Installation & Licensing
error 1335. the cabinet file 'max2.cab' required
3 REPLIES 3
oshahrukho
11060 Views, 3 Replies
hey,
i am installing 3ds max entertainment suit premium 2012 after the autocad architecture 2012 installation so every time 3ds max entertainment suit premium 2012 giving "error 1335. the cabinet file 'max2.cab' required for this installation is corrupt and cannot be used." this error. instead i first time install it before autocad so it was fine but autocad giving error. i again downloaded max2.cab file but still this error, i removed all files except autocad but still this error. i tried to use different user account for installation but still this error.i am using windows 7 64 bit.and i aattached an error image.
Please help me about this issue because i need both softwares at a time.
Shahrukh Nawaz,
Architectural, Interior & 3D Designer
SNK's
Karachi, Pakistan
Designer
3 REPLIES 3
hashim.mundol
in reply to: oshahrukho
installation source is corrupt. please contact your reseller for a replacement media
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
oshahrukho
in reply to: hashim.mundol
i think u didnt read my msg properly. i told u that if i installed max first than autocad it will installed, means both softwares have problems that they are not installing at a same machine if 1 installed.please check this at ur system and let me know please.
awaiting for your soon reply
regards,
Shahrukh Nawaz
Designer
hashim.mundol
These products are part of Suite and we don't have issues installing both on a machine
sorry for not getting the question correctly.
 please try to install the software in diagnostics mode as described here
http://usa.autodesk.com/getdoc/id=TS75218
If the issue persisits, please post the all the log files from the %temp% folder (start->run/search->type %temp% ->Enter) as a zip file.
Hashim Mundol
Autodesk, Inc.
Administrator Productivity
