and started the install this way.  As a result, when there was an error on a class key, I deleted the class key altogether.  Then I hit retry and it recreated it and continued on.
It seems as though the Autocad installer balks when it tries to create a registry key that already exists.
 Incidentally, changing the permissions on the keys had no effect.
Message 5 of 17
~master
in reply to: gf
After making the suggested changes this is what happens when I hit APPLY
Registry Editor could not set owner on the key currently selected, or some of its subkeys.
How can I proceed from here?
Message 6 of 17
TravisNave
in reply to: ~master
Try it a few times.  If that doesn't work, go down and find each individual key that it cannot change and make the changes there.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16508079&linkID=9240617
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 7 of 17
~master
Went ahead and did a complete re-install of the OS.
Thanks for the suggestions.
Message 8 of 17
brankoje57
There is not such key in my registry.
I use Win 7 Ultimate x64
Please help.
Message 9 of 17
eljoseppo
in reply to: brankoje57
I did what you suggested. But not all of the subkeys were listening to me. (see attachment)
No matter if I did all permissions on folder "Components" or "S-1-5-18".
Waht is your advice?
Tags (1)
Message 10 of 17
TravisNave
in reply to: eljoseppo
It takes a couple of tries to get it.  Go back thru and make sure you take ownership.  Then close it all out and try it again.  I typically get it after 2-3 passes.
Autodesk Forums:
Message 11 of 17
fesworkscience
How to solve that problem on win 8.1 ?
Best regards, Evgenii
Message 12 of 17
TravisNave
in reply to: fesworkscience
Same way as Windows 7.
Autodesk Forums:
Message 13 of 17
gf
Observer
in reply to: TravisNave
BTW, after several years have passed, many 'new' versions were released, the setup routines still do a really miserable job...
We routinely experience this (and similar) problems for various reasons.
e.g. A setup runs silently in the background and the user does something with the machine or the power fails, etc.
Quite often the Autodesk setups just don't manage to recover from the things they have already 'done to' the machine...
Obviously a setup which can recover from unexpected failures his is not in the focus of Autodesk at all
Maybe a simple 'Cleanup the mess from a failed setup'-Tool is all that is needed.
Bottom line: Still they same manual recovery procedures are required as a few years ago.... Nothing changed...
DId i mention that the full Autodesk design suites installation takes AGES even on really fast machines with ssd drives. So there is plenty of time for something to interfere with the process.
Message 14 of 17
rwegrzynowski
in reply to: gf
How to slove this problem on windows 10? I can't find the owner tab on the advanced options.
Message 15 of 17
bobby.shipman
Is Windows 10 the same method?  I'm looking in the registry but can't find the Owner tab to be able to follow the correct steps.
Message 16 of 17
pavlov.ds
In the remediation manual, explicitly forgot one more point - 7. Repeat until the key failure errors appear.
Message 17 of 17
Hattmannen
I ran into this problem while trying to uninstall Maya 2017.
The suggested solution of setting the owner for the Components key and all subkeys did, however, not work even after repeating it several times.
I ran into the same error message as other users have posted: That I was unable to set the owner for the current key or some subkeys.
However, I found what was causing the problem, so I thought I post an update here if anyone else should run into the same problem.
I'm doing this on Windows 7, so the exact wording and layout for setting permissions may be different on other versions. The general process should still work, though.
The problem in my case was that the relevant subkeys lacked permissions altogether (thus also lacking the permission to set the owner of the key).
It's an easy fix, though.
Before switching to the Owner tab in the Advanced Security Settings dialogue box, select the Administrators group in the list box and check that it has full control. If not, just click the Edit button and give the Administrators group full control.
Check the box to replace all child object permissions with inheritable permissions from this object. This should give the Administrators group permissions to change the owner on subkeys.
Switch to the Owner tab and select the Administrators group and hit Apply (or OK). That should set the appropriate permissions for the Administrators group as well as take ownership of the entire subtree.
Hope this saves someone an entire OS reinstall.
Administrator Productivity
