Installation & Licensing
error 1311 3ds Max 2014
2 REPLIES 2
475 Views, 2 Replies
Trying to install 3ds max 2014 and it keeps coming up with the error attached in the image, I have tried looking for ways to fix it on the forum but so far nothing has worked.
2 REPLIES 2
TravisNave
Looks like a problem with the data.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Good Luck!
Autodesk Forums:
Thankyou 🙂
Administrator Productivity
